COLEMAN HOT WATER CHARGING
Submitted: Monday, Jan 08, 2007 at 21:22
ThreadID: 41011 Views:3158 Replies:6 FollowUps:8
Can someone please tell me what is on their 240v charger for their hot water unit, I have several chargers for different appliances and have mixed them up. I tried them all and each does not do what the book says it should. Can someone please tell me also what the light doeas when charging, and roughly how long to charge. Thanks for any help.
Reply By: Noldi - Monday, Jan 08, 2007 at 22:34
Hi Reddog,
bugger, just went to look for it and it was with 2 others, I think it has a funny large G then NCE, do you have one like that?
When plugged in the bootom LED (Recharging) comes on took probably 20 hours.
Rgds
Ian
AnswerID: 214137
Reply By: Keith_A (Qld) - Monday, Jan 08, 2007 at 22:58
Hi Red - have it in front of me now:
AC/AC Adaptor Xixing
Model XDB44124-515
Pri :240V-50hz
SEC: 12 - 700ma 8.4V
N19613 Made in China
The battery is 6V 4.5AH/20 Hrs.
We charge ours with the the 12V cig/accessories cord supplied....................Keith.
AnswerID: 214147
Follow Up By: renegade - Monday, Jan 08, 2007 at 23:08
Too quick for me Keith - raced out to the garage to get the charger and all the info was already here when I got back.
And it's all the same info.
Don't forget to keep it charged up Red, nothing worse than running out of power on a cold night, standing there all wet and lathered up.
FollowupID: 474394
Follow Up By: Pajman Pete (SA) - Tuesday, Jan 09, 2007 at 11:41
"Don't forget to keep it charged up Red, nothing worse than running out of power on a cold night, standing there all wet and lathered up. "
Yes there is, it is when SWMBO is in the shower and it was you that forgot to charge it!
FollowupID: 474458
Follow Up By: REDDOG - Tuesday, Jan 09, 2007 at 19:33
Thanks guys I thought it was that one but when plugged in it does nothing. The 12 volt charger puts the led on but nothing with the 240 volt, must be broke, will have to take it back to kmart . Just used it for 6 days and as others say they are a very good unit, one cylinder lasted for 5 nights and low battery came on last night, but hadnt been charged since bought in april
FollowupID: 474524
Reply By: Noldi - Wednesday, Jan 10, 2007 at 14:35
Slightly OT but has anyone used the coupler to refill the small gas canisters?
If so is it worthy the effort?
Rgds
Ian
AnswerID: 214429
Follow Up By: Shaker - Wednesday, Jan 10, 2007 at 16:18
I have a MacCoupler, but haven't used it yet .... I will post a report when I have.
FollowupID: 474679
Follow Up By: Noldi - Wednesday, Jan 10, 2007 at 16:31
Tks Shaker, did you buy it from the US?
FollowupID: 474685
Follow Up By: Shaker - Wednesday, Jan 10, 2007 at 16:51
Yes.
FollowupID: 474696
Follow Up By: brett - Thursday, Jan 11, 2007 at 21:26
Got one from the US as well, used it probably a dozen times on the 3 cylinders I have. Works well, just have some common sense when filling and check for leaks after.
FollowupID: 475063
Reply By: Member - Andrew (QLD) - Wednesday, Jan 10, 2007 at 15:14
Unreal Reddog,
I was going to ask the exact same question just the other day (and forgot) as i haven't used mine for around 9 months and the battery still worked!
I must sort through my assortment of power packs and work out which one goes with the coleman system now that i know which 6v one to use :-)
AnswerID: 214439
Follow Up By: Member - Andrew (QLD) - Wednesday, Jan 10, 2007 at 15:19
There's my problem......i was looking for a 6v DC powerpack as i just pulled out the battery to check whether it was 6v or 12v. :-(
FollowupID: 474664
Reply By: brett - Thursday, Jan 11, 2007 at 21:27
I have found the 240V charger charges much q
AnswerID: 214798
Reply By: brett - Thursday, Jan 11, 2007 at 21:29
I have found the 240V charger charges much quicker than the 12V one. After some testing I found the charging rate is about 3 times more on 240v than 12v, the 12 volt will charge but if you have the option use the 240v
AnswerID: 214799
