drop down fridge slide
Submitted: Friday, Jan 19, 2007 at 14:11
ingo57
Gday all
There is a fridge slide that I have seen somewhere??? that extends out as normal, but when it gets to the end of its travel, it swivels downward about 40 degrees. Ideal for 40 litre engels when installed on top of a draw system which allows you to see in the fridge a lot better.
Has any one got one of these, how do they rate and where can I get one??
Any help would be appreciated
Reply By: Member - Craig D (SA) - Friday, Jan 19, 2007 at 14:18
Hi ingo57, I have one of these. Got it through Candy Canvas at
Tintinara.
I find
mine indispensable, as when I have my camper off the Patrol's tray it's a bit too high for me to look into the fridge and impossible for the wife without the tilt mechanism. About $140 from memory.
Regards,
216424
Follow Up By: Truckster (Vic) - Friday, Jan 19, 2007 at 15:17
$140, is that the complete slide nad everything or just an attachment?
476811
Reply By: Steve63 - Friday, Jan 19, 2007 at 15:01
We have two of them. I think they are a normal fridge slide with a custom base. We also got ours from Candy Canvas. They use them in their slide on campers because the top of the fridge is too high unless you are six foot and my wife is five foot. They are a great idea.
Steve
216436
Reply By: 4wdNewbie - Friday, Jan 19, 2007 at 15:17
What kind of mechanism allows the fridge to swivel?
216440
Follow Up By: Member - Craig D (SA) - Friday, Jan 19, 2007 at 15:20
No swivel - just tilt.
!MPG:11!
476814
Follow Up By: 4wdNewbie - Friday, Jan 19, 2007 at 15:32
Aha. Thanks mate.
476827
Reply By: Member - Craig D (SA) - Friday, Jan 19, 2007 at 15:18
Trucky, that's just for the tilt mechanism...you simply bolt on whatever slide you want to the top of it.
216442
Follow Up By: Truckster (Vic) - Friday, Jan 19, 2007 at 16:14
No worries.. cheaper to buy one of them $40 steps that slide into the towbar thing where tounge goes.
476848
Follow Up By: Member - Craig D (SA) - Friday, Jan 19, 2007 at 16:25
Trucky, I don't think that would help me in my case any LOL
476851
Reply By: Shaker - Friday, Jan 19, 2007 at 15:31
I think Crazie has one that he made himself.
216449
Follow Up By: mike w (WA) - Friday, Jan 19, 2007 at 15:44
Didnt geocacher make one also. Im sure he had some lnks to some plans he had put together
476834
Follow Up By: Kev M (NSW) - Friday, Jan 19, 2007 at 16:11
Mike,
Your correct
Geocaher (Dave) designed and the plans are on his web check his profile out for details.
Kev
| Russell Coight:
476846
Follow Up By: Truckster (Vic) - Friday, Jan 19, 2007 at 16:13
and awill4x4 and about a dozen others lol...
476847
Follow Up By: GaryInOz (Vic) - Friday, Jan 19, 2007 at 16:40
From the looks of it you could use a normal slide mounted on an alloy plate with a hinge at the (vehicle) rear of the plate and a short bungee cord limiting strap to stop the front of it lifting too far, using the weight of the fridge itself to tilt the mechanism when it is pulled out.
Alloy sheet, 600 x 800 x 6mm cut in half (600 x 400 tilt plate and 600 x 400 base to screw down to top of drawer system)
Large piano hinge or two door hinges (between plates)
Slide mechanism base (mounted on tilting base)
1 metre of bungee cord for limiting strap (between baseplate and tilting plate)
rubber buttons (to stop plates rattling together)
Guessing total cost ~$40-50, not including slide mechanism.
476855
Follow Up By: mike w (WA) - Friday, Jan 19, 2007 at 16:49
As you say, wouldnt be too difficult, might have to take a trip to bunnings!!
476858
Reply By: awill4x4 - Friday, Jan 19, 2007 at 23:37
This is the one I built for my Engel 40 litre fridge.
Mine is a bit different in that I can unlock the tilting mechanism (the 2 spring loaded stainless steel rods running parallel with the fridge base) from the rear of the car rather than having to reach past the fridge and unlock from there.
Regards Andrew.
216559
Reply By: BUGGER ME - Saturday, Jan 20, 2007 at 00:09
hi ingo57
whats you email , i think i have got the the one you are after, will send it to you
bugger me
216570
Follow Up By: ingo57 - Saturday, Jan 20, 2007 at 08:34
gday bugger me
chris@torchpublishing.com.au
look foward to it
477004
Reply By: ingo57 - Saturday, Jan 20, 2007 at 08:37
Thanks everyone for your imput
As always, much appreciated
216590
Follow Up By: Wisebyname - Saturday, Jan 20, 2007 at 10:48
Hi Chris
Do you know a G Waud or Alison
Andy
477026
Follow Up By: ingo57 - Saturday, Jan 20, 2007 at 18:09
Gday Andy
Not that I can recall mate, but then again I am hopeless with names.
Why do you ask?
477083
