oz explorerer map software
Submitted: Wednesday, Jan 24, 2007 at 22:14
Member - andrew G (VIC)
gda guys i have a question about oz explore map software. ive been using this great software for about a yr or so got all worked out and no real dramas so far practise makes perfect. but i now want to start importing map images from other
places .
have saved images ok and got them opend in ozex but cant seem to be able to calibrate them, put in the points as in the help but cant put in the other figures lontitude and latitude stuff.. where do i read these from on my image. i only have the image marks. thanks for any help in this
Reply By: Member - Jay Gee (WA) - Wednesday, Jan 24, 2007 at 23:19
Have you scanned in a full map including the borders?
Do the border borders have something that looks like a ruler with the latitude and longitude information?
What you do is use the information on the borders to work out the co-ordinates of your calibration points.
If your map has a set of gridlines - you would normally use the interesction of the horizontal and lines as calibration points (provided you know the value of the gridlines.
Other - choose a number of points on the map that you know the co-ordinates of and use that information.
Have I lost you yet?
Jeff
217618
Reply By: Member - Jay Gee (WA) - Wednesday, Jan 24, 2007 at 23:22
Woops - left out a word - try again
If your map has a set of gridlines - you could use the interesction of the horizontal and vertcal lines as calibration points (provided you know the values of the gridlines.)
Another option - choose a number of points on the map that you know the co-ordinates of and use that information.
Jeff
217620
Follow Up By: Member - andrew G (VIC) - Wednesday, Jan 24, 2007 at 23:53
thanks for info there are no borders on the map and no gridlines just the map image i suppose this is why the map wont calibrate.
I think i will have to use known waypoint marks from other maps and put these into the right
places on calibration screen,Bugger knew it wasnt going to be that easy..
Great software overall just need to keep using it to remember all the stuff.
478062
Follow Up By: Member - Jay Gee (WA) - Thursday, Jan 25, 2007 at 00:01
Yep - that's what you need to do. Enjoy and keep with it. You are correct when you say it is great software.
478067
