TD5 Failure.
Submitted: Thursday, Jan 11, 2007 at 17:23
ThreadID: 41118 Views:5243 Replies:7 FollowUps:19
TD5 Failure.
The oil cooler failed, apparently the core corrodes thin and when they rupture the oil and coolant mix. The engine quickly overheats as the coolant is transformed into an emulsified sludge. The combination of dropping oil pressure, contaminated oil and rising temperatures ensured this engine will never run again.
Apparently there can be some early indications of this impending failure such as droplets of oil in the radiator expansion tank.
To qualify the oil cooler it needs to be removed for an internal inspection and considering the failure outcome it may be better to select an interval and replace it. The vehicle a Defender is 7 years old and traveled 170,000 klm.
Hope this info helps others from learning the hard way.
Spinifex
Reply By: Mike Harding - Thursday, Jan 11, 2007 at 17:34
Ouch!
What's the damage, $12k?
AnswerID: 214738
Follow Up By: Truckster (Vic) - Thursday, Jan 11, 2007 at 18:25
Mate used to work for the Landy dealer down Carrum way, it was $10k for a bare head when they came out.. they replaced a few.
FollowupID: 475015
Follow Up By: Member - Axle - Thursday, Jan 11, 2007 at 19:08
C'm on Truckster!, I know you hate the product, $10k for a bare head ?, maybe off some ruthless landy dealer, sure to do better than that.
FollowupID: 475025
Follow Up By: Utemad - Thursday, Jan 11, 2007 at 20:55
On the AULRO forum there have been a couple mentioned. I think $4.5k for a genuine complete head. A friend of mine has had two Toyota heads done in the last few years. One H and one 2H and both cost $4k for genuine replacements.
FollowupID: 475057
Follow Up By: Truckster (Vic) - Thursday, Jan 11, 2007 at 23:18
Not joking Axle.. thats what the price was.. this was a few yrs ago, tryin to figure out what car he had at the time to figure out what yr it was. I'll ask him tomorrow.
Stewart Websters was the dealer...
FollowupID: 475092
Follow Up By: Member - 'Lucy' - Thursday, Jan 11, 2007 at 23:31
What would it cost if you only gave it a No.1 head job
FollowupID: 475094
Follow Up By: disco1942 - Saturday, Jan 13, 2007 at 22:54
The price was actually $7-8K but that included 5 injectors @ over $1k each. Later heads came without the injectors and glow plugs.
FollowupID: 475463
Reply By: Member - Oldplodder (QLD) - Thursday, Jan 11, 2007 at 18:13
Thanks for the warning.
Even thought I have a Pajero 2.8 ITD, it also has the oil cooler mounted in the block in the water jacket. Same thing could happen. The older 2.5 diesels had the oil cooler externally mounted up near the radiator. Advantagesand disadvantages.
Makes you wonder how important it is to use the right corrosion inhibitor in the water.
Any thoughts about what you used?
Will keep checking the radiator by taking off the cap and if I see oil on the top, will be very suspicious.
Thanks - this problem had not occured to me before now.
AnswerID: 214753
Follow Up By: Member - MrBitchi (QLD) - Friday, Jan 12, 2007 at 08:54
Never heard of it as a Pajero issue :-)
FollowupID: 475136
Follow Up By: Member - Oldplodder (QLD) - Friday, Jan 12, 2007 at 10:09
Getting a little paranoid in my old age, and the old age of the engine.
Got almost 300,000k up now. So thinking of what can go wrong in the next 100,000k. Haven't touched anything in that time except for normal servicing.
The oil cooler leaking into the water jacket never occured to me.
FollowupID: 475151
Follow Up By: spinifex - Friday, Jan 12, 2007 at 14:16
Hi Old Plodder
Vehicle always serviced by dealership using approved Inhibitor/Coolant
Spinifex
FollowupID: 475205
Follow Up By: obee - Friday, Jan 12, 2007 at 15:58
I view dealerships with suspicion since the local stripped my wheel nuts and I needed a four foot bar to remove them.
I use the recommended coolant and change it every forty thou or so using demineralized water.
Owen
FollowupID: 475229
Reply By: mattie - Thursday, Jan 11, 2007 at 19:41
one of the biggest issue i thought was the regular changing of the timming belt (70,000km) if you go any longer you are very very brave, i thought this was the cause of most of the engine failures.
Mattie
AnswerID: 214774
Follow Up By: Utemad - Thursday, Jan 11, 2007 at 20:53
That's the 300Tdi motor which is the engine in the model before the Td5.
FollowupID: 475053
Reply By: Philip A - Thursday, Jan 11, 2007 at 20:54
TD5 has a chain.
Regards Philip A
AnswerID: 214789
Reply By: Eric Experience - Thursday, Jan 11, 2007 at 22:19
Spinifex.
Did the td5 have a copper heat exchanger for a shower? Eric.
AnswerID: 214810
Follow Up By: spinifex - Friday, Jan 12, 2007 at 13:43
Hi Eric.
I see you point, (dissimilar metals) but no galvanic corrosion going on here.
Spinifex
FollowupID: 475198
Reply By: Member - 'Lucy' - Thursday, Jan 11, 2007 at 23:33
Sounds like its time for a GEN III or a 6.5 GM.
Both half the price (installed) of a new TD5 head by Truckies calcuations
AnswerID: 214827
Follow Up By: Bilbo - Thursday, Jan 11, 2007 at 23:47
Lucy,
Great idea - but GM 6.5s have oil coollers as well ;)
Bilbo
FollowupID: 475097
Reply By: Bilbo - Thursday, Jan 11, 2007 at 23:56
There's a variety of "failure indicators" here depending on whether the oil goes through the radiator tubes or through the cooler radiator tank. I would say on most engines the oil would go through the tubes as it's easier to maintain the oil pressure that way. SO if a tube was slowly failing, you'd get a drop in oil level on the dipstick and signs of oil in the engine cooling water. This is based on the oil pressure being higher than the water jacket pressure so the oil goes into the water. Theoretically this should have been picked up long before there was such a catastrophic failure.
If a tube did blow suddenly & catastrophically, the oil pressure would drop very rapidly and the oil pressure warning light or alarm would come on. Stop engine immediately!!
Someone's not been checking things,,,,,,,,
Whose car was it Spinifex? Not yours I hope!
Bilbo
AnswerID: 214834
Follow Up By: spinifex - Friday, Jan 12, 2007 at 14:09
Hi Bilbo
As you say, if it is a weeping oil cooler you can be lucky and pick it up early but if it ruptures on route then the demise is swift and merciless, by the time you notice anything amiss the damage is done.
You know the old saying if your oil light comes on at highway speeds then it is a bit too late.
Not just head damaged, cylinders scored as well.
The repair shop has another TD5 in it that had done the same thing.
Spinifex
FollowupID: 475203
Follow Up By: disco driver - Friday, Jan 12, 2007 at 15:19
So.......that's 2 of how many TD5's on the road,
Compare it with the number of blown Nissan 3 litre Patrols listed on this forum since 1999.
It would be interesting to check on the various Nissan,Toyota and Landrover sites as well to compare numbers of stuffed motors reported per make.
Disco
FollowupID: 475218
Follow Up By: GQ_TUFF - Friday, Jan 12, 2007 at 18:30
"So.......that's 2 of how many TD5's on the road"
Thats about right, there would be about 2 TD5'S on the road. The rest on tow trucks, or in the shop!!!
LOL
Cheers Stefan
(it is phriday funny)
FollowupID: 475256
Follow Up By: MT - Friday, Jan 12, 2007 at 23:09
Funny Stef,
I laughed until I stopped,
MT
SII TD5 Disco
Patrol Recovery Vehicle
FollowupID: 475322
Follow Up By: pilbaradisco - Saturday, Jan 13, 2007 at 12:17
A least the LR does twice the KM"s of most 3.0l Nissans! ;-P
Glen.
FollowupID: 475381
Follow Up By: GQ_TUFF - Saturday, Jan 13, 2007 at 12:21
yes that is true they to travel more KM than most nissans......but not under their own power!!!! Km's on a tilt tray don't count!!!
Cheers Stefan
FollowupID: 475384
