80 Series gear change "clunk/grind" ?
Submitted: Saturday, Jan 20, 2007 at 14:11
AndyMac
Hey all.
I have a 93 80 series standard wagon in diesel. Never had any gear issues before but in the past few months I have developed a clunk/grind resistance on the 2nd to 3rd shift. No where else. I can baby it in with no problem but if it is under load so to speak it is a pain. any guess as to what I am looking at repair wise ? I will be off to a
shop but don't want to get raped in the process.
As always thanks.
Andy
Reply By: Member - Cruiser (NSW) - Saturday, Jan 20, 2007 at 15:28
Join the 80 Series Group at groups.yahoo.com/group/80scool/
They might be able to help you.
216651
Reply By: Merce - Saturday, Jan 20, 2007 at 15:43
Mate it sounds like you have worn out the 3rd gear syncro. This was a common problem with the early 80 series. I know of several people that had it replaced under warranty in the early 90's. And some that have been done twice.
216656
Reply By: Middle Jeff - Saturday, Jan 20, 2007 at 20:25
Hi Andy
You might get a bit more life out of it if you use Castrol VMX-M, it is a oil that was developed for Mitsubishi but works great in the Cruiser. But all good things come to an end and eventually they die, my box has just started to do the same thing and some time in the next month or so I will have to get it done, I am happy though it has done 350,000 Ks and I thrash it.
I have heard between $1,000 and $2,000 but I really have no idea, we have a gearbox place in the complex where I work so I will just give it to him and pray.
Have fun
Craig
216716
Reply By: AndyMac - Saturday, Jan 20, 2007 at 20:50
Thanks all, I suspected it was going to be a real issue. It has just on 250K and my regular mechanic said between 5 and 1500 depending on just what needs doing.
Andy
216720
Follow Up By: Member - DOZER- Saturday, Jan 20, 2007 at 21:15
Andy, the bearings are probably the culpret, try vmx-m it will help alot, i would also look for a later model gearbox to rebuild and fit...as the later ones were heaps better. There have been a few for sale on ebay lately....look under landcruiser or 80 series
477137
Reply By: djm67 - Tuesday, Jan 23, 2007 at 20:32
My 94 model standard does it from 3rd to 2nd, syncro appears to be the culprit, and I too am putting off the rebuild lol
217331
