Wheel bearing nut dimensions for GU
Submitted: Tuesday, Feb 06, 2007 at 12:00
Austravel
Just about to do my GU wheel bearings. If anyone has dimensions so I could make a spanner I'd appreciate it. I know they are now round with a couple of dowel pin holes.
If not, when I make one I'll post all the dimensions needed. Would just make it easier for me to get them first.
Reply By: madcow - Tuesday, Feb 06, 2007 at 12:11
If my memory is right I believe they are 53mm apart for the pins. Might pay to do a search
220145
Follow Up By: Robin - Tuesday, Feb 06, 2007 at 12:57
Yep
mine same almost.
Two steel pins 52mm apart centre to centre
Made by welding pins to outside of short piece of 45mm OD steel pipe
Robin Miller
480713
Follow Up By: Austravel - Tuesday, Feb 06, 2007 at 13:18
Thanks madcow and Robin, will get to it now.
480717
Follow Up By: Austravel - Thursday, Feb 08, 2007 at 11:22
Hi Robin,
Any idea what ID the pipe was?? Alternatively what is the OD of the stub axle?
481156
Follow Up By: Robin - Thursday, Feb 08, 2007 at 12:41
My pipe was 42mm Id
Robin Miller
481170
Follow Up By: Austravel - Thursday, Feb 08, 2007 at 12:47
Thanks for that.
481171
Follow Up By: Austravel - Thursday, Feb 08, 2007 at 17:39
Being a pain I know but-
So 7mm pins, ID 42mm, OD 45mm. What length of pipe if I want to clear the stub axle and drill holes in the end of the pipe to make it like a T-bar????
Thanks again.
481230
Follow Up By: Robin - Friday, Feb 09, 2007 at 08:10
Haven't got
mine today , so from memory pins extended below tube 15mm and tube was approx 120mm long, and most important was the 52mm centre to centre
Robin Miller
481373
Follow Up By: Austravel - Monday, Feb 12, 2007 at 10:40
Thanks for that Robin.
481918
Follow Up By: Austravel - Monday, Feb 19, 2007 at 10:11
Thanks for the help Robin. Made the spanner and used it on the weekend.
Found that
the nut was very tight, unlike the GQ bearing nut. I had to loosen it with a hammer and to get it to the same spot so the locking nut could be screwed it I had to tighten it with a couple of taps with a hammer.
Is that the norm for the GU??
483468
Reply By: Member - Ed. C. (QLD) - Tuesday, Feb 06, 2007 at 12:58
The one I made has 7mm dowels, 52mm apart (centre-centre)... Pins need to be about 55 - 60mm long to clear the axle stub...
Mr
Gregory (Manual# 519) recommends a pre-load torque between 167 - 196 Nm (123.5 - 145 lb ft).. If you follow this recommendation, I'd suggest using at _least_ 1/2 - 9/16" dia. (HT bolt) for the dowel pins (w/- the ends turned down to 7mm to engage
the nut)...
Have fun;-))
Regards, Ed. C
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
220154
Follow Up By: Austravel - Tuesday, Feb 06, 2007 at 13:19
Thanks for the extra info Ed, it's not a job I really enjoy but at least I know it's done properly.
480718
Reply By: Bilbo - Tuesday, Feb 06, 2007 at 14:36
Hmmmmmm,,,,,,,,
"167 - 196 Nm (123.5 - 145 lb ft).. "
Sounds about "one good belt and two little taps" with 2lb hammer and chisel ;)
Well, that's how i used to do the Mav wheel bearings and they never packed up!
Bilbo
220168
Reply By: Wayne (NSW) - Tuesday, Feb 06, 2007 at 18:00
Austravel,
The socket for the wheel bearing nut is not that expensive. The one I have is more of a tube socket and is strong enough to tighten and loosen the wheel bearing nut.
The one I got had a 3/4" drive, so I welded a 1/2" socket into the 3/4" drive and this also works fine.
Having the right tool for the job makes it a lot easier and I would check and repack the bearing more often having the right socket.
Wayne
220201
