Hot water heater hose connection
Submitted: Wednesday, Jan 31, 2007 at 10:28
Noldi
Hi Guys
I have a Coleman Hot
water system. I want to connect it to my
water tank on the CT, that has a threaded garden type tap on it. Is there an attachment that will screw onto the end of the pump (the bit that screws onto the supplied platic container) which I can also attach to the tap? if so any ideas on where I can purchase them?
Rgds
Ian
Reply By: Member - Teabag (Queanbeyan) - Wednesday, Jan 31, 2007 at 10:38
Mine has a normal tap fitting (Male) to the end of the pump and the
water tank also Male. The have a piece of food grade hose with two female hose fittings to interlink the two....Works a treat.....
218783
Follow Up By: Noldi - Wednesday, Jan 31, 2007 at 10:45
Thanks Teabag, good idea I'll take it down to Bunnings and get the fittings, where did you pick up your food grade hose?
479209
Follow Up By: Shaker - Wednesday, Jan 31, 2007 at 11:15
Bunnings ..... 10 metres for about $14.00
479212
