75 series diff housing
Submitted: Wednesday, Jan 10, 2007 at 16:36
ThreadID: 41073 Views:4105 Replies:5 FollowUps:4
g'day, i have a small split on the rear diff housing with oil slightly weeping out, will a quick hit with the welder fix it or is there a proper fix/process to repair it. cheers sparra.
Reply By: Peter 2 - Wednesday, Jan 10, 2007 at 16:39
Depends on where and how big the split is, giving it a quick zap will do for temp roadside repairs but it really needs to be cleaned and welded properly.
AnswerID: 214451
Follow Up By: Member - sparra - Wednesday, Jan 10, 2007 at 16:52
g'day pete,the split is very small on the left side a few inches before the diff centre. i can get the boily's here at work to do the job[nearest town hours away], just thought i'd better make sure it's ok just to clean and weld. thanks pete, cheers sparra.
FollowupID: 474697
Follow Up By: Rod W - Thursday, Jan 11, 2007 at 11:05
Makes one wonder why it would split? Is the housing already under some stress or bent? Before any in situ welding I would be trying to brace the diff to prevent it from bending when heat from the welding is applied thus sometime in the future leading to leaking axle oils seals.
Be interested to know the results.
FollowupID: 474905
Reply By: Wayne-o - Wednesday, Jan 10, 2007 at 16:50
hey mate, drain the oil, clean the area, grind it smooth if you have to and fill if you have to then weld a run above and below the crack, clean the welds, then bump the power up slightly and use a slighlt bigger rod, and weld a clean run through the guts, should be able the hand 3 tonne off the weld......(if you wanted too), bu nothing will get through the pal, let me know how you go!!!
AnswerID: 214459
Follow Up By: Member - sparra - Wednesday, Jan 10, 2007 at 16:55
no worries,thanks for that wayne-o. cheers sparra.
FollowupID: 474699
Reply By: Wayne (NSW) - Wednesday, Jan 10, 2007 at 17:12
Sparra,
I had the exact same problem.
Tried to weld the crack on the vehicle, but the crack opened up again.
Took the diff housing out of the vehicle, ground the crack, drilled the end of the crack to stop it getting any bigger and welded a plate over the crack. Replaced the diff and no more leaks, however the other side if the diff housing cracked after doing the Canning and the Kimberleys.
I fixed one crack and another appeared. I could have plated the new crack but where will it end.
I finally ended up getting another second hand diff housing that has not been cracked and put that in.
Why I think that they crack is if the vehicle is jacked up with the jack under the centre of the diff, too much weight is put on to the outer ends of the diff housing and the diff housing bends slightly and then cracks.
The 78 Series that I have now has the reinforced diff housing, the 80 Series was the same but I don't know why they did not reinforce the 75 Series diff housing.
If you want to weld the diff housing and only have to do it once, take the diff housing out and weld plates over the cracks. It might take the best part of a day to but in the long run it will save time.
Wayne
AnswerID: 214466
Follow Up By: Member - sparra - Wednesday, Jan 10, 2007 at 17:50
thanks for the input wayne,the split is only very small at the moment but as you say,it may crack somewhere else again so maybe another housing will be the go.will have a yak to the boily and see what he reckons. i don't what it to let me down out the back of the great sandy etc, thanks again, cheers sparra
[ps.i saw your troopy at your camp at birdsville race weekend,was gunna stop and say g'day but you were'nt there the times i walked past.]
FollowupID: 474718
Reply By: Member - dock - Wednesday, Jan 10, 2007 at 20:57
Sparra, Welding diffs insitu is generally fine ,just make sure the crack is clean of any oil or dirt (wire brush and petrol, if the oil level is crack high you may have to to empty a bit out). I use WIA 16 TC welding rods as they will take to most steel surfaces.
AnswerID: 214523
Reply By: Sam from Weipa Auto Electrics - Thursday, Jan 11, 2007 at 11:37
I have found the ones that we have welded up havent lasted including on my own car I enned up getting a new rear diff housing in the 79series but its no majoer drama having a crack in the diff housing I drov 9000kms to broome from weipa with mine cracked.
AnswerID: 214651
