Washing under car after beach
Submitted: Monday, Jan 22, 2007 at 22:20
Twinkles
Hi All,
Planning to go with friends to
Beachport and
Robe this weekend, along with a million others it seems. Is there anywhere that you can wash the underside of your car after beach driving over there?
Water restrictions may make this a problem.
Reply By: Member - Phil G (SA) - Monday, Jan 22, 2007 at 23:09
I call into a Happy wash or Carlovers on the way back into town.
217157
Follow Up By: Member - Ivan (ACT) - Tuesday, Jan 23, 2007 at 06:29
agree - Some of the CarLovers also have an under body spray - once the spray has started, just go forward and reverse over the full length of the car a couple of times - but don't go over the bump that is the sensor for the underbody wash to stop.... - gets just that little bit more out of the carwash, and under where it's needed
477622
Reply By: Brian B (Brisbane) - Monday, Jan 22, 2007 at 23:34
Twinkles,
We are probably on
the beach every couple of weeks and when it comes to washing down afterwards I have found that a lower pressure wash is better than jetting
water in at higher pressures as that just seems to force sand into
places you really don't want it to get to.
It is a real bugger since we went onto level four
water restrictions in
Brisbane as you can't use your hose for this. Our local dam average capacity is down to around 22% at present and level five is just around the corner if we don't get some decent rain in the catchment area soon. I like a lot of others here have installed a
tank and pump so I can still keep my car clean.
I run a lot of
water through the chassis rails via the drainage holes in them as
well as giving a good wash to all other underbody components and the enginer bay. I follow this up with a good wash on the paintwork and once she is all dry I go for an underbody and underbonnet spray of lanotec or something similar.
I also have installed an electronic rust prevention system and to date have not gotten any rust.
That seems to work for me but having access to
water is one of the big issues facing people at present.
Have a good one.
217165
Follow Up By: srowlandson - Tuesday, Jan 23, 2007 at 08:21
i find the staun Massojet a handy tool for this kind of think, pumped from the 12volt
water pump in my car (from the shower unit) and my 120litre
tank and hooked up to the compressor to force the
water out a little, but not as much as a high pressure washer works wonders.
you can even do it as soon as you get off
the beach if you have a hose etc with you ;)
477643
Reply By: DIO - Tuesday, Jan 23, 2007 at 09:30
In SA Level 3
water restrictions apply only to deignated zones thorughout the State. There are no Level 3 restrictions at Robe/
Beachport HOWEVER there are Permanent
Water Conservation Measures.
SA
Water Conservation Measures in detail
CLEANING OF MOTOR VEHICLES, BOATS:
Water must not be used to clean a motor vehicle or boat unless the
water is applied:
From a bucket or watering can filled directly from a tap; or
By a high-pressure low volume
water cleaner; or
From a hand-held hose that is fitted with a trigger nozzle
Motor vehicles or boats can be cleaned at a commercial car wash or by means of an automatic washing system that recycles
water.
Boat motors may be flushed or rinsed after use.
Hope this info clears up your concerns.
217208
Follow Up By: Member No 1- Tuesday, Jan 23, 2007 at 13:29
DIO......you were looking ar restriction levels prior to current level 3
Level three when applied to cars is
"WASHING CARS AND BOATS
Water must not be used to wash a vehicle except by means of a commercial car wash or a bucket filled directly from a tap.
Hoses are not to be used.
Boat owners are permitted to flush out motors and rinse off metal parts to prevent ."
Note: Hoses are not to be used.
477692
Follow Up By: Member No 1- Tuesday, Jan 23, 2007 at 13:33
if read the first line of the page you directed us too.....
"This information relates to permanent
water conservation measures which apply to all customers NOT covered by level 3 or Eyre Peninsula restrictions."
it then makes sense
477695
Reply By: John R (SA) - Tuesday, Jan 23, 2007 at 10:26
There are no car wash joints in
Robe. Nearest is probably
Kingston.
There is a boat wash facility at the harbour, but someone's bound to get annoyed if teams of 4wds turn up to wash the car. Could be quite a lineup too!
I get one of those very basic, round metal sprinklers and
park over it for five minutes.
217221
Reply By: Twinkles - Tuesday, Jan 23, 2007 at 10:58
thanks everyone
217226
Reply By: Member - Hughesy (SA) - Tuesday, Jan 23, 2007 at 15:59
Twinkles, this might not be real relevant for our current climate but when I lived in Qld years ago I would give it a quick hose when I got home but as soon as it started raining (usually within a week) I would jump straight in the cruiser and head along the highway (only 2 ks from home) and do 30 odd km's at 110km/hr in the rain. This will give the best wash of under the vehicle you can get. The
water will go into every crevice that the salt
water did while driving on
the beach.
217263
Reply By: D-Jack - Tuesday, Jan 23, 2007 at 17:37
Beachport Caravan
park has a wash station just inside the front gates, but you need a card to get in - or you could try offering $10 for a wash???? It isn't trigger nozzle operated, but you turn it on and off by bending the nozzle Worth a try.
Level 3 measures don't apply to the S/East, they have more rainfall generally and their
water supply isn't from the Murray.
D-Jack
217279
Reply By: Crackles - Tuesday, Jan 23, 2007 at 19:20
There's a big car wash on the Beechport road in Millicent.
Cheers Craig..........
217313
