Where do you fit it
Submitted: Friday, Jan 12, 2007 at 18:16
ThreadID: 41150 Views:2673 Replies:9 FollowUps:7
Have just picked up a 2004 120series TD Prado and cannot for the life of me figure out where to fit the UHF CB. It is an older model Uniden and hust to bulky. Think it is a case of having to ditch it and buy one of the newer smaller models possibly with a detatchable facia.
Anyone had this problem and if so do you have any suggestions on where the older one can fit or did you have to upgrade and if so, to what make and model.
Cruiser
Reply By: Craigww2 - Friday, Jan 12, 2007 at 18:39
I upgraded to a GME TX3400 when I got my LC100. It was either that or install a roof console, and the roof console might not have been deep enough to house it anyhow. I thought the price of a roof console was similar to the radio so I sold my old one on ebay and used the proceeds to go towards a newer smaller one.
Craig
AnswerID: 214961
Reply By: Taz & Milka-Queanbeyan - Friday, Jan 12, 2007 at 18:45
If you do go to another unit I have a suggestion. I purchased a Uniden GPS105 and it fits nicely into the empty space under the ashtray in a 90 series - don't remember how similar the 120 and 90 are internally.
Cheers ... Taz
AnswerID: 214963
Reply By: Member - Boo (ACT) - Saturday, Jan 13, 2007 at 01:02
Morning Cruiser... (just)
When I was setting my radio up I bought a second hand 'Syntrx' radio off ebay and was able to mount my radio under the drivers seat, not sure on the space under yours as I have a Patrol but couldnt be happier with it. The Syntrx radios have all the controls on the microphone (volume, scan, chanel selection) . Another great thing about the Syntrx is they put out around the 25w unless they've been modified, which gives fantastic range. You can pick them up off ebay for around the $120 mark generaly.
Hope that helps,
Boo.
AnswerID: 215046
Reply By: Member - Pesty (SA) - Saturday, Jan 13, 2007 at 09:42
Muddy has a 120, and he mounted his Icom uhf in the console box, works good and is out of site when not in use.
Cheers Pesty
AnswerID: 215071
Follow Up By: Member - Cruiser (NSW) - Saturday, Jan 13, 2007 at 09:48
I thought of that, but havent figured out how to have the mike outside the console box and still have the lid closed.
Some pictures would be nice if thats possible.
FollowupID: 475360
Follow Up By: Muddies Doe(Trippn) - Saturday, Jan 13, 2007 at 22:05
Hi Cruiser
Muddy is replying to you.........but from me........I don't like it in there with the lid up. We use a towel to pad the armrest otherwise it is so hard on your arms after a while.
Cya
FollowupID: 475454
Follow Up By: Muddy doe (SA) - Saturday, Jan 13, 2007 at 22:09
Hiya Cruiser,
Yes I still have this setup and it works well as I only use the UHF when out of the city. It is simply a case of having the lid up when UHF is in use and draping the mic out of the box. When in town the only indication that I have a UHF at all is the antenna on the roof rack.
The other night I drove a Country Fire Service 120 Prado and it had 3 radios all installed in that box. The lid of the box had been removed completely.
I would like to move the radio to the dash one day though as it can be a pain in the butt driving with that lid open at times when in convoy or on sand dunes. Makes it more difficult to have that arm to arm contact with the significant other in the co-pilot seat too!!
The radio bracket is screwed to the passenger internal sidewall of the console bin and the power and antenna leads come up from underneath (drill hole in floor of bin). It was a pro install so I can't give that much more detail!!!
Muddy
FollowupID: 475456
Follow Up By: Member - Cruiser (NSW) - Saturday, Jan 13, 2007 at 22:17
Pesty/Muddies Doe/Muddy Doe,
Thanks for the suggestion of fitting the radio inside the centre console box, but from the replies, it sounds to me as though having to have the lid open would be a bit of a pain in the ar$e.
Will look at the possibility of fitting it into the upper part of the glovebox as suggested by Alan W.
If thats the way to go, then all i have to buy is the mic extension cable instead of a new radio.
FollowupID: 475457
Follow Up By: Muddy doe (SA) - Saturday, Jan 13, 2007 at 22:20
Yeah,
I looked at that as well but if you are solo it makes it a real PITA to change channels or adjust anything else on the unit while driving. OK if you have a co-pilot to do it for you though!
Muddy
FollowupID: 475459
Reply By: Alan W - Saturday, Jan 13, 2007 at 21:59
Hi Cruiser,
I have the Grande model and my GME tx3200 is on the top shelf inside the glovebox.
An extension lead for the mike is used to locate it near the gear shift.
I have the volume turned up full blast and its fine to be heard with the glovebox closed. The installer gave me a extension speaker just in case I wasn't happy, but I am.
regards
AnswerID: 215162
Follow Up By: Member - Cruiser (NSW) - Saturday, Jan 13, 2007 at 22:06
Thanks Alan W, I will look at it tomorrow. Didnt think of there.
I assume that the extension lead is something that is commercially available.
FollowupID: 475455
Follow Up By: Alan W - Saturday, Jan 13, 2007 at 23:07
Glad to be of help Cruiser,
The extension lead is, I assume, commercially available. I had the radio professionally installed, so cant really say, but it looks as if its commercially made.
If you plan to 'fiddle' with the radio whilst on the move, it may be an idea to mount the radio in the console and have a extension mike outside so you can have the lid shut.
In my opinion the volume from the speaker in the closed glovebox is fine. From a closed console, which is closer, should also be fine. Try before going out and buying a extension speaker.
As someone said, the driver cant really fiddle with the radio if mounted in the glovebox but I don't fiddle with it, I keep it to the one agreed channel, and the volume is near full blast anyway.
Works for me.
FollowupID: 475468
Reply By: disco1942 - Saturday, Jan 13, 2007 at 23:05
Have you looked at one of these to mount the radio.
www.consoles.com.au/Toyota_Prado9_dash.htm
or Site Link
I have a dash pod in my Disco Td5 and it makes for a very neat installation.
AnswerID: 215173
Reply By: snow - Monday, Jan 15, 2007 at 13:22
I had the some woes when transferring my old Uniden from my old Lux to my 03 Navara. I had it mounted on th etransmission tunnel in th elUx and there was sufficient leg room but the newer vehicles seem to have less space all the time.
In the end I did as Boo did and mounted it under the seat with mic mounted on that plastic crap that sounds gear stick.
AnswerID: 215416
Reply By: JJ - Monday, Jan 15, 2007 at 16:30
Pro fitting unit wanted to cut holes, fit brackets etc. as nowhere in our Pathy to fit our philips uhf. No way, we say! So I sewed velcro on both ends of a web strap and with rubber matting under & over unit, and strap fed through lid before closing, we strapped it on top of the centre console! Mike sits under handbrake (of vehicle, that is!) also on matting. It plugs into rear cig-lighter socket & Pro only had to wire in arieal.
Works a treat for us!
AnswerID: 215460
Reply By: Member - Norm C (QLD) - Monday, Jan 15, 2007 at 17:05
You can always make your own roof console. I made mine for around $70.
If interested, I've written up some instructions for others who wanted to give it a go.
AnswerID: 215466
