Homemade fridge slide ???
Submitted: Friday, Jan 19, 2007 at 22:27
ThreadID: 41412 Views:15709 Replies:6 FollowUps:1
Hi Folks,
Searched the web and the archives and was surprised to not locate a single article on a homemade fridge slide.
All the fridge slides I have seen advertised start from $250 and go up.
I need to mount a TC-32 litre waeco and a CF-40 litre waeco in a frame at the back of my trailer. The fridges will be mounted side by side and in an east/west configuration within the trailer so that when they slide out of the frame they move across the trailer not toward the towball or tailgate.
I don't really want to spend $500-600 to achieve this. The frame that the fridges will sit in will be made from galvanised steel, probably 20x20mm square tube (RHS ?).
Has anybody built their own slides or know where I can get plans/ideas ?
I am happy to weld a base to strap the fridge to but I don't know where to obtain slides with sufficient strength for offroad work to connect the base to the frame.
Cheers ... Taz
Reply By: Member - Ivan (ACT) - Friday, Jan 19, 2007 at 22:39
Mate - when are you home? - I made my own fridge slide for an Engel 40 - solid as..
AnswerID: 216544
Follow Up By: Taz & Milka-Queanbeyan - Friday, Jan 19, 2007 at 22:46
Out of here on 15 Feb if the weather doesn't cut the flight to Dubai like it did yesterday so should be home on the 17th. Will come around before March to pick up the unichip and have a stickybeak and a couple of square bears in a round can.
Cheers ... Taz
FollowupID: 476956
Reply By: Member - JohnR (Vic)&Moses - Friday, Jan 19, 2007 at 23:15
Taz, there was a really good article with pictures of the job that Crazie did a couple of years ago. Really professional job he did of it as you may expect from such a guy. Try a MM to him, not sure if he has his numbers with his rigpic....
AnswerID: 216550
Reply By: Wisebyname - Saturday, Jan 20, 2007 at 01:20
POST 20718 will get you Crazie's fridge slide. saved this page to my fav's for future ref'.
I'm not far from making a copy myself.
Andy
AnswerID: 216575
Reply By: Taz & Milka-Queanbeyan - Saturday, Jan 20, 2007 at 01:58
Thanks guys. Crazie's slide looks great and will easily hold the weight.
Cheers ... Taz
AnswerID: 216580
Reply By: Darian (SA) - Saturday, Jan 20, 2007 at 12:02
My home made slide for the Waeco 50 is still going well.
Bought some study chinese drawer slides from a discount place - $18 the pair !
Bought a piece of ally plate and folded it into a tray at work (sheetmetal folding).
All downhill from there......
Screw the slides to my marine ply false floor, via the use of a bit of ally right angle
Pop rivet the tray to the slides.
Put some nylon support-runners underneath to take the weight when mobile.
Make a spring loaded catch from some ss rod.
Might have been about $65 all up.
I'm not into metalworking - anyone who is would make it stronger than mine but so far, I'm happy.
AnswerID: 216619
Reply By: Diver1 - Saturday, Jan 20, 2007 at 21:33
we built ours for our waeco cf50....easy as...
used a bit of thick ply...painted black ....eventually carpeted it.....put it on rollers that are nailed/bolted into our false floor/draw system that we did ourselves too, then for straps to hold her in place nathan got helicopter seat belts, cut them to length that was needed and they go through the handles and onto a metal loop that he put on the base too..... a
and so that the slide doesnt slide out when the back is open and on a lean there is a push pin that goes into a hole that we drilled into the false floor...
total cost..... $20
Laura
AnswerID: 216740
