Help please
Submitted: Tuesday, Jan 23, 2007 at 18:41
djm67
For the toyata experts.....
I am trying to find out the model (part #) of the transfer case & gearbox in the following vehicles:
HJ75 (2H 4lt diesel)
HZJ75 (1HZ 4.2lt diesel)
Essentially I am trying to find out if a PTO winch from a later model HZJ75 (4.2lt) will fit onto a early model HJ75 (4lt)
TIA
Dennis
Reply By: Member - Toytruck (SA) - Tuesday, Jan 23, 2007 at 19:09
djm67,
I don't think it will go. The reason is, and I may stand corrected, the 2H Transfer case has an inspection plate that is removed to take the PTO gearbox.....the 1HZ does not have this inspection plate.
I have a HJ60 with a PTO winch and looked at this same thing some years back.
Toytruck
217308
Follow Up By: Member - Toytruck (SA) - Tuesday, Jan 23, 2007 at 19:12
sorry,
should have said, I have a HJ60 and a HZJ105. I think you will be in the same boat with the 75's.
Toytruck
477768
Follow Up By: djm67 - Tuesday, Jan 23, 2007 at 19:29
Thanks but the PTO is coming FROM the 1HZ to the earlier 2H (with said inspection plate)
477772
Reply By: Member - Phil G (SA) - Tuesday, Jan 23, 2007 at 22:30
I'd be pretty sure that they are identical.
I've looked up the spec sheets (dated 11/87 and 10/92) on those two models, and the gearbox, transfer and diff ratios were identical. The gearboxes on both were the H55F. Can't remember the transfer designation, but I'd be pretty sure they were the same too. I've known people with both vehicles with PTOs
I think Toytuck above is getting confused with the 80/100series 1Hz which I think had a different transfer and lacked the plate for the PTO.
217376
Follow Up By: djm67 - Tuesday, Jan 23, 2007 at 22:36
Marks adapters has the 80 series box as the H150F (H151F for the turbo)
But it lacks model numbers for the HJ75 series.
It notes that they both are 19t spline, with the ratios the same except for 3rd gear (slightly higher ratio in the 4.2lt)
477824
Follow Up By: Member - Phil G (SA) - Tuesday, Jan 23, 2007 at 23:08
H150F/H151F boxes didn't ever get fitted to the 2H or 1Hz 75series.
They were only used in the 1FZ-FE and 1HD-FTE 75series.
477834
