What is the best camp stove?
Submitted: Tuesday, Jan 16, 2007 at 12:25
ThreadID: 41257 Views:35919 Replies:13 FollowUps:11
hi all,
my current camp stove (cheapo gas Jackeroo) is driving me nuts.
im ready to INVEST in a stove, not just buy one.
my current issues are
1. cant have low flame without blowing out
2. takes a long time to boil water
3. ive replaced the knobs each year (damaged during transit)
4. takes a long time to clean
5. the two burner doesn't hold two medium/large pots.
6. flame can blow out in mild wind
i require it for outdoor use. i also dont care if its dual fuel or gas.
any advice (including makes and models) will be appreciated.
Thanx in advance.
Gav
Reply By: Mike Harding - Tuesday, Jan 16, 2007 at 12:26
Coleman - gas or dual fuel.
AnswerID: 215633
Follow Up By: Shaker - Tuesday, Jan 16, 2007 at 14:28
Hear hear! No contest, I lean towards gas though, uses very little.
FollowupID: 475934
Reply By: Member - Teabag (Queanbeyan) - Tuesday, Jan 16, 2007 at 12:52
I just bought the new Coleman Fold and Go and it is excellent. Two burns at 10 000btu and only half the size. Uses the small disposable Coleman gas can or standard Gas bottle. If space is an issue then this is what I recommend......
AnswerID: 215635
Follow Up By: Middle Jeff - Tuesday, Jan 16, 2007 at 20:09
I got one of these before Christmas and I also got a carry bag for it, I was only going to use it for the odd trip but now I only use it, when it opens up it is huge and it never blows out.
Have fun
Craig
FollowupID: 476010
Reply By: mfewster - Tuesday, Jan 16, 2007 at 13:13
We have had several gas stoves over the years, including a new fancy model with a griller I built into the camper. But the Coleman easily outperforms them all. Have a look at the burners on the Coleman. They are very different design and that seems to be the secret. They need a special combined regulator/hose (if the gas model). The only downside to the Coleman gas is that if you have a problem with the regulator, it has to be replaced with the special Coleman hose/regulator. I have seen a couple of people get stuck when the regulator had a problem. On the other hand, we have had ours for about 15 years and still have the original hose/regulator and have had absolutely no issues. Just take a bit of care in packing the hose/regulator away.
AnswerID: 215639
Follow Up By: RosscoH - Tuesday, Jan 16, 2007 at 13:19
Coleman or Coleman or Coleman, any one of the three and you will have a good stove.
FollowupID: 475924
Reply By: vcbb - Tuesday, Jan 16, 2007 at 13:29
I still have my original two burner, but havent used it for ages. I am currently using a small burner called a Pocket Rocket and it fits onto the small gas canister. It boils water very quick and also cooks.
I am now upgrading to a new unit called JetBoil , link is http://www.jetboil.com/Products
Takes very little room and doesnt have any of the problems you listed.
This is the beez neez and I now find because I use fluro's I dont need gas bottles etc (hate mantles)
AnswerID: 215641
Reply By: flappa - Tuesday, Jan 16, 2007 at 13:49
This is a common discussion.
A search would find many many threads on this subject.
In general terms though , give the High pressure stoves the big heave hoo , and invest in either a low pressure stove or dual fuel.
Colemans seem to always get a very good wrap , and I personally use a Low pressure twin burner Coleman.
I have never really used a dual fuel as I find them fiddly , but a lot here think they are the best ever.
Your choice , but either will work SUBSTANTIALLY better then what you currently have.
AnswerID: 215644
Follow Up By: Ron173 - Tuesday, Jan 16, 2007 at 14:03
Flappa, what do you classify as a high pressure stove? one that runs from a 9kg bottle?
I have all the issues with my stove too, and would be interested in following this thread as it develops, as I really need to get a better one as it has no control and takes ages or blows out etc.
Rgds
Ron
FollowupID: 475928
Follow Up By: Robert - Tuesday, Jan 16, 2007 at 14:08
Would totally agreed with Flappa, we changed from a high pressure to a coleman low pressure and wish we had changed years ago. You can turn them down to a simmer easily. Turning one burner on, off or to a simmer does not effect the other burner at all if it is in use. I personally was put off buying a dual fuel as I was not comfortable with the idea of burning unleaded fuel due to possible health risks.
FollowupID: 475931
Follow Up By: Mike Harding - Tuesday, Jan 16, 2007 at 14:10
It's a stove which runs directly from the gas bottle without a regulator. So they'll just be a straight through pipe which connects bottle and stove. They are also very poor in low temperatures - won't produce much heat - anything below about 6 or 7 deg C.
The low pressure stoves have a regulator (bulky thing on the end of the pipe) and are not much more expensive but perform _so_ much better in all respects.
Mike Harding
FollowupID: 475932
Follow Up By: flappa - Tuesday, Jan 16, 2007 at 14:51
As Mike says , a High pressure stove runs straight from the Bottle to the stove. Size doesn't matter.
The Low pressure stoves have a regulator in the hose (like most backyard BBQ's).
I bought mine specifically for use in my CT as low pressure doesn't suffer from flareups , like HP ones do. A big No NO is a canvas CT.
The other benefits are the far better flame control , and heat.
Mine also has a Piezzo Lighter for the burners.
I have had it about 4 years and cost me , from memory , about $120.
FollowupID: 475941
Reply By: looking_4_BJ42 - Tuesday, Jan 16, 2007 at 14:43
Go the duel Fuel Coleman.
Can have extremely low flame without blowing out, is extremely hot, hotter than gas cooker at home, Can use engine degrease on it and hose it out, has holes for water run off.
I use it for roasts using a 9qt cast iron pot full of meat and veg, i also use a BBQ hotplate on it, have absolutly no problems with doing this, they are extremely rugges and can take alot of weight. They can easily hold 2 large pots.
Once you get the stove you can than get the latern, which is extremely bright and transportable. And than never have to carry gas again, yippeeee
Best this is you always know how much fuel you have left, dont have to carry 2 gas bottles incase one runs out.
Get the Duel Burner powerhouse, i think model is 414.
Had mine for 6 years, mate has had his for 5 years. not a problem. Yhe ultimate cooker on the market, and with the later a unstoppable combination of light and cooking. Best thing about the latern is the fuel is contained in the latern and is therefore very transportable, weighs 1 kg or so. Also when duel fuel laterns tip over they dont flare up like the gas ones do, they just continue burning normally.
These items are a little bit more expensive but if your a keen camper, you cannot go wrong!!!!
They are my favorite bit of camping kit i own.
AnswerID: 215659
Follow Up By: Ron173 - Wednesday, Jan 17, 2007 at 09:20
What sort of $ in the dual fuel stove n lantern please?
Ron
FollowupID: 476141
Reply By: Wayne M(QLD) - Tuesday, Jan 16, 2007 at 19:01
Hi kingswoodwagon
Mate realy have a look at the Coleman duel fuel been using both the stove and light for about 5yrs and going strong or if fuel stove's ain't your thing look at the coleman gas as in post's above sound like there good too
wayne
AnswerID: 215724
Reply By: FZJ 80 - Tuesday, Jan 16, 2007 at 19:56
Kinsgswoodwagon.
5 Years with Coleman 3 burner gas. LH burner 15000BTU ball tearer, Absolute beauty. Go Coleman they're great.
AnswerID: 215729
Follow Up By: Member - Crazy Dog (QLD) - Tuesday, Jan 16, 2007 at 21:04
Coleman...
Grrr!!!
FollowupID: 476031
Reply By: Brew69(SA) - Tuesday, Jan 16, 2007 at 19:59
Coleman Dual fuel...........game over.
AnswerID: 215731
Reply By: hoyks - Tuesday, Jan 16, 2007 at 20:49
I tried the Jackeroo high pressure option for years, but found it easier to cook on a camp fire most times. With the continuing drought and lack of firewood at a lot of sites I thought it was time to upgrade.
I have just lashed out and ordered a Coleman 'Powerhouse' 2 burner stove and am waiting for it to arrive. I also have a dual fuel twin mantle lantern. It has been going strong for 10 years now and only on it's third generator, so I hope the stove will work half as well and I will be happy. I don't usually use unleaded but rather shelite. I stock up when it is cheap at Woollies or slip a bottle into the trolley when shopping rather than buy it at the camping shops. It works out much cheaper..........................., especially when my wife is paying.
AnswerID: 215747
Reply By: chisel - Tuesday, Jan 16, 2007 at 21:28
Coleman "guide series" 3-burner gas. LH burner is 15000 BTU (as mentioned above). Absolute cracker! Better than my gas stove at home! Pity they are a bit bulky. Also it has some rust on the case but still works great.
AnswerID: 215755
Reply By: Dave from P7OFFROAD Accredited Driver Training - Wednesday, Jan 17, 2007 at 07:17
ummm Coleman!
AnswerID: 215816
Reply By: neptune - Wednesday, Jan 17, 2007 at 09:30
Just to throw a spanner in the works, a lido junior is a great stove and also has a grill underneath. It is bulkier than the coleman, has brass burners and will simmer very well. I do own a coleman 2 burner lp as well. Both are great stoves.
AnswerID: 215841
Follow Up By: Moggs - Wednesday, Jan 17, 2007 at 10:55
Yep, a vote here for the Lido - great stove - a bit exy though at around $260. Getting one in our new camper and the missus is looking forward to using the griller for toast and throwing away that mesh toaster frame!
FollowupID: 476150
Follow Up By: flappa - Wednesday, Jan 17, 2007 at 12:02
I was looking at one of these when I bought my CT because of the griller.
Was told the griller is a bit ordinary and then because of cost , decided to go Coleman.
Never got to check out the Lido myself.
FollowupID: 476160
