tyres/wheels
Submitted: Monday, Jan 15, 2007 at 13:28
porkhunt
what are the biggest tyres/
wheels that I can put on a 05 Rodeo without having to start modification?
Reply By: Member - Peter D M - Monday, Jan 15, 2007 at 13:43
with no modifications 31x10.5 r15 or 265/70r16 fit with no problems. speedo gets within 1km at 100 accurate.
regards peter
215424
Follow Up By: Member -Signman - Monday, Jan 15, 2007 at 13:52
Hey Peter
Appreciated the description as a 'Murdoch' canopy!!! Is that now the generic description of the canvas type canopy on utes etc???
475706
Reply By: Member - Davoe (Nullagine) - Monday, Jan 15, 2007 at 13:47
i assume your standard tyres are 265x70x16 ht tyres. You can fit 265x75LT tyres and even they will rub a bit but not so as to worry but that is it
215426
Follow Up By: Member - Peter D M - Monday, Jan 15, 2007 at 14:11
original tyres are 245x70r16.
265x75r16 which i use are 50 mm taller and can only be used with a
suspension lift and mud flap trim. standard rims are not an issue as they were with the r9.
regards peter
475711
Follow Up By: Member - Davoe (Nullagine) - Monday, Jan 15, 2007 at 14:20
Hmm the glx-r at work came with 265x70 and now has bridgstone 265x75 which rubs ever so slightly only sometimes
475712
Follow Up By: Member - Peter D M - Monday, Jan 15, 2007 at 14:34
checked the manual and 245/70 standard. not sure what model you are talking about as glx-r not mentioned in
mine.
as yours arrived with different tyres maybe the
suspension had been done as
regards peter
475714
Reply By: Member - Charlie M (SA) - Tuesday, Jan 16, 2007 at 18:41
05 Rodeo has load index of 111 S. Can not go below 111 in load index, 31 10.50r15 is load index 109. I dont think 15inch will clear disc brake calipers.
Charlie
215714
