Good auto electrician in Melb?
Submitted: Wednesday, Jan 17, 2007 at 21:33
ThreadID: 41331 Views:2897 Replies:6 FollowUps:13
Hi all, a quick one. Can anyone recommend a good honest auto leccy in Melbourne? Much preferably somewhere inner east / sth east.
Reply By: luch - Wednesday, Jan 17, 2007 at 22:08
Too bad your in the East
I know a great one in the West mobile auto elec works on mostly trucks
AnswerID: 216026
Follow Up By: Member - Julie P (VIC) - Thursday, Jan 18, 2007 at 20:04
Alex Auto Electrical - cochranes road moorabbin
FollowupID: 476562
Reply By: Rock Crawler - Wednesday, Jan 17, 2007 at 22:14
Clayleigh motors , James st Clayton , ask for Con , tell him your a freind of Eric Christopher , that way l get my 10% lol
AnswerID: 216028
Follow Up By: Member - Tonester (VIC) - Thursday, Jan 18, 2007 at 11:18
Hi Eric. Thanks mate. Is that the guy you mentioned once before to me? Great mechanic. From memory was on Malvern rd, or is this a different bloke?
FollowupID: 476433
Follow Up By: Rock Crawler - Thursday, Jan 18, 2007 at 20:08
Thats Anthony at Mobil Prahran, Yes he is a great mechanic , trained by the best lol Me
The Auto elec , is another bloke , works out of Clayleigh motors , a very good auto elec. Con is his partner , but give him a call and he will get you sorted , good mate of mine also .
FollowupID: 476563
Follow Up By: Member - Tonester (VIC) - Thursday, Jan 18, 2007 at 21:27
cool mate, thanks
FollowupID: 476586
Reply By: martz8 - Wednesday, Jan 17, 2007 at 23:48
Try Spalverio (Not sure on Spelling) or Viking fleet service.
Hope this helps.
Marty
AnswerID: 216055
Follow Up By: Member - Tonester (VIC) - Thursday, Jan 18, 2007 at 11:23
Thanks Marty
FollowupID: 476436
Reply By: annez - Thursday, Jan 18, 2007 at 06:52
Alan at Berwick Auto Electrics. Excellent work.
AnswerID: 216083
Thanks annez
FollowupID: 476437
Reply By: Truckster (Vic) - Thursday, Jan 18, 2007 at 08:06
What do you need doing Tony??
Speak with Alan at Outback accessories in Seaford... he will put you right.
AnswerID: 216089
Follow Up By: Member - Tonester (VIC) - Thursday, Jan 18, 2007 at 11:21
Got my ongoing issue with the radiator. Toyota told me to go to hell, which has yet to be settled, cause I don't know the way. Want to see if there is indeed an elec prob in the car, and also get the old one tested. Away over the last 3 weeks I had to put 3 full cups of water in the reserve, there is a leak still.
FollowupID: 476434
Follow Up By: Rock Crawler - Friday, Jan 19, 2007 at 01:03
im confused , you need a auto elec , becase your loosing water ?
FollowupID: 476632
Follow Up By: Member - Tonester (VIC) - Friday, Jan 19, 2007 at 13:36
Overheated badly a week prior to xmas, no radiator water. I posted some stuff on this then, cause when Toyota "fixed" it a day later, they said the cause was electrolosys in the radiator causing the hole.
Over xmas in the Otways, I was keeping an eye on the newby radiator, and the fluid in the reserve kept dropping away, and I could see dribbles occasionally underneath.
Back to Toyota yesterday when we got back from hols and got them to check the new install and fix the leak whatever it was. Which they did for free - replaced the three clamps, 2 top and 1 bottom, and full flush of the fluid again.
However, back to the old radiator that got replaced, it was only 22mths old and had sprung a leak - few leaks actually. My understanding is that the radiator can die from external abuse/rust, internal wrong fluid, or stray current.
Toyota after some serious "discussion" with them tell me it was external abuse from mud, and that is what their radiator specialists had said. I separately took the old radiator to Toyotas own specialist and asked them to pressure test and comment. They said it is very likely an incorrect fluid or stray current issue due to where the leaks were appearing - so different story to what Toyota are saying.
Now, I got a statement from their radiator specialist saying it is unlikely mud. So I need to get stray current and earthing check to rule out that problem (last I looked there was 200mV potential b/w the radiator fluid and the battery terminal, so it is possible). If it checks out ok, that leaves a fluid issue so I can go Toyota for the cost (the aim of the game here, its near $800) since they are the ones who fully maintained the vehicle for the last 2.5 yrs.
Bottom line also, if I got an elect prob, the new radiator apparently will suffer the same fate just as quick anyway.
FollowupID: 476769
Follow Up By: Rock Crawler - Friday, Jan 19, 2007 at 19:14
Earth the radiator out , no more problem
FollowupID: 476890
Follow Up By: awill4x4 - Friday, Jan 19, 2007 at 23:46
Sorry Eric, earthing the radiator is exactly the wrong way to go. Have a look at all modern cars and the way the radiators are fitted and you will see there is no earthing to the radiator at all.
On the custom radiator I built for Mike next door on his 460 cube F100 he had a stray current problem we couldn't find. We tried everything and then I suggested he independently mount the radiator with rubber grommets so there was no earth pathway to the radiator at all and the problem was solved.
Regards Andrew.
FollowupID: 476967
Follow Up By: Member - Tonester (VIC) - Saturday, Jan 20, 2007 at 10:54
mmm. all this stuff is beyond me. Is why I want to get a good auto elect to have a look.
FollowupID: 477027
Reply By: Member - John - Thursday, Jan 18, 2007 at 10:51
About Auto Electrix Pty Ltd
Factory 5, Commerce Drv
Hampton Park
VIC, 3976
Australia
9799 7977
No affiliation, happy customer.
John and Jan
AnswerID: 216122
Thanks John
FollowupID: 476438
