The last GQ ute?
Submitted: Wednesday, Jan 10, 2007 at 09:50
ThreadID: 41054 Views:2366 Replies:5 FollowUps:7
My B_I_L has just bought a 1/99 GQ Patrol 6 wheeler. Is this possible or has the plates been doctored? I thought they were GU's after 98. Any help would be great, thank you.
Trevor.
Reply By: Truckster (Vic) - Wednesday, Jan 10, 2007 at 10:00
99 is not GQ.
AnswerID: 214374
Follow Up By: Member - John - Wednesday, Jan 10, 2007 at 10:10
Bruce, presumes the six wheeler was a ute, LOL, may be not?
John and Jan
FollowupID: 474598
Follow Up By: Trevor R (QLD) - Wednesday, Jan 10, 2007 at 14:04
That is what I thought also truckie but see the links on other replies here and it sounds like some 99's were actually GQ.
Thanks, Trevor.
FollowupID: 474649
Reply By: Member - John - Wednesday, Jan 10, 2007 at 10:00
Trevor, GU utes did come out later than GU wagons, think it was mid 99, but don't quote me, lol. John
John and Jan
AnswerID: 214376
Follow Up By: Trevor R (QLD) - Wednesday, Jan 10, 2007 at 14:06
Thanks John, do you know if the GQ utes of 99 run earlier gearboxes or will it be prone to the 5th gear failures in 99 GU wagons?
Trevor.
FollowupID: 474650
Follow Up By: Robin - Wednesday, Jan 10, 2007 at 16:05
Is correct - you can be quoted John
Robin Miller
FollowupID: 474675
Reply By: donks1 - Wednesday, Jan 10, 2007 at 10:11
y60 ran to 02/99
y61 started 10/97
donks
AnswerID: 214379
Reply By: banjodog - Wednesday, Jan 10, 2007 at 10:15
This is from redbook - 1999 GQ
Both the GQ and the GU cab chassis came out in '99 - GQ not long into the year.
AnswerID: 214381
Follow Up By: robak (QLD) - Wednesday, Jan 10, 2007 at 10:16
Beat me by " that much.
FollowupID: 474600
Follow Up By: Trevor R (QLD) - Wednesday, Jan 10, 2007 at 14:03
Sounds like my B_I_L got one of the last GQ utes made. Do you know if they run the bullet proof GQ gearbox or would it be susceptible to the 5th gear failures in the 99 GU's? it is a n/a 4.2 diesel also.
Thanks Trevor.
FollowupID: 474648
Follow Up By: banjodog - Wednesday, Jan 10, 2007 at 14:27
No doubt a call to Nissan should provide answers to whether the manual boxes are the same or different in that year.
So long as it was assembled after lunch on a Wednesday it should be OK ;-)
FollowupID: 474656
Reply By: robak (QLD) - Wednesday, Jan 10, 2007 at 10:15
1999 NISSAN PATROL GU DX Cab Chassis 2dr Man 5sp 4x4 4.2D (Leaf)
AnswerID: 214383
