Disco 2 air bag problem - any advice please
Submitted: Saturday, Jan 27, 2007 at 23:42
Member - Barry (NT)
Hi all
seeking some advice if I could from Disco 2 owners. Friends have 2000 Disco and RH rear airbag deflates intermittently, which is an obvious problem with 2 tonne van on behind.
Problem is only when parked on uneven ground and as I said intermittent. Alan has taken it in for check by the local dealer and their majic black box says problem is with LH rear bag (Murphy at work or wired up wrong I suspect).
Suspect either intermittent exhaust valve or inlet non-return valve type problem but dealer wasn't helpful when they wanted to fit 2 new bags first ($1200 or so) and they intermittently stay inflated - so I suspect there is no leak at the bags or they would deflate when parked ( some logic here I trust).
Any help appreciated if you have experienced any thing like this.
Cheers Barry
Reply By: garrycol - Sunday, Jan 28, 2007 at 11:33
I cannot help ypu but if you go to this landrover
forum you will get the answer real quick - www.aulro.com
Garry
218154
Reply By: Redback - Sunday, Jan 28, 2007 at 17:31
I'd say it has a small leak, or a leak in the air line from the compressor, get some soapy
water in a spray bottle and pump them up and spray the soa[ie
water along the line and joins and the air bag too.
Anymore info, go to the web link that is mentioned above, AULRO, it's a great Landy
forum that has heaps of info and people to help.
Baz.
218203
Reply By: Member - Barry (NT) - Sunday, Jan 28, 2007 at 23:52
Thanks - missed the site you puit up - looks like my guess was close and I start the leak checks.
Cheers Baz
218282
