02 GU td42 couple of questions
Submitted: Friday, Jan 19, 2007 at 15:12
ThreadID: 41394 Views:2114 Replies:4 FollowUps:5
Hi all,
Today I greased up the uni's and front and rear shafts and would like to know if there are any other nipples to grease?
It is a bit of a tight squeeze under the Nissan :)
In my old Jeep there were several more places needing to be greased.
Also my front shaft has about 1/4 of a revolution free play?
Is this normal?
Thanks in advance Chris.
Reply By: Truckster (Vic) - Friday, Jan 19, 2007 at 15:15
funny that.. the GU has heaps less nipples than the GQ.. I too have gone searching, and found little. there was a post on the patrol forum while back, but cant find it.
will keep lookin
AnswerID: 216439
Follow Up By: Member - Roachie (SA) - Friday, Jan 19, 2007 at 15:24
Yep, at least the GQ had small bolts in the steering knuckle joints which (when I owned it) I promptly removed and screwed-in nipples. The GU doesn't even have the little bolts and the steering joints are non-serviceable.
The front tail shaft is supposed to have that free-play (unless you've manually locked the auto hubs, in which case the shaft won't budge.....or shouldn't!!!).
I've replaced the auto hubs with part-time, manual locking jobs. When these are in the "FREE" position the front shaft can be freeely rotated as much as ya like.
FollowupID: 476816
Follow Up By: Cobes - Saturday, Jan 20, 2007 at 19:01
Hi Truckster,
thanks for your comments.
Just wondering if you could let me know the lubricants that you use for your td42 engine, gear box, diffs and transfer case.
I would like to do my own changes rather than pay for everything to be done.
Chris.
FollowupID: 477095
Follow Up By: Truckster (Vic) - Monday, Jan 22, 2007 at 14:27
Engine : Shell Rimula X
Diffs: rear: penrite LSD
Gearbox: ATF (auto)
FollowupID: 477474
Reply By: Member - Toytruck (SA) - Friday, Jan 19, 2007 at 15:22
I know mine ain't a Nissan but the cruizer only has nipples on the shafts also. We are in the era of throw away items. I remember on my parents old Holden you could grease just about everything....not anymore.
Toytruck
AnswerID: 216444
Follow Up By: joc45 - Friday, Jan 19, 2007 at 23:26
These days, all the joints and knuckles are sealed and greased for life.
When the item is stuffed, that's the end of its life! - lol!
FollowupID: 476963
Reply By: Member - MUZBRY (VIC) - Saturday, Jan 20, 2007 at 08:01
Gday
I remember back in the old days ,when we had to grease Leyland's and "Atkinsons" there were grease nipples on anything that moved. If it didn't move , then it was ceased and had to be repaired. Spring shackles on twin steer and tandem drive with three part tail shafts and slides.All the pedals and controls under the old trucks, even the speedo cable had a nipple, along with door hinges and hand brake controls...Those were the days, So Chris , i think that you have it easy just having to do the uni joints and slides.
Have a nice day.
AnswerID: 216589
Reply By: Cobes - Saturday, Jan 20, 2007 at 18:53
Hi there,
Thanks for all of your imformative responses.
Looks like i greased all that I can.
Just one last question for Truckster and Roachie,
What lubricants do you guys use for your td42 engine, Diffs (front and rear), gear box and transfer case?
Thanks once again,
(I'm trying to save a few dollars by doing what I can rather than pay to have everything done for me by mechanics)
Chris.
AnswerID: 216703
Follow Up By: Member - Roachie (SA) - Saturday, Jan 20, 2007 at 20:25
Chris, I have now responded to your member message.....but for the benefit of anybody else looking in, I can best suggest that my story about my AMSOIL dual bypass filtration system and 100% synthetic oil might be worth searching on this site. Lots of info available.
It costs a bit to set up initially, but the benefit of only having to change your oil every 50,000klm or so has to be taken into account.
FollowupID: 477113
