Holden alternator, on a Nissan ?
Submitted: Wednesday, Jan 17, 2007 at 05:01
ThreadID: 41295 Views:2985 Replies:2 FollowUps:7
I have heard that this can be done,,,
Is there a kit ??
or is back to the old inginuity, you know someone cuts out a plate and can adapt it to take the far cheaper holden alternator ?
Any thoughts,,
Pud and Barb as I know hat you guy's got caught
Cheers Bucky
Reply By: Truckster (Vic) - Wednesday, Jan 17, 2007 at 07:22
which Holden? Which NIssan?
AnswerID: 215817
Follow Up By: Member - Bucky (VIC) - Wednesday, Jan 17, 2007 at 09:53
Truckster
I heard that it was an alternator off a VP commodore, ( 70 - 90 amp not too sure ) and an adapter plate was set up to go onto the 3.0 TD ( ZD30 ) engine.
Now how true it is is yet to be established, but if so, it makes a mockery out of the price that Nissan charge
Like you, I will want to see it too,
Cheers Mate
Bucky
FollowupID: 476144
Follow Up By: mike w (WA) - Wednesday, Jan 17, 2007 at 10:57
excuse my ignorance, but arent diesel alternators designed to provide vacuum for the brakes, or is that only on certain models??
Not having a go or trying to be smart, just 'expanding my supply of UFI'
FollowupID: 476151
Follow Up By: Leroy - Wednesday, Jan 17, 2007 at 10:59
Only on certain models.
Leroy
FollowupID: 476152
Follow Up By: Truckster (Vic) - Wednesday, Jan 17, 2007 at 11:12
wouldnt almost anything with an adapter plate fit?
theres a difference in fitting and adapting ;)
FollowupID: 476154
Follow Up By: Truckster (Vic) - Wednesday, Jan 17, 2007 at 11:13
sorry difference in fitting and working
FollowupID: 476155
Follow Up By: mike w (WA) - Wednesday, Jan 17, 2007 at 12:13
Thanks Leroy
FollowupID: 476161
Follow Up By: RosscoH - Wednesday, Jan 17, 2007 at 15:00
What does a Holden Alternator cost? It would have to be cheap to make it worthwhile buggering about to make it fit,I put a Brand new Nissan one on a ZD30 for $370.00.
FollowupID: 476201
Reply By: Member - Glenn D (NSW) - Thursday, Jan 18, 2007 at 23:55
Hows it going Bucky,
When I had an early model Pajero , I found original mudflaps V expensive , Went to Clarke Rubber and sorted things out , Noone knew the difference !
I dont think its any benefit if you have to mess around with " half assed" adapter plates and non standard installations if you only save like 100 dollars , it may end up being a far greater pain in the long run.
Glenn.
AnswerID: 216286
