Putting Out Campfires
Submitted: Tuesday, Jan 09, 2007 at 16:23
ThreadID: 41037 Views:3591 Replies:15 FollowUps:11
Campfire chat recently turned to the question of how best to safely put out a campfire. Opinions varied.
Doing some googling to follow up, I notice that Parks, Fire, and Health authorities all stress the importance of putting out campfires using water, rather than smothering them with sand or soil. Smothering camouflages the fire pit and keeps the coals hot so they can burn feet several hours later.
The water treatment is fine for small fires and where water is readily available. But what do forum members do in desert areas where water is scarce?
Also, if a fire pit has been cooled, is it worthwhile covering it to prevent ash blowing about and making a mess. Some organisations recommend this as a good thing to do.
Your ideas appreciated,
Val.
J and V
- Albert Einstein
Reply By: Member - Phil G (SA) - Tuesday, Jan 09, 2007 at 16:34
We usually have a morning fire with small wood. We use the last shovel of coals down the pit dunny. And the fire trench gets buried - with a trench, theres little evidence left of you having been there and its easy to bury.
AnswerID: 214262
Reply By: ingo57 - Tuesday, Jan 09, 2007 at 16:35
Gday mate
I reckon the best is a rectangular fire pit 20 to 30 cms deep and toss the removed dirt/sand in a mound to the side. When breaking camp let the fire die right down and leave it for the last thing to do before leaving then fill it back in, cant even tell it was there.
AnswerID: 214263
Reply By: Member - Norm C (QLD) - Tuesday, Jan 09, 2007 at 16:53
When we have enough water I always douse the coals with water till it stops steaming. If in a place where there is not enough water for this, we don't have a morning fire. As a result the coals are substantially cooled overnight (we normally don't have a big fire - it's a waste of wood, that others including native animals can use. Also, If we have to carry wood, it is even more important to preserve.
Only exception to this is if we are in a camp ground with proper concrete or similar fireplaces.
On a couple of occasions when the coals have still had too much heat in them, I've dug a hole and burried them with at least 6 inches of cover (or put them in the hole from the Thunderbox if there is one).
Just covering with sand is real bad. When in the Kimberley last year, we were told of a small child who got very serious burns to the feet from walking on a fire place that had been covered with sand. There was apparantly no way it could have been detected until it was walked on. The person who caused the injury would be blistfully unaware (unless you are reading this of course).
AnswerID: 214267
Follow Up By: ingo57 - Wednesday, Jan 10, 2007 at 11:56
The Question Norm, was what do you do in desert areas..... the chance of someone in the Simpson camping in the same spot a few hours after you leave is pretty slim and a died down fire with warm coals is not going to burn anyone,s feet if its buried sufficiently........ as I said 30 cms!! and you say 6inches (15 cms) I think youve contradicted yourself. Like someone else has posted dirty dish water allways helps. In places where a lot of travellers are passing through commonsense comes in to play.
FollowupID: 474624
Follow Up By: Member - Norm C (QLD) - Wednesday, Jan 10, 2007 at 12:40
Hi ingo, my response was to John and Val (original posters) and a general comment on securing camp fires. If it was a response to your post, I would have done it as a follow up to you. Not even sure I had read your post at the time. I might have been typing my response when you posted yours; either way it hardly matters.
I wasn't contradicting you, myself or anyone else. Just stating my practice, view and experience.
FollowupID: 474632
Follow Up By: ingo57 - Wednesday, Jan 10, 2007 at 13:21
Fair enough Norm...
FollowupID: 474638
Reply By: Member - andrew B (Kununurra) - Tuesday, Jan 09, 2007 at 17:00
Gday Val
Generally with water and don't bury, most spots have semi - established fire spots with rocks etc around them. Water shortage for this task is always readily available, as a bucket to store grey water in from the dishes etc is used most of the time. Shower water is also a good option - we usually stand in a 40l elcheapo storage tub
Cheers andrew
AnswerID: 214268
Reply By: Steve63 - Tuesday, Jan 09, 2007 at 17:16
If there is plenty of water available then use water then back fill the fire pit. If you only use the water you need a LOT of water not 1-2l. If you are going to use water 20-30 litres is the sort of volume you may need for any decent fire. If there is no water then I back fill with a decent cover of soil, not 1 inch. If you are in a popular area try to use an existing fire pit or area. At least it will look like a fire and so there is some hint it may be very hot. There is a two way responsibility. You need to put out the fire so that you don't start a bush fire if the wind really comes up, others coming to a camping area need to be wary of obvious fire pits until they have been inspected. If you have small children you need to be very cautious. The water argument comes from a case where a small child fell onto a covered fire and by the time someone raced over and picked her up she had severe burns and ended up lossing some fingers.
I noted the ash in the loo pit in a previous reply, not a bad idea.
Steev
AnswerID: 214272
Reply By: Mikee5 (QLD) - Tuesday, Jan 09, 2007 at 20:33
There have been many documented cases of people (especially children) walking onto a concealed fire which is still hot and burning their feet. Let the fire die right down then put it out with water. Definitely don't bury a burning fire, it will remain hot for hours/days especially in sand.
Mike.
AnswerID: 214297
Follow Up By: silkwood - Tuesday, Jan 09, 2007 at 21:25
In a desert there is not enough water around to douse the fire. Funnily enough this means there is not enough water around to grow excess vegetation with which to have a fire, solution? Unless you bring your own fuel (from outside the desert area) DON'T HAVE A FIRE!
Mark
FollowupID: 474540
Follow Up By: Member - Cruiser (NSW) - Wednesday, Jan 10, 2007 at 09:53
When we were at Kings Canyon about 4 years ago, one of the tour operators just covered the fire they had been using with dirt and about 3 hours later one of the children in our group was walking over to the amenities and was blissfully unaware of the fact that they had had a fire going and you guessed it, she walked over the old fire site and was badly burned on the sole of 1 foot.
Why the operator used dirt I dont know. There was a camp kitchen for tours about 20 feet away and water was readily available.
Fortunately we had a registered nurse in our group and she was carrying a comprehensive first aid kit and was able to render the appropriate treatment.
When we told the management about it, they were very blasé about it all and generally couldnt give a stuff.
FollowupID: 474593
Follow Up By: Hairy - Wednesday, Jan 10, 2007 at 10:08
"In a desert there is not enough water around to douse the fire. Funnily enough this means there is not enough water around to grow excess vegetation with which to have a fire, solution? Unless you bring your own fuel (from outside the desert area) DON'T HAVE A FIRE! "
What?????
FollowupID: 474597
Follow Up By: silkwood - Wednesday, Jan 10, 2007 at 20:57
Hairy, which part of DON'T HAVE A FIRE didn't you understand?
Mark
FollowupID: 474779
Follow Up By: Hairy - Thursday, Jan 11, 2007 at 03:22
Na Mate,
It wasnt the dont have a fire bit I couldnt understant but the logic of "In a desert there is not enough water around to douse the fire. Funnily enough this means there is not enough water around to grow excess vegetation."
I live in what is called a desert and funnily enough there is lots of vegetation and buggerall water.
But your probably right because if I bothered to walk to the right area, and dig a deep enough hole I would probably find enough water to put out the fire...............................But how much would I drink while Im digging???
I still rekon GO THE COMMON SENSE!!!
FollowupID: 474841
Reply By: D-Jack - Tuesday, Jan 09, 2007 at 22:01
Me and my mates usually have a ceremonial 'putting out' of the fire before we leave, it means expelling a few beers consumed the night before, the more beers the better the fire is put out before having to use water!
AnswerID: 214314
Follow Up By: Mikee5 (QLD) - Tuesday, Jan 09, 2007 at 23:19
Don't let anyone stand down wind. LOL
FollowupID: 474565
Reply By: Member - Duncan W (WA) - Tuesday, Jan 09, 2007 at 22:02
Having suffered the consequences of walking over a buried fire pit (badly burnt feet), I usually bury our fire ash/coals as deep as possible and cover over with stones if available. Also pour over the dishwashing water. Try to keep the fires as small as possible so as to conserve wood.
Dunc
AnswerID: 214315
Reply By: Truckster (Vic) - Tuesday, Jan 09, 2007 at 22:03
As said above, burying a fire sometimes does far kall. Fires can burn underground for a long time. We had a swamp fire opposite Cronulla High that lasted 3 mths, it kept coming to life time after time, no matter how much water we threw at it. they ran a dozer through it in the end.
The only sure way is water, and be genrous. If you can touch it or hold the wood, then its cool enough... THEN if you like to leave it clean, bury it.
If your in a desert, its different, you can dig a pit and bury it, as long as theres plenty of sand surrounding your fire, and your in the "DESERT", not a bushy camp site thats the same as the center of the high country. Sand doesnt usually catch fire.
A good idea given to me during a camp with some old bushy was to have very small logs, then in the morning throw them in a bucket of water.. My problem is I like a bonfire not a match!
AnswerID: 214316
Follow Up By: Truckster (Vic) - Thursday, Jan 11, 2007 at 17:05
You could wee into coke bottles, and keep it for later and use tat on the fires.
FollowupID: 474998
Reply By: Member - extfilm (NSW) - Tuesday, Jan 09, 2007 at 22:36
Fraser Island no longer allows fires on the beach for the same reason as post above. The quoute from the ranger when asked was"a small child badly burnt theier feet due to a fire been buried"
AnswerID: 214326
Reply By: Member - Davoe (Nullagine) - Tuesday, Jan 09, 2007 at 22:49
definitly dont bury If you do that the fre will smoulder for days (as a id we had a pet fire and would dig it up every couplke of days and get it going again before burying it)
Water to put out a fire Pfft - try around min 50l. I have spet 10 min with a hose on a fire only to come back in 2 hours to see it going.
Try spreading the coals as it ill go out in a matter of hours with no concentrated hot spot
The politiclly corect methods of putting out fires are NOT the best
AnswerID: 214328
Reply By: Hairy - Tuesday, Jan 09, 2007 at 22:55
There is never one rule for all,
Just use common-sense, look around, do the right thing, think about the person who might roll up 5 mins after you leave and have a conscience.
All will be good.
AnswerID: 214330
Reply By: Member - Phil G (SA) - Tuesday, Jan 09, 2007 at 23:17
Just wondering how many of you actually read Val's original post?
"But what do forum members do in desert areas where water is scarce?"
AnswerID: 214337
Follow Up By: silkwood - Wednesday, Jan 10, 2007 at 16:49
I did!
Mark
FollowupID: 474693
Reply By: Member - Karl - Wednesday, Jan 10, 2007 at 09:33
Where water is scarce I would dig a deep pit to light the fire in and once I have finished with it I would let it die down over night. Don't re-light it in the morning if you are leaving, then use a shovel to turn over the coals to get the heat out of them - do this a number of times whilst you are packing up and then flatten the coals out as much as possible.
If for some reason you do need to re-light it to cook with make it a very small fire just enough for your cooking needs and no more.
Then fill in the pit with the sand and mark it - similar to how you would mark foul ground - which everyone obviously does.
But I think the best advice is to use gas for all your cooking needs and if water is that scarce and you are only having a fire to sit around then I probably wouldn't have a fire at all - less chance of any accidents.
AnswerID: 214370
Reply By: Member - John and Val W (ACT) - Thursday, Jan 11, 2007 at 12:16
Thanks all for your thoughtful responses.
The dangers of covering hot fires with sand are clear. Some good ideas about recycling water when its scarce as in desert areas. Covering up cooled fires makes sense if there are no established fire pits - helps to maintain an unused appearance.
We usually have only a small fire at night - and cook mostly with gas. But a fire adds so much to the camp experience that its hard to go without - even if it means carrying some wood.
Val.
J and V
- Albert Einstein
AnswerID: 214663
