radio reception
Submitted: Thursday, Jan 11, 2007 at 11:41
Member - Hurkmagurk (WA)
Does anyone know why my reception is good for FM and lousy for AM? I have just had the head unit replaced so that I may play MP3, but the new one is no better than the old. It seems to be electrically induced "buzz" as it is worse with the motor running (diesel), only just acceptable in the city centre but barely audible a short distance out. The kids at Audiocom/Strathfield etc tell me that a quality GME aerial should improve things ( there goes another $100+). I hope to go half way around the block soon, so I will need very much better quality sound than I currently get, and would value anyone else's experiences.
Reply By: Robin - Thursday, Jan 11, 2007 at 11:49
Could be several reasons , including that it could also be bad on fm but its harder to tell because of way Fm locks in weaker signals so they sound strong.
- as a first step attach 20 ft or so of wire to aerial and note if reception improves markedly on AM
Robin Miller
214655
Reply By: rolande- Thursday, Jan 11, 2007 at 12:39
I fitted a powered signal booster to my alpine head unit and found it instantly killed all AM reception.
Took booster off, AM returned.
While on it did nothing for better FM reception either
hope this helps
Rolande
214669
Follow Up By: joc45 - Thursday, Jan 11, 2007 at 15:30
Hi Rolande,
Yeh, I once bought a power antenna with a booster in its base for both AM and FM. Didn't really improve the FM much, as the radio was reasonable already, but the AM was decimated. Get within 5 kms of an AM transmitter and it would intermod, blending a whole potpourri of assorted AM stations. Great if you want to listen to several stations at once!!
I bypassed the amplifier as the rest of the antenna was what I was really after.
Gerry
474970
Reply By: joc45 - Thursday, Jan 11, 2007 at 12:39
Hi Hurkmagurk,
It may pay to check the continuity of your antenna lead, tho this can be masked by some antennas having a capacitor built into the lead, preventing the continuity check. A brand new antenna I once bought was open-circuit in the lead.
If you've got hash/buzz with a diesel running, the first thing to be looking for would be your alternator. A decent suppressor across its output may help. This is generally characterised by a whine in the hash, which will increase in frequency as the engine is revved. Also inline filters are avail from car audio shops to filter the DC into the radio.
Also, I found when I fitted a diode-type second-battery-combiner at the alternator, it introduced hash (commutating noise from the diodes). Small capacitors across the diodes usually fixes this.
The aircon fan on my Pootrol is atrocious for AM noise.
If the noise is still present when the diesel is not running,
well, hmmm.. Try running a small portable radio in the vicinity, tuning for the worst noise, and wandering around the car. You might find the source then. There may be some other item creating the hash when the Acc switch is on, but engine not running.
Gerry
214670
Reply By: Darian (SA) - Thursday, Jan 11, 2007 at 15:38
From some experience with an allied issue (2 way
HF radio for long distance comms) - all sorts of things (incl. the engine, fridges etc) can provide interference to AM - if it is local and strong, it will push the required incoming AM signal into the background - the further you go from the AM transmitter the worse the problem. Only thing is to kill the source of the interference where possible - we 2 way HF users often have to stop and turn the engine off to comm long distance. RE FM - a wholly different method of transmitting signals - unaffected by the stuff that
ruins your AM signal (UHF 2 way radio ignores it too).
214714
Reply By: Member - John R (NSW) - Thursday, Jan 11, 2007 at 17:08
Also, most radios with AM have a trim pot on the chassis of the radio for setting up the antenna (usually variable between vehicles). The instructions on last one I had (a Pioneer) said to tune a station near a specific frequency (can't remember whether at the high or low end), then fine tune the antenna via the trim pot for best signal.
The one on my previous bike had the same setup.
This might be your problem. You'll need a flat blade jeweller's screwdriver of about 2.5mm to fit the trim pot.
214730
