Finally put the turbo on my Patrol
Submitted: Monday, Jan 29, 2007 at 23:01
Luke SA
Ive had the turbo sitting in my spare bedroom for about 18 months now and slowly getting bits and pieces to put it all on as I didnt get the whole lot when I bought it.
I bought the turbo and dump pipe and a other few bits and pieces from Roachie.
On the weekend stripped the the front pipe and and manifold from under the bonnet and started fitting the hairdryer. I had a few little problems like the nuts would bind up on the studs and strip themselves when i tried to undo them so I had to go and buy a tap and dye to give them a clean. (Even though they "looked" clean)
When I eventually got the manifold against the side of the head I just had to overtighten a nut didnt I, and yep....... I broke a stud, easy outs were my new best friends. finally got it back on and was a bit more carefull.
I ran the oil feed from the oil pressure sender and after undoing 34 sump bolds welded a fitting in the side of the sump for the drain. For the
water I drilled a hole in the housing that the lower radiator hose feeds into, taped a thread and put in an elbow brass fitting, and put a rubber hose from there to the metal hose that leads to the turbo, put another hose from the thermostat housing to the other metal hose to the turbo. Sound a bit confusing.......... it confused me lol
As soon as I was able to start it, i did strait from the dump pipe to see if it ran smoothly....... I was glad it did, there was only one oil leak coming from the T piece I put in the oil pump for the oil feed
I have sorta bodged up the exhuast so I can drive it until I get a complete 3" exhuast put on but for now does the job
As far as power goes I wish I had put it on 18 months ago I wouldnt be without it now I just have to get used to the whistle it makes it sounds like a truck is passing me out on the highway its that bad. I have done a search on turbo whistles and it seems to be "sorta" normal but it still worries me a bit. Maybe when I get the exhuast and injectot pump tuned it might quieten down a bit ........ I hope
It was a good few days with a couple of challenges but would do it again and a hoist is a must, it made life soooooooo much easier
Cheers Luke
Reply By: Recyled Teenagers - Monday, Jan 29, 2007 at 23:17
Good one Luke
How many ks has the patrol done as Im thinking of doing the same
George
218518
Follow Up By: Luke SA - Tuesday, Jan 30, 2007 at 19:28
Thanks George
my advise would be to go for it. I got the turbo from this site cheap and the wreckers I got all the other bits and pieces from had just gotten a change over engine in that was going to the scrap yard so they were happy for me to take what I wanted as nobody would seperate a good diesel engine.
All up it has cost me so far just under a grand. Ive still got the exhuast and tune to do yet so maybe $1500 all up
Cheers Luke
479100
Reply By: Member - Roachie (SA) - Monday, Jan 29, 2007 at 23:30
Glad to see you finally got it bolted up mate. I'm surprised there wasn't a oil return lug available just below the turbo, but above the sump. Anyway, good effort and hope it goes
well for you for many years.
Roachie
218519
Follow Up By: Luke SA - Monday, Jan 29, 2007 at 23:40
Thanks Roachie
There was a lug where the oil return is supposed to go on the turbo motors but there was no hole and i wasnt game enough to go drilling into the side of the block and there wasnt enough room to fit the drill
Cheers Luke
478935
Reply By: Member - Jason S (SA) - Tuesday, Jan 30, 2007 at 02:18
MMMMMM .....
turbo whislte .........
Don't be worried lad. All normal for a Turbo.
218529
Reply By: Ian from Thermoguard Instruments - Tuesday, Jan 30, 2007 at 09:22
Hi Luke,
Congrats on getting your turbo set-up. I'm a bit confused by your
water piping though.
Please correct me if I'm wrong about the Nissan coolant circuit and/or turbo cooling, but it seems as though you will be taking 'hot' coolant from the thermostat housing, passing it through your turbo bearing jacket, then discharging it into the bottom hose (pump suction). This small flow will be completely bypassing the radiator, no?
I would have thought the ideal would be to take relatively 'cool' coolant from the pump discharge side (not sure where you'd pick this up on your engine though - perhaps a drain port low down and towards the front of the block?) to the turbo jacket. Then discharge into the t/stat housing and send it through the radiator.
If I've interpreted it all wrong, my apologies.
Ian.
218546
Follow Up By: Exploder - Tuesday, Jan 30, 2007 at 17:56
I think It Picks the coolant up from the lower radiator Hose aria (Before the
water pump) then the
water runs throe the turbo and back into the Theostat housing to go back into the radiator to be cooled.
That’s the way I read it anyway.
479073
Follow Up By: Luke SA - Tuesday, Jan 30, 2007 at 18:36
I always thought the
water flowed up thru the radiator not the other way around. Correct me if im wrong somebody.
The
water is suppose to (in my way of thinking) go from the radiator thru the top radiator hose out of the thermostat housing thru the turbo, out of the turbo and back into the lower radiator hose
If I have it wrong I would apprieciate it if someone told me as I dont want to blow up the turbo
Cheers Luke
479080
Follow Up By: Ian from Thermoguard Instruments - Tuesday, Jan 30, 2007 at 18:57
Hi Guys,
This is my understanding of normal engine coolant systems (please correct me if its wrong): While pump-forced, they still employ the thermo-syphon system. That is,
water flows upward from the hot engine block, throught the thermostat housing, then into the radiator core where, as it cools, it falls to the bottom of the radiator, then back int the engione from from the bottom hose. [I believe the original Ford flathead V8 employed ONLY thermosyphon circulation without any pump, is this right?[
Now add a
water pump at the engine block end of the large diameter bottom hose and it acts like this: the lowest pressure point in the system is at the pump suction (the bottom hose) and the highest pressure point is at the pump discharge (in the engine block, at the front, just behind the pump). So, at every point in between, the pressure is somewhere gradually decreasing between the highest and lowest points.
Therefore, the t/stat housing will be at a higher pressure than the bottom hose (the lowest pressure) - and
water will have to flow from the higher pressure point to the lower pressure point. Any cooling system specialists out there (Mr
Water Saver Alarms?), would you tell us if this is so or not, please?
479087
Follow Up By: Luke SA - Tuesday, Jan 30, 2007 at 19:17
Hi Ian, I can not corect you on any of that............. you lost me when you said thermo-siphon ;)
But I can say that if your understanding is correct about
water flowing down the radiator then I dont think there would be a problem as
water would flow from the bottom hose, divert to the turbo (before the
water pump) then to the thermostat housing and back thru the radiator.
The hose that goes from the bottom rad hose housing to the turbo is the way they are from the factory but the other one is supposed to go in the side of the block but I couldnt do that as I didnt want to start drilling in the block so I ran it where I did
Cheers Luke
479094
Follow Up By: Member - Shane D (QLD) - Tuesday, Jan 30, 2007 at 20:12
hot
water goes in the top and cool
water comes out the bottom of a raditor
479117
Follow Up By: Luke SA - Tuesday, Jan 30, 2007 at 21:22
Thanks Shane it makes sense now that I have been thinking about it. The
water gets hot going thru the engine and heats up the thermostat, thermostat opens and
water flows on ;)))
Cheers Luke
479142
Follow Up By: Ian from Thermoguard Instruments - Wednesday, Jan 31, 2007 at 08:21
Hi Luke,
Re. your comment: "then I don’t think there would be a problem as
water pump) then to the thermostat housing and back thru the radiator." - but unfortunately it can't. Like all fluids,
water flows from high pressure to low pressure and the lower hose (the pump suction inlet) is the lowest pressure point of the system.
I'm sure the flow in the factory set-up is the opposite to what you have assumed: it flows FROM the port in the block (on the pressure side of the pump), through the turbo jacket and then TO the bottom hose (the suction side of the pump). That's why, in my original reply, I suggested looking for a coolant drain plug on the side of the block as a suitable source of higher pressure, relatively 'cool' coolant.
If you then kept the return from the turbo going to the t'stat housing (as you have it at present) you would also get some natural ("thermosiphon" - hot fluids rise, cool fluids fall) circulation still occurring after switching off - always a good thing for turbo bearings.
Interesting discussion - but I hope some specialist our there can definitively resolve this for us shortly.
Ian
479195
Follow Up By: Ian from Thermoguard Instruments - Thursday, Feb 01, 2007 at 14:04
Hi Luke,
Looks like no 'experts' have come to the rescue.
To check the direction of flow with your set-up, perhaps your could insert a short length of clear tube into your turbo jacket line (when it is all cold) and see which way the flow is? Hopefully there'd be enough small bubbles or fine particles in it to 'see' the flow?
Ian
479450
Follow Up By: Ian from Thermoguard Instruments - Tuesday, Feb 06, 2007 at 07:37
Any update on this, Luke?
480652
Follow Up By: Luke SA - Monday, Feb 12, 2007 at 00:47
Hi Ian,
I did what you suggested with the clear hose idea, and the
water flow goes from the thermostat housing thru the turbo and back into the bottom radiator hose housing, meaning
water flows from the engine thru the turbo and back thru the engine. Its been like that for two weeks now and is still running fine so I think I will leave it like that.
Ideally I would rather it come straight from the radiator thru the turbo and straight back into the radiator but I couldnt find two small hose fittings on the radiator, only found one up the top
Thanks for your concern and asking
Cheers Luke
481880
Follow Up By: Ian from Thermoguard Instruments - Monday, Feb 12, 2007 at 09:00
Hi Luke,
Thanks for going to the trouble of checking the flow.
No joy with finding a drain plug on the side of the block, eh? That would be the ideal source point - then take the turbo outlet hose to that fitting on the radiator top
tank. The current set-up will work fine most of the time but if you're ever working the engine hard in hot conditions (40C+), the turbo bearing may not be getting the specified cooling.
Ian
481909
