Garmin GPS q?`
Submitted: Monday, Jan 22, 2007 at 10:15
ThreadID: 41488 Views:2155 Replies:5 FollowUps:0
I have a GARMIN GPS map 76, and im looking for an external receiver, prefferably a small bullbar mounted one. I have seen them, lil white half dome, about 2" diameter. Anyone know where i can get one from? Online?
Reply By: MEMBER - Darian (SA) - Monday, Jan 22, 2007 at 10:48
www.gpsoz.com.au should know - I've used them and quite happy with the service (free postage too) - I bought an external for my Garmin 60 - much smaller than the domes - not much bigger than a matchbox - works very well up on the roof rack.
AnswerID: 216994
Reply By: Member - Jay Gee (WA) - Monday, Jan 22, 2007 at 13:24
Ring up Johnny Appleseed GPS on 1800 477 477. I got one for my GPSMAP60. It is a small magnetic type one that works real well.
AnswerID: 217022
Reply By: Kiwi Kia - Monday, Jan 22, 2007 at 17:34
There are plenty around. I use a magnetic mount one (active aerial) on my Garmin 76 and sit it just above the headlamp, run the cable into the gap between bonnet and guard and up through the fire wall.
AnswerID: 217083
Reply By: DIO - Monday, Jan 22, 2007 at 18:15
You don't need an external aerial. An internal is just as good and not likely to get flogged. Sure it doesn't look as posey however it will do the job.
Have a look at GPS OZ I paid about $69.00 for mine including cable, plug and mounting hardware.
AnswerID: 217087
Reply By: Member - Michael- Tuesday, Jan 23, 2007 at 17:27
Wayne
i got an external antenna for my Map76 and have it mounted, using velcro on the dash mat at base of windscreen, at least it won't get flogged or damaged
May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
AnswerID: 217277
