12 Volt inline water pump
Submitted: Thursday, Feb 08, 2007 at 10:56
vcbb
I have put a 55 litre
water tank in the back of my dual cab, and was looking for a small in line pump to out provide the
water a bit quicker than gravity. Is anyone aware of s amll pump to do the job which doesnt cost a small fortune
Reply By: Howard T - Thursday, Feb 08, 2007 at 11:07
Hi VCBB
There are heaps of pumps around that will suit your purpose. I have a Johnson on my
camping trailer for about 3 years and has never missed a beat. Cost was arount $100. Got it from a fishing tackle
shop.
Would imagine there would be some on EBay also.
Good Luck
HowardT
220550
Reply By: Member - Roachie (SA) - Thursday, Feb 08, 2007 at 11:08
Flojet or similar would be the go.
220551
Follow Up By: Member - Roachie (SA) - Thursday, Feb 08, 2007 at 11:14
Site Link
or
Site Link
481155
Follow Up By: vcbb - Thursday, Feb 08, 2007 at 11:39
Thanks Roachie much ppreciated the whale pump seems the go, ta
481161
Reply By: porl - Thursday, Feb 08, 2007 at 11:36
My vote goes with the Whale, amazingly reliable and robust. I use one for my
football field line marker when the expensive one breaks down and for quick jobs. Been going 3 years now and sits unused in the 6 month off season every year.
220554
Reply By: Member - Phil G (SA) - Thursday, Feb 08, 2007 at 12:35
I know people who've used teh Whale pumps and been really happy. $50 from Whitworths (boat
shop):
Wouldn't discount gravity. I've always used it for
water. My current 75litre undertray
tank has 1/2 inch hoses and fittings and a high flow tap (like rainwater
tank tap) that is mounted on the back of my cab, just below the
tank, and flow is very good.
220559
Follow Up By: Gordon from Black River 4wd Club Inc - Thursday, Feb 08, 2007 at 14:37
Beware the Whale.
I have one in my setup and they will allow flow withot power.
My outlet is above
tank level, but given a fairly full
tank and a steep incline it can drain (even if only partly) through the pump.
I installed a 24vAC irrigation solenoid valve (Yes, to my surprise it does work) wired into the same switch as the pump and this has solved the problem.
I have had
mine for 4-5 years without trouble and as others have said, they take up little space.
Given the option I'd go for gravity.
Gordon
481192
Reply By: flappa - Thursday, Feb 08, 2007 at 13:52
Do you have to prime the Whale Pumps , or self priming like the Flojets etc ?
I personally like the flojet pumps for this type of thing
220567
Follow Up By: Rod W - Thursday, Feb 08, 2007 at 14:19
Whalers are self priming.
481186
Reply By: Moose - Thursday, Feb 08, 2007 at 14:14
The Whale is the go. Cheap, effective and takes up bugger all space. Use one of those push to operate type of switches so that you don't waste
water. Can get them at SuperCheap for a few dollars.
220569
Reply By: V8Diesel - Thursday, Feb 08, 2007 at 14:17
Go to Bias Boating Superstores. They're a chain store with very good prices.
I use a Jabsco which is as powerful as the mains and cost about $130 from memory.
220570
Follow Up By: V8Diesel - Thursday, Feb 08, 2007 at 20:49
Correction: Sure-Flo pump
481268
Reply By: Member - Doug T (W.A) - Thursday, Feb 08, 2007 at 14:20
Yes as Roachie has posted Flojet, No 1 reason is that they are not cheap Chinese crap , and if you don't mind me asking , what type of
water tank did you get, I have an 80ltr under the bed in my Troopie . like this one but inverted.
" target="EOF" class="lbg">www.dynaplas.com.au/
Site Link
220572
Follow Up By: Member - Doug T (W.A) - Thursday, Feb 08, 2007 at 14:25
Odd that the link is not working. it does from my favorites but try putting the http:// in front
481190
Reply By: Rod W - Thursday, Feb 08, 2007 at 14:21
My Whaler will empty a 25lt container in 2 minutes.
220573
Follow Up By: Member - John L G - Thursday, Feb 08, 2007 at 15:05
And that of course is the problem with electric pumps versus a gravity or
hand pump when using precious fluids - they can be wasted.
481196
Follow Up By: Rod W - Thursday, Feb 08, 2007 at 15:14
You're dead right there. When I was setting up my set-up I quickly discovered that I need an in-line tap at the point of use as after turning the pump off syphon gravity took over withwater continuing to flow.
481198
Follow Up By: traveller2 - Thursday, Feb 08, 2007 at 15:17
I've used awhale in several vehicles over the years, work
well, currently have one pumping diesel from the aux tank to the main one.
481199
Follow Up By: Member - John L G - Thursday, Feb 08, 2007 at 15:21
Rod,
Being an old offshore racing yachtsmen, it is notable that very few boats have electric pressure pumps for
water supply but use manual types.
The reasons for this I suppose are two fold in that race yachts don't carry that much water in the first place so its pretty precious stuff and hand pumped water is less wasted and of course the other is as you describe with syphoning a real threat on tipping and rocking boats.
481202
