12 volt sink pump for a van???
Submitted: Tuesday, Jan 30, 2007 at 21:05
Jimbo
We're after a 12 volt pump that can simply be placed in the top of the inlet hose that normally runs to the
hand pump.
I'm assuming it would have to be self primimg to lift the
water from the
tank to the sink.
Has anyone done this?
Type/brand of pump?
Cost?
Jim.
Reply By: Gob & Denny - Tuesday, Jan 30, 2007 at 21:10
goodday jimbo
most of the later vans have a pump with a built in pressure switch and use a normal tap so whenits turned off pump stops
having said that have you tried carac in frankston dandy rd in dandy
steve
218706
Reply By: Member - Davoe (Nullagine) - Tuesday, Jan 30, 2007 at 21:17
no worries they are arund 100 bux (country prices) fom any good
camping store
218708
Reply By: Willem - Tuesday, Jan 30, 2007 at 22:24
Jim
You can use a $20 Jaycar Shower pump for the job. I use this to pump
water out of my
water jerries. Doesn't need priming.
218727
Follow Up By: Member - Crazy Dog (QLD) - Tuesday, Jan 30, 2007 at 22:30
Yo Willem,
Could not find in the Jaycar cattledog... I want to do the same ...
Grrr!!!
479158
Follow Up By: Willem - Tuesday, Jan 30, 2007 at 22:43
Yep Doggie....it might be out of the dogalogue by now. I managed to pick up one in
Melbourne in October last year. Call them and see if they have some hidden away somewhere. I have one for a shower and one for a pump.
479162
Reply By: rags - Tuesday, Jan 30, 2007 at 22:35
Jimbo
I have a jayco camper which i fitted a Whale superline 991 12v inline pump and using a waterproof toggle switch as the control.You need to prime the pump with your
hand pump when you first go to use it but then it works any time you activate the switch.Got it from CAMEC for about $45.00 part no 3541-962
www.camec.com.au Plumbing.pdf
Thanks Russell
218731
Follow Up By: V8 Troopie - Tuesday, Jan 30, 2007 at 23:42
With regard to switches for
water pumps, unless you have a BIG
water tank it pays to use a MOMENTARY push button instead of a toggle switch. With this, the pump would only run while the button is being depressed, you cant walk away from it. This will save you
water in the long run as pressing the button for a long time gets tiresome.
Klaus
479174
Reply By: Mike Harding - Wednesday, Jan 31, 2007 at 07:12
A small bilge pump - any boating supplies place about $20 upwards.
218759
Reply By: AdrianLR (VIC) - Wednesday, Jan 31, 2007 at 08:04
Jim,
This is the one I used in our camper :
Site Link
$23.95 at Whitworths. Fittted at the lowest point of the
water line under the camper with a metal cover. Enough
water remains in the line to self prime. Fitting it here allows the manual pump to also be used. Momentary toggle as the switsh as others have suggested.
Adrian
218765
Reply By: Ian from Thermoguard Instruments - Wednesday, Jan 31, 2007 at 08:36
Hi Jim,
I recently installed a Whale in-line pump near the
tank outlet under our van - works a treat. It could be the same as the one Rags mentioned (can't recall model no. now). It needs a flooded suction but can be easily primed with the
hand pump if the
tank is very low.
Agree with others' recommendation to use a momentary switch and have another suggestion: we put our large
water-resistant momentary pushbutton on the front of the undersink cabinets, at "knee height". Makes it very easy to wash both hands at once! Send me an email if you'd like a photo.
Ian
218772
Reply By: flappa - Wednesday, Jan 31, 2007 at 10:42
I bought a small self priming pump from a Country show a while back , it only runs about 12l/min. Was the smallest available. Cost me $50.
They are very similar to the Surflow pumps but probably made in China ?
I'll try and find a name for them , although it has been discussed on here previously.
218784
Reply By: wazzaaaa - Wednesday, Jan 31, 2007 at 10:51
Hi Jimbo,
In my caravan I replaced the
hand pump with a normal tap with a Flowjet self priming 4.5 lpm pump in the line from the
tank. All we do now is turn the tap on and out comes the
water, turn it off and it stops, I have a switch to turn the power to it off when travelling or when low on
water. The
hand pump can easily refitted in emergency.
Wazzaaaa
218786
Reply By: Grizzle - Wednesday, Jan 31, 2007 at 11:59
I have a Flojet 4.5 Litre/minute pump that I use for my car shower. Small in size with built in pressure swich and is self priming. Cant remember exact price but I think around $90
218793
Follow Up By: wazzaaaa - Wednesday, Jan 31, 2007 at 12:15
Grizzle,
That is the same pump I have I can have two taps running at the same time hot and cold
water tap, the pressure switch is great.
Wazzaaaa
479217
