leaf springs
Submitted: Tuesday, Jan 16, 2007 at 23:35
ThreadID: 41292 Views:1743 Replies:1 FollowUps:0
hi all ,i have been lucky enough to have been given some new leaf springs from a 75 series landruiser ute [front] and wondered if they where compatible with my 89 landcruiser 60 series diesel . Thanks
Reply By: Tony - Wednesday, Jan 17, 2007 at 10:42
The eye size is the same, but you will have to check the length. They are two differsnt part numbers.
If for some reason that the main leaf is to long/short you can always pull the spring pack appart and re-build it using the old main leaf and the new spring leaves and build it up to suit the weight of your front end. You will most likely need a new centre bolt.
AnswerID: 215853
