GU Sub tank problems
Submitted: Sunday, Jan 28, 2007 at 13:52
Willem
A mate(who can't type) asked me to pose this question...lol
He has a 1999 Nissan GU 4.2lt diesel.
Lately the sub
tank has been draining into the main
tank with the switch in the OFF mode.
The sub
tank drains completely within about a week.
Is this a known problem and is there an easy solution?
Thanx
Reply By: V8Diesel - Sunday, Jan 28, 2007 at 14:16
My 4.5 petrol GU used to pump a bit from the sub
tank to the main every time it started. I could never work out why my
tank was draining. I believe it is set up like that so the reserve fuel does not go stale.
218182
Follow Up By: Willem - Sunday, Jan 28, 2007 at 14:52
Thanks for that V8
478617
Reply By: Bilbo - Sunday, Jan 28, 2007 at 14:41
Willem,
Does the sub-
tank drain while the car is stationary? If so, then he has a problem - but,,,,,,,,,,,
Or does it drain when it's running?
The standard GU set up is that once the Main
Tank gets down to less than 3/4 full then the '
tank-logic' will allow a small amount of fuel to go from the sub to the main each time the vehicle starts up.
It doesn't take long for the sub
tank to disappear if yer doing stop/start runs often.
I don't like the set-up, but it's "'standard Nissan"
Bilbo
218185
Follow Up By: Willem - Sunday, Jan 28, 2007 at 14:51
Thanks Bilbo
I think that my mate said that he noticed the drain over a week or so. Cannot really say if it was draining whilst stationary and/or moving. The truck is used every day.
I think your reply is the answer my mate is looking for(or not the answer...lol)
478616
Reply By: Member - Ross (NSW) - Sunday, Jan 28, 2007 at 15:02
Willem,
I have a 2000 GU 4.2 diesel that has only started to drain the sub into the main of its own accord. For the first 5 years I had to manually press the sub
tank button.
Regrads
Ross
218186
Reply By: Red One - Sunday, Jan 28, 2007 at 15:09
If its draining in one week it might be worth while to check if the solenoid is working.
I have heard of the coil burning out which could lock into a half open, quarter open etc position.
218188
Reply By: Member - Dunworkin (WA) - Sunday, Jan 28, 2007 at 16:54
We have a GU 1999 model 4.2 and yes it does empty a little out of the sub
tank each time you start it but it takes a lot longer than has been mentioned in your post to empty. We had the oposite problem with ours, after we got off of the CSR. (a couple of years ago) was heading to
Fitzroy Crossing after leaving
Halls Creek thinking that we had plenty of fuel, pressed sub-
tank switch, half hour later sub
tank still full, oops!! finished up having to drain subtank into bucket and putting it into the main
tank that way, problem was the pump from the subtank. Hundreds of $$$$$$to replace new but our mechanic sourced a good second hand one for half the price and is still going strong.
Deanna
218197
Reply By: diesel dave - Thursday, Feb 01, 2007 at 13:47
Hi Willem
I own 1998 GU 2.8lt Tdi. when you first start the patrol the sub
tank drains around 7-9 secs worth of diesel into the main
tank. Unless he his starting the patrol a lot within the week this shouldn't account for the sub
tank draining in a week. not sure if you know this already but it may give him some answers.
when you find out the exact problem can you post it on the
forum because i would also like to know why.
218996
