offtopic .... problem with SPAM
Submitted: Tuesday, Jan 30, 2007 at 21:10
Member - Dedalus (SA)
Hi I.T.guys!
I have to post this becouse I'm desperate .... can you please explain me how I can stop someone (legally) to send me SPAM and insulting e-mails ??
Thanks!
Luca
Reply By: Tim (vic) - Tuesday, Jan 30, 2007 at 21:15
I use Spam Fighter which is a free down load
www.spamfighter.com
You can block addresses etc
Tim
218707
Follow Up By: V8Diesel - Wednesday, Jan 31, 2007 at 10:33
Tim, you are a diamond mate! Read your post and installed Spam Fighter last night. It works a treat. (insert usual disclaimer here)
Thanks again.
479208
Follow Up By: Johnnotoo - Wednesday, Jan 31, 2007 at 17:28
Thanks also Tim
I too downloaded it . Very impressed. User friendly .
479272
Follow Up By: Tim (vic) - Wednesday, Jan 31, 2007 at 19:15
Glad it helped
I have used it for a while now and find it quite good
Tim
479298
Reply By: Member - Dedalus (SA) - Tuesday, Jan 30, 2007 at 21:22
Thanks Tim!
I'm installing it now ...
Luca
218710
Reply By: GaryInOz (Vic) - Tuesday, Jan 30, 2007 at 21:41
Report it to your ISP. They can block it completely to the MAC address in the offenders computer (harrassment) and take it further legally if need be.
218714
Reply By: Mobi Condo - Tuesday, Jan 30, 2007 at 21:52
Also try SPAM MATTERS from ACMA - if it Australian source SAPM I believe they can act pronto. Cheers Mobi
218717
Reply By: Member - John (Vic) - Tuesday, Jan 30, 2007 at 22:00
Mail Washer is also a help in filtering the $hit before you download it to your machine.
Allows you to blacklist the crap.
218718
Follow Up By: Angler - Tuesday, Jan 30, 2007 at 22:09
I have been using mailwasher for some time now and though it seems to work I was still getting big mobs of spam. I installed spamfighter and find it is far superior to mailwasher.
The only problem with it is it will not work with thunderbird.
Pooley
479152
Follow Up By: Member - John (Vic) - Tuesday, Jan 30, 2007 at 22:25
Mail Washer won't block the crap but will allow you to filter it and bounce and delete it at the ISP server level.
It allows me to quickly scan the incoming email list for the important stuff before dumping the $hit.
479157
Follow Up By: Mad Dog - Vic - Wednesday, Jan 31, 2007 at 14:36
Angler, Thunderbird has it own junk mail controls built in. The adaptive filter works very
well indeed after a little training.
479239
Reply By: Motherhen - Wednesday, Jan 31, 2007 at 00:00
My ISP (Westnet) filters out SPAM and emails me a list each day in case i want to retrieve any. Mostly it gets 20 - 40 meaningless total garbage emails from overseas.
Outlook gets a few that slip the net and puts them into junk mail box (i check as it occasionally gets legit mail).
Any that get through both of above, i then make a "rule" on that sender, ISP, wording or whatever to put straight in the delete box when they arrive, or just "block sender" - does the same thing.
218748
Reply By: moss - Wednesday, Jan 31, 2007 at 00:26
I recently started getting spam and just forward them to reportingspam@submit.spam.acma.gov.au
and they stop pretty quick
regards
David
218751
Reply By: Waynepd (NSW) - Wednesday, Jan 31, 2007 at 07:59
I have just been using the rules in outlook to filter my usual mail into folders.
If it turns up and stays in my inbox then it is either junk mail or mail from a new source. A quick scan through and its sorted.....
218764
Reply By: Mr Fawlty - Wednesday, Jan 31, 2007 at 21:03
As you could imagine I get many personally offensive emails go here & report it:
http://www.dcita.gov.au/communications_and_technology
Spam is another problem but the free spam filters work
well. In Outlook Express under the mail rules you can set up rules to not download emails from any given address, that sometimes works.
For people who send you viruses knowingly see if you can find software called "Nuke Them", you send it to them & it formats their hard drive for them....
218885
