Strange colour on outside of hoses.
Submitted: Wednesday, Jan 31, 2007 at 12:17
Footloose
Popped the bonnet of my 80 series yesterday. Some of the rubber pipes have a white covering over them. The heater pipe appears to be the worst. The covering will come off if you wet your finger and rub hard.
There are no leaks anywhere.
Any guesses what the powdery white stuff is ?
What I use to remover it easily ?
Reply By: Member - Franga (QLD) - Wednesday, Jan 31, 2007 at 12:59
Hey Footloose,
I'll have a stab at it, have you changed your coolant of late.
I believe if you use a different coolant to the one you have been running without flushing the system, it can cuse problems with chemical reactions.
Being on the outside of the hoses, how old are the hoses, could they be at the end of there use by date.
Any pin hole leaks under pressure?
Back to you
Franga
218800
Follow Up By: Footloose - Wednesday, Jan 31, 2007 at 13:30
Coolant not changed for 12 months. All fluid levels Ok. Hoses are 12 months old.
Just wondering if mech has sprayed something onto the hoses to make them look good and thats what I'm seeing ?
479226
Reply By: peteC - Wednesday, Jan 31, 2007 at 13:37
Hi, They all do it. Dont worry about it.
218812
Follow Up By: Member - Davoe (Nullagine) - Wednesday, Jan 31, 2007 at 15:29
i know
mine does- something to do with those crappy factory clamps i reckon
479246
