New / Second Hand HF in, But is it working
Submitted: Sunday, Jan 28, 2007 at 20:43
ThreadID: 41712 Views:3577 Replies:8 FollowUps:2
Fired up the Barrett 550 today. Went out of town so as to be out of the way of any interference. Set up for the VKS-737 Schedule & heard one caller in Brisbane talking to Charters towers Base. Brisbane was clear & Charters towers was weak.
Tried calling The Charters Towers base but no answer.
Am I asking a bit much to try & raise Charters Towers from the Bule Mountains NSW ?
Have Lisentened in to others skeds but have not picked up anything. Is it just a slow time or do I have a coms problem ?
Vince
Reply By: Member - Shane D (QLD) - Sunday, Jan 28, 2007 at 20:50
If you don't mind me asking,how much did you spend?
I the process of getting one myself
Shane
AnswerID: 218239
Follow Up By: Vince NSW - Monday, Jan 29, 2007 at 08:07
Shane,
&1800 on ebay
FollowupID: 478694
Reply By: Sign-man - Sunday, Jan 28, 2007 at 20:58
What time did you call C/T base?? Was it their sched time??
You could have called me at Adelaide from 1900hrs NSW time tonite- or Darian last nite..
AnswerID: 218240
Follow Up By: Vince NSW - Monday, Jan 29, 2007 at 08:09
Tried C/T at 1700 hrs.
Will try to get home in time to try Adelaide tonight at 1900 (Monday 29 Jan)
FollowupID: 478695
Reply By: Member - John and Val W (ACT) - Sunday, Jan 28, 2007 at 21:09
Vince,
Generally speaking, if you have a good signal from a base, they have a good chance of hearing you. Atmospheric conditions dictate how well long distance hf comms work - sometimes bad, sometimes good. I haven't been listening lately, but at other times I've had excellent contact with Charters Towers from ACT and Victoria. Mornings I find usually better than evenings, though interference out of Asia and from OTH radar can sometimes be pretty overpowering.
If you can hear CT base and a Brisbane mobile from the Blue Mountains, your installation is probably OK, though this doesn't vouch for your transmissions. Ensure all connections, epsecially earth connections, are good - these have much more effect when transmitting than when receiving. Around sked times you should be able to talk to someone (anyone) to check your transmissions.
HTH
J and V
- Albert Einstein
AnswerID: 218245
Reply By: Member - Davoe (Nullagine) - Monday, Jan 29, 2007 at 00:41
very slow time of the year for VKS I did a radiocheck from Kal just so the poor operator had ANYONE to talk to. Just coz you hear the base doesnt mean they can hear you Adelaide is a good example they boom through 5 by 5 but can barely hear you from Perth. HF is a bit fickle from Kal i can easily hear people doing the CSR but the Alice sked is barely a whisper.
AnswerID: 218289
Reply By: MEMBER - Darian (SA) - Monday, Jan 29, 2007 at 09:18
As others have said Vince, lots of things introduce variation to the performance - mainly "natural conditions" - solar activity , weather etc. The thing is, wherever you are , under any conditions, you should be able to get at least one base, if the chips are down - once into the network, all sorts of good things can start happening. Re radio checks generally, early and late in the day are best - you might get good comms as far as Derby and Perth - Charters you would normally expect to be good for you. From Brisbane, you should normally expect to get into the Alice - also the same for Adelaide - time permitting, keep trying - it'll happen. I think it is fair to say that once travelling in the interior, the base options you have increase markedly, as compared to the coast.
AnswerID: 218308
Reply By: Steve63 - Monday, Jan 29, 2007 at 10:17
You will need to experiment a bit. The base stations tend to be clear as they have big units and good antenna set ups. If you can hear them easily and clearly you should have a good chance of being picked up. Pick one of the stations (not in a sked time slot) and send it a becon call. If you get the answering chirps you know your signal got there. You need to be aware that the "best" frequency varies by how far away you are from the base station, what frequency and what time of day it is. The situation can change very rapiodly as the sun is setting or rising. The distance is not an issue as long as the frequency, conditions, time of day etc are correct. I have spoken to Adelaide from Cape York and the northern end of CSR when the same day it was difficult or impossible to raise Alice. The very next day the situation could be the other way around. Some times position can be important, moving 10 feet can make the world of difference. Get out from under trees etc, make sure there are no power lines close by. If you are in a gorge this tends to cause some issues. I tend to get interference from the engine electrics so I always call parked somewhere with the engine off. Hope this helps.
Steve
AnswerID: 218321
Reply By: Vince NSW - Monday, Jan 29, 2007 at 10:54
Thanks for the reply.
I will try again tonight depending on what time I can get away from work.
I have a great spot to test from with no tree cover & no power lines within 800 mt. It is also great for UHF as I can see from Gosford to Goulburn...
Thanks everyone, hope to hear you on the air.
regards
Vince Remeo 1776
AnswerID: 218331
Reply By: anglepole - Monday, Jan 29, 2007 at 13:33
First take a look at www2.ips.gov.au/HF_Systems to see there are no warnings, then ensure no one is using the VKS frequency and Beacon Call say Alice Springs on 8,11 or 14 MHz
You should get a return beacon on at least one frequency.
You could also try other bases. Remember Beacon calls can be annoying and refrain during sched times.
AnswerID: 218362
