Bury yourself in the sand
Submitted: Friday, Feb 02, 2007 at 15:19
ThreadID: 41898 Views:4187 Replies:6 FollowUps:21
I just saw a program on ABC2 where it was recommended that if stranded in the desert, it is advisable to bury oneself in the sand, in spite of the heat, to slow down dehydration.
I'd never heard that one before.
My first reaction would be that you'd cook yourself like in a camp oven, albeit juicy not dry !
Anyone else heard of that?
Reply By: Member - Davoe (Nullagine) - Friday, Feb 02, 2007 at 15:25
Aussie desrts are a bit different to some in that they are vegetated - you would be better off trying to get some shade I reckon - it doesnt take much of a shrub to cast enough shadow to get the sun off you
AnswerID: 219259
Reply By: Member - Phil B (WA) - Friday, Feb 02, 2007 at 15:51
I wonder if they tookinto account how much perspiration would take place digging the hole?
As Dave says its better to rest inthe shade
AnswerID: 219272
Follow Up By: Member - Matt Mu (Perth-WA) - Friday, Feb 02, 2007 at 18:24
My first thought...stranded...conserve water and energy! Not dig a grave although...maybe thats the point! Keep ther vermin away and save the rescueres having to deal with the remains!
mmmm, not nice! I think I would be creating shade and conserving water ASAP! Not digging holes unless its a bushstill for water but I would do that at night!
FollowupID: 479825
Reply By: Member - Toytruck (SA) - Friday, Feb 02, 2007 at 16:02
Ever seen a hungie???
Cooked meat. :-)
Toytruck
AnswerID: 219276
Follow Up By: Member - Stephen M (NSW) - Friday, Feb 02, 2007 at 18:53
Hi there Toytruck, same thought that just come to my mind. Steve M
FollowupID: 479830
Follow Up By: Member No 1- Saturday, Feb 03, 2007 at 09:26
bloody kiwi's will eat anything
FollowupID: 479944
Follow Up By: Sam from Weipa Auto Electrics - Saturday, Feb 03, 2007 at 14:26
Easy best food you will ever have (cooked right though) you need coals to make a hungie
FollowupID: 479985
Follow Up By: Bonz (Vic) - Saturday, Feb 03, 2007 at 15:36
u mean a Hunjy? I wouldnt call a 100 series cooked meat.
FollowupID: 479999
Follow Up By: Member No 1- Saturday, Feb 03, 2007 at 17:34
betterthananissananyday
FollowupID: 480018
Follow Up By: Bonz (Vic) - Saturday, Feb 03, 2007 at 18:28
yougottabejoking
FollowupID: 480033
Follow Up By: Member No 1- Sunday, Feb 04, 2007 at 09:19
closer to the bone sweeter the meat
nissanslooklikelard
FollowupID: 480152
Reply By: Member - Arkay (SA) - Friday, Feb 02, 2007 at 19:24
Put tarp up attached to vehicle. Sit in shade. Wait. No tarp? Scoop up small amount of sand from under side of vehicle to make shallow cave (not grave). Crawl under shade of vehicle cave. Wait. Whatever else you do, stay with vehicle.
AnswerID: 219319
Follow Up By: Mike Harding - Friday, Feb 02, 2007 at 19:46
Raises a good point: having tried to use a tarp as a sunshade last year in the Vic High Country when the temp hit 45C I found it next to useless. (Because of the nature of the trees in that area they provided little shade). The direct heat of the sun just streamed right through! Sure, it helped a bit (5%?) but I soon gave up on it and found a tree with a broad trunk the shadow of which I could sit in - albeit in a rotating manner :)
Does anyone have a recommendation for some material suitable for shade on very hot days.
In regard to the original post: the "dig a hole" thing sounds like something which someone writing a "Survival Manual" might suggest - the theory has some merit but the practice is probably pretty stupid.
Mike Harding
FollowupID: 479844
Follow Up By: Robin - Friday, Feb 02, 2007 at 21:30
Hi Mike reminds me of guy camping next to us last year and they got sunburnt under there lightweight tarp.
A plain heavy duty silvered trap is what we use mostly out of convience and it really does work but is not quite as good as a tree because the underside isn't reflective as well , and its heat profile extends down about 300mm allow light air
currents to circulte hot air under the tarp (the higher the tarp the better).
As an experiment I have used double sided building foil silvered on both sides and it is as effective as trees however not as practical (not current stuff blued on one side).
What however really works best is a doubled tarp (two tarps) seperated by 200 to 300mm. Silvered side up and other silvered side down.
Now this is more trouble and we only do it if in one place for 2 or more days (rare).
But its not as hard as one might think , using a standard 12X12 tarp with 5 poles one in middle , the two tarps are just laid out one over the other and they touch in center when erected.
On the 4 outer poles , the lower tarp is clipped onto the poles about 300mm below the top tarp, with poles already set up for this its fairly easy.
The real secret of this though is that it allows the hot air below the top to tarp to circulate and flow away outside the area shaded by the tarps.
The system is as effective as tree shade.
Robin Miller
FollowupID: 479878
Follow Up By: Member - Brian (Gold Coast) - Saturday, Feb 03, 2007 at 09:59
Robin.... exactly the principal behind tropical roof awnings on older pergolas, permanent caravan's and even some old Land Rovers!
FollowupID: 479949
Follow Up By: Carl & Kaz - Saturday, Feb 03, 2007 at 12:22
We use shade cloth instead of a tarp to erect an awning off the side of the car. One corner attached to the rear of the roof rack, one pole 2-3' in front of the bullbar, and two more pole for the outer corners. Takes all of 2-3 minutes, only one peg and rope on each corner.
We find the shadecloth allows air to circulate, and it is definately cooler than using a tarp! Still keeps the sun off you - I've sat all day on the bank of Eli Creek under one of these watching the backpackers getting into and out of trouble!!
FollowupID: 479970
Follow Up By: Footloose - Saturday, Feb 03, 2007 at 17:39
If in sandy area, scooping or digging a depression isn't a silly idea at all. It allows you to get under the vehicle (shade) and wriggle around without belting your head on anything.
The blue poly tarps allow too much UV through and you can get sunburnt easily. Better to go for some shadecloth.
Some deserts aren't easy to scoop ground away, better to lie doggo around a small bush.
FollowupID: 480019
Follow Up By: Robin - Sunday, Feb 04, 2007 at 08:55
Interesting Brian , didn't know that. Love to see old land rover like that to. We have a really big outdoor 4wd show on here in 2 weeks sponsored by LRV so must look out for some really old ones.
Carl / Footloose
Shadecloth can be good but you have to be alittle careful these days , around here a lot of 50% shadecloth is being sold and its cheap and I suspect many get caught.
I guess there are two factors at play , ruliny out completely light tarp ,the heat buildup under good trap is real, but even 90% shadecloth still lets 10% UV thru so I feel in would be a toss up between the effectiveness of the two.
Other factors are that while shadecloth lets hot air go , it also lets rain pass, so I guess one would make choice on there local conditions.
We actually take both , mainly because of the changeable weather here in vic.
The heavy duty single layered tarp handles everthing with exception of really sunny days, which have required either the second tarp or siting the main tarp such that by mid afternoon some additional tree shade covers it.
Robin Miller
FollowupID: 480143
Follow Up By: Member - Brian (Gold Coast) - Sunday, Feb 04, 2007 at 09:16
Robin,
Have a look here...
www.eunos.com/keith/landy/
Click on some of the pics of "Basil" the Landy and you'll see the tropical roof. We had a neighbour here for the last ten years who had an old dead Landy in his yard, it had a Tropical Roof on it as well and it would have been a good project car, in almost running order, it simply needed bearings in the gearbox as a minimum to get it going. It was a similar vintage to Basil in the above link...
Brian
FollowupID: 480150
Follow Up By: Robin - Sunday, Feb 04, 2007 at 10:20
Thank you Brian , worth looking at.
I could have been a landy owner , except that the very first 4wd trip I ever went on was in one and it broke an axle 100m into the bush.
Robin Miller
FollowupID: 480170
Follow Up By: Member - Brian (Gold Coast) - Sunday, Feb 04, 2007 at 10:39
"I could have been a landy owner " ...
Yep... me too!!
I grew up in Sydney next to a family of machanics and the son that was my age had a penchant for Landy's. He built one up from a wreck, this was mid/late 70's. He treated it like a kid! I had no interest in it at all. Years later, my bride and I were on a 4wd tour to see the coloured sands on Teewah Beach in an old Landy. It was a lot of fun but still not my "thing". Our introduction to 4wd'ing was via a "rent-a-wreck" mid 80's Range Rover at Rainbow Beach. fell in love with that old banger!!!!!! Even have a pic of it somewhere!!! LOL...
Now I love my GQ and the fun it brings us, but I kept seeing the neighbours Landy over the last ten years and often thought of it as a 'builder", but he was the sort of bloke that would never let me forget where I got it from had I bought it.
Brian
FollowupID: 480176
Follow Up By: Footloose - Sunday, Feb 04, 2007 at 10:56
I used to be a Landy owner. It was the most uncomfortable *fun* you could have with your gear on. 100k/h downhill with the wind behind you. The seats designed to give you years of pain thereafter. Diffs that went bang, brakes that were useless in traffic. Couldn't talk to passengers because of the noise. But I loved mine........... until I got in a Yota.
FollowupID: 480179
Follow Up By: Member - Brian (Gold Coast) - Sunday, Feb 04, 2007 at 11:01
That's GOLD Footy!!!!
LOL...
Brian
FollowupID: 480180
Reply By: Footloose - Friday, Feb 02, 2007 at 19:37
An old Foreign Legion mate of mine had a good tip for stranded in a desert. Remove all clothes except light footwear. Then cover the head and body in an old bedsheet. (Arab style suit)
When I suggested digging a hole under the side of the vehicle to lie in, people here slammed me. But thats exactly what I'd do. Lie doggo in the sheet and try not to move around during daylight.
Burying yourself in sand wouldn't allow your body to sweat very well.
If working during the day remember that tools can get hot enough in summer to burn your hands. Better to do any work at night.
AnswerID: 219322
Follow Up By: Mike Harding - Friday, Feb 02, 2007 at 19:48
I always carry one on the off-chance.... :)
FollowupID: 479845
Follow Up By: Truckster (Vic) - Saturday, Feb 03, 2007 at 17:43
They keep one spare all the time in arabia...
FollowupID: 480020
Reply By: Troopy22 - Friday, Feb 02, 2007 at 20:03
In the Kimberley you often see Aboriginal people sitting under a boab tree rather than a gum tree because boabs are basically big water bottles that keep nearby air much cooler and a decent sized one will give you good shade.
AnswerID: 219331
