shock absorbers
Submitted: Friday, Jan 12, 2007 at 21:35
ThreadID: 41158 Views:2768 Replies:4 FollowUps:1
Whats a good shock to fit to a hjz 75 ute with alum body carring camping gear fridge ect heavy duty springs towing kk trailer.
ome
ranchos
desert fox
koni
gabriels
I have ome on now but things change what was good may now be superceded.
Reply By: Crackles - Saturday, Jan 13, 2007 at 11:41
OME are an ordinary shock that do an average job. If they work for you I'd say don't bother changing them. If you want something a little longer lasting with better handling the adjustable (& rebuildable) Koni's are a quality unit & I've found them to work very well in both the high country & outback. Bilsteins probably are a higher performance shock again with their variable valving giving excellent handling & the Fox shocks are in a class of their own & are really intended for competition use although I've seen them work very well on extreme trips like the Madigan crossing over the Simpson. Although I've had no direct experience with the other 2, I have been told by those 'In the know' they are nothing special. Another shock probably worth a look at are Ridepro, a big bore heavy duty unit that is surprisingly well priced.
Cheers Craig.........
HZJ105 Koni shocks. (over 250,000 km)
AnswerID: 215090
Reply By: Sign-man - Saturday, Jan 13, 2007 at 12:51
OME
AnswerID: 215099
Reply By: Member - Doug T (W.A) - Saturday, Jan 13, 2007 at 17:28
Yep I say too OME
the ride and handling of a 75 series is like ....unbelievable,
I was warned away from series 2000 TJM by a certain shop South of Townsville
AnswerID: 215121
Follow Up By: acdc - Saturday, Jan 13, 2007 at 17:49
Doug T
I don'y why! a XGS shock will outlast and outperform a OME anytime,middle of the road average shocker.
FollowupID: 475420
Reply By: Member - Phil G (SA) - Saturday, Jan 13, 2007 at 19:36
I put OME on the 79series 2 years ago after a couple of friends had them on their 78/79's for over 100,000k without a problem. They also make very good leaf springs. I've only done 30,000k on them - no issues, but that 30k has been pretty rough.
I personally would steer away from anything made in the USA, Mexico or Brazil. Just my bias after seeing a few failures.
AnswerID: 215141
