Removing the radio facia on a Patrol
Submitted: Thursday, Jan 11, 2007 at 16:41
rambll
Hi, I am going to replace my standard CD/Radio player in my 05 ST-L. I having trouble removing the facia. Does anyone have an idea how the facia comes off please?
Reply By: Member - Beatit (QLD) - Thursday, Jan 11, 2007 at 16:47
Presume the same as my 2002 Patrol. From memory all I used was a screwdriver in the two tabs on the bottom of the panel to lift it out.
Kind regards
214724
Reply By: Gob & Denny - Thursday, Jan 11, 2007 at 18:16
2 screws below radio then ease the face off with a small screwdriver its recomended that you wrap the driver in a rag to stop scratches
i had
mine off several times in a short period while fitting a new dvd player and i ended up taking the 4 little clips off so that you didnt have to keep digging with the driver and adding further scratches and just put the clips back on when finished
also went to autobarn and bought adaptors for the aerial and the speaker wiring which made the job so easy the aerial has a funny plug on it
steve
214754
Reply By: Trevor M (SA) - Thursday, Jan 11, 2007 at 18:18
I have taken
mine off and it is easy once you know where the clips are. I have a workshop manual at home that has a good diagram. When I get home later tonight I will see if I can post the pics somehow.
Trev
214756
Follow Up By: Trevor M (SA) - Thursday, Jan 11, 2007 at 22:08
I have saved the page as a pdf but not sure how to get it on this site. email me ..... casnat at internode dot on dot net and I will send it to you.
475081
Follow Up By: rambll - Friday, Jan 12, 2007 at 08:51
thanks for all the advise, i followed it and the facia finally came off, it was pretty tight.
thanks again
475135
Reply By: rambll - Friday, Jan 12, 2007 at 08:52
finally came off following your advise, thank you all.
214871
