gu overheating
Submitted: Monday, Jan 22, 2007 at 22:26
simple
i own a '00 model GU ute TD42T.
i know roachie and others have had overheating problems with similar vehicles. over the past 2 months on hot days i've had overheating issues on the highway. travelling at 110 if i hit a bit of a
hill where the car needs to work a little bit the temp guage sky rockets.
i tried turning off the air con and this helped a bit though it still climbeb to about the 3/4 mark on any
little hill.
as it was so hot on saturday i decided i wanted the air con. so i pulled over and took the lightforce 240's off. this and the half hour break seemed to make a difference and we didn't have any other issues.
so where should i start in dealing with my hot headed nissan.
the easy fix ideas i have are down-size my lighting and add a thermo-fan.
any ideas.
thanks guys.
Reply By: Member -Dodger - Monday, Jan 22, 2007 at 23:06
Mine is a 00 GUas
well and one of the things you can do to help is to take the radiator out a reasonably simple job and clean it out as the space between the radiator core and the air con evaporater gets full of rubbish.
217156
Reply By: Peter - Monday, Jan 22, 2007 at 23:13
Have a '03 4.2 Patrol. I noticed it was warming up towing the van. Had the whole system flushed with Mukowt and new coolant but didn't seem to make much difference. Ended up taking it to a radiator place and they found the radiator 50 percent blocked. Apparently not an unusual occurence for Patrols. Since having the radiator cleared the temp guage doesn't move (although my analogue guage does get to a maximum of 108C) when towing the van (3tonne) up hills with aircon on
217159
Reply By: Willem - Tuesday, Jan 23, 2007 at 00:41
Have radiator thoroughly cleaned by yourself or a radiator place.
OR Buy a new radiator. I got an aftermarket one for $495 (country price including freight) and fitted it myself
217176
Reply By: fishtail - Tuesday, Jan 23, 2007 at 09:51
We had a similar problem with our TD42 in our Maverick - in our case it was the thermal cuppling in the radiator fan which had slowly deteriatored.
Steve & Alison
walkabout.tekcities.com/
217213
Follow Up By: Member - Jeff M (WA) - Tuesday, Jan 23, 2007 at 10:02
That's a very common problem on the surf's and 80 series too.
Clean or replace radiator, repalce clutch fluid in fan and you'll be right as rain I reckon.
477659
Reply By: Member - Roachie (SA) - Tuesday, Jan 23, 2007 at 11:32
I tried all sorts of things on
mine and in the end I decided that anything up to around 118oC was okay. The trick is to have a proper gauge to monitor the ACTUAL temp, rather than rely upon the Nissan gauge which registers in the "normal" position (just below half way) when the actual
water temp is anything between 45oC and 105oC. Once it exceeds 105oC (as registered by the VDO gauge in the top hose), then the Nissan gauge starts to rise in such a way that in the space of 15oC (from 105oC up to 120oC) it goes from the "normal" position to just under the "danger" mark on the hot side.
With that in mind, I disconnected the plug in the bottom of the radiator that senses the temp and "tells" the air conditioner to turn itself off. That meant that the air con stayed on.....and I really don't think that it being on had a great impact on the coolant temperature.
Like the others have said, I would recommend getting the radiator thoroughly flushed and cleaned etc (inside and out), check the viscous hub and either replace or add some extra fluid to it.
I also don't believe having
driving lights in front makes much/any difference to the cooling.
The product called Red-Line
Water Wetta (
grey) might be worth using too. Others have reported good results with it. I used it once too, but the one I got was the red coloured one and from I have since learnt, the
grey version is better for diesels.
Good luck.......just remember, the 4.2 is as tough as old boots and doesn't seem to mind running a bit warm all day if necessary.
Roachie
217233
Follow Up By: GQ_TUFF - Tuesday, Jan 23, 2007 at 17:26
Well Said, everything you said is the method of deduction I went through with my 2.8 GU, The crappy patrol radiator was 80% blocked at 125000km. Had to get a new one as it beyond cleaning. That fixed it. Then I put some
water wetta in it and that has cut down the fan run times so it must be doing something. I could not say how much it has helped as Roachie has said the nissan temp gauge is calibrated in such a way that small rises and drops dont show on the gauge.
Cheers Stefan
477742
