WLL Safe Working Load Limit versus breaking strength
Submitted: Tuesday, Feb 13, 2007 at 17:03
ThreadID: 42264 Views:33467 Replies:9 FollowUps:14
Hi all,
I'm looking for a new winch hook.
I have several options.
I'm a bit confused though by both the prices and some of the claimed ratings.
I'm aware that the breaking load rating far exceeds the Working Load Limit but I can't find a lot of info on how or what to do to calculate it.
The ratings for towing/pulling exceed the lifting loads. One american document I found from a government standards site suggested it was dependent on the purpose.
Paste:
When the lift involves raising or lowering workers, the factor of safety on
the rigging is 10 i.e. 10 percent of the breaking strength. For all other lifts,
the factor of safety on the rigging is 5 i.e. 20 percent of the breaking
strength.
Example:
If the weakest rigging component has a breaking strength of
35,000 kilograms, the SWL for a personnel lift is 3500 kilograms i.e. 35,000
÷ 10. If the same rigging configuration is used for a non‐personnel lift, the
SWL is 7000 kilograms i.e. 35,000 ÷ 5.
But that doesn't really apply in our setting.
You don't use a 20tonne rated hook on a 2 tonne vehicle.
Also I have seen three different Grade 80 Self Locking hooks and two rated a rung above the competition despite as best I can work out being the same size.
The Beaver hook is a 10-8 Grade 80 hook rated at a WLL of 2000kg and is about $70.
The ARB 10-8 hook (grade not specified) is rated at a WLL 3200kg and from inspection looks to be the same size and is $23.
There's another on Ebay which is unbranded and when I asked the guy said "The hooks are supplied by the same company that make the RunHua brand winches (including those for Ironman and various other brands). They are manufactured in China by an ISO certified manufacturing company."
The hook is stated as being a"... G80 grade 10-8 size hook weighs in at 1.46kg and has a WLL of 3200kg. This equates to a breaking strain of between 12800kg and 16000kg." with an RRP of $50 but are selling on Ebay for less than that. I would guess they are really worth about as much as the ARB one which is possibly also chinese.
Beaver make construction & lifting equipment, it's what they do. The chinese copy stuff I'm not sure about.
The 10-8 size is the same for all three, but the Beaver one which is list $82 and trade $70ish, is the way I'm leaning but I'm not sure if the WLL 2000kg is okay or not. I could go to the next size up but it's huge compared to the other two.
I've got a similar size lashing hook from Beaver that is rated at a SL (safe load?) of 6000kg so it must have a breaking load of much greater than that also.
I'm guessing that the WLL 2000kg hook from Beaver has a breaking load of at least 6000kg-8000kg from the fact that when I rang and asked how to work out the towing rather than lifting rating they said double it.
So to safely be able to tow 4000kg it must have a factor of at least 1.5-2 for safety margin.
Any mechanically qualified opinions care to be ventured?
Thanks in advance,
Reply By: geocacher (djcache) - Tuesday, Feb 13, 2007 at 17:52
A picture speaks a thousand words.
The first pic is of the three I have at the moment.
On the left is the Beaver lashing hook with an LC rating of 6000kg and 10mm for the chain size, which is bigger than any drag chain I've ever carried.
In the middle is the Beaver supplied Gunnebo Eye Self Locking Hook.
I've just found their web site and the info below is from there:
The specs for the size are:
Code BK-7/8-8
WLL 2.0 tonnes*
chain size 7, 8
L 137mm
B 36
E 25
F 11
G 17
H 23
Weight 0.7
* Safety factor 4:1
I take the safety factor to be less than or the same as the breaking load rating.
The red one is the original Warn hook. It's marked as a G30 rating. I don't have anything to reference as to its rating.
This pic is the ARB one. You can see the prices marked. The marking on the hook iis 10-8 WLL3.2T.
AnswerID: 221451
Reply By: Ozboc - Tuesday, Feb 13, 2007 at 18:08
WLL or SWL are there for a reason - how many times have i gone to fix an overhead crane rated to 10 tonne to be told " ah yeh - we had been cross pulling with it - also been lifting about 15 - 20 tonne with it - it handeled it ok"
if you want to work out other factors that are far more revelent to you - then look up dogging calculations - if you cant find them i will get out my dogging books.
In short - if its rated 5 tonne -- you DO NOT EXCEED 5 tonne. spend the little extra cash.
BOC
P.s sorry i could give figures , but i have known of people that have presumed that the saftey fact was 4x and ended up as a work cover statistic.
AnswerID: 221457
Follow Up By: geocacher (djcache) - Tuesday, Feb 13, 2007 at 18:29
Hi Boc,
Yes, true. But lifting ratings and pulling ratings are completely different. Don't ask me why. The sales engineer at Beaver tried explaining it but didn't do a very good job.
As best I understand the difference is in the margin for safety and using a 4500kg rated hook on a 9000lb winch is both completely unnecessary as it is putting a hook that would operate safely PULLING at something like 20 tonne on a winch incapable of pulling more than 5 tonne.
When winching even up a steep slope the winch isn't lifting the entire weight of the vehicle. There's some sort of vector relationship and it's a very long time since I did physics but the mass of the vehicle is supported by the ground at all times, the winch is just providing the force required to get that mass to move against friction/resistance up an incline.
Even on a steep recovery the winch isn't holding the full mass of the load at any time.
A 3.2 tonne hook is rated for lifting with 10mm chain. No one uses 10mm chain in recovery, nor am I aware of any accredited 4wd course curriculum that recommends it.
A 5.4 tonne hook is rated for 13mm chain but that's just getting ridiculous.
As a Paramedic I'm acutely aware of work cover statistics. I've been to a few. It's also why I'm doing my research.
FollowupID: 482219
Follow Up By: Alloy c/t - Tuesday, Feb 13, 2007 at 19:08
Have not done physics for a long time either , 30+yrs in fact , but it seems to be basic that a straight vertical lift of say a 3 tonne vehicle is just that , 3 tonne , a winching exercise of a bogged / stuck 3 tonne vehicle would require considerably more force than required for a straight vertical lift ,ergo a higher safety margin required , tell me I'm wrong ! Gravity is a constant , 3 tonne is 3 tonne , a stuck 3 tonne is not just 3 tonne.
FollowupID: 482226
Follow Up By: Ozboc - Tuesday, Feb 13, 2007 at 19:37
Just for the people interested - ANY chain that is to be used for lifiting must have a graded stamp on it - the stuff from bunnings is not to be used for anything other than as security lock up.
formula to work out chain lift capacity - SWL(KGS)=d(squared)(mm) x G x 0.4
so - we know the chain is 10 mm - the grade will be 80 grade ( or stamped T )
so its 10 x 10 x 80 x 0.4 = 3200 KG or 3.2 tonnes
There are other grades of steel chain but 80 grade is the most common in the lifting game ( t- 80 p - 40 l-30 ( mild grade)
NOW to the one that will maybe effect winch owners if looking to change FSWR ( flexible steel wire rope )
SWL of FSWR Formula:SWR(kgs)=dsquared x 8
12 mm FSWR will be 12 x 12 x 8 = 1152 or 1.15 tones
how to work out if your rope is ready for the bin ( any kinks and it should be disguarded without this test)
6 x 24 rope ( 6 strands of 24 wires ) with the same size rop as above ( 12 mm )
length of rope to inspect is 12 mm x 8 = 96 mm
Number of wires= 6 x 24 = 144
10 % of 144 = 14.4 wires
therefore 14 broken wires over a 96 mm length means rope is no good
this covers the basics --
if you need more formula then let me know !!
Boc
FollowupID: 482231
Follow Up By: geocacher (djcache) - Tuesday, Feb 13, 2007 at 21:29
Interesting reading the bit on recovery on SA_Patrol's link.
It seems the advice I had was wrong (above). It's very hard to get a consistent response to this stuff but the bit I found interesting on the Pirate 4x4 site was the bit I've pasted below.
I might even print the pics, laminate them and stick them in the glovebox for future reference. I might also be more inclined to use the snatch block.
From www.pirate4x4.com
Calculating the force of a recovery operation:
This is a critical step in both the conduct of a winch recovery (because you need to be absolutely sure that EVERY single piece of equipment used in the task is strong enough and will not fail and thereby endanger life and limb), and in the selection/purchase and decision to use a piece of recovery equipment. It is a calculation where, quite frankly, the manufacturer's recommendations are woefully inadequate. Why? Simply because if they let you in on how large the forces really are, it would leave you realizing that they are unable to economically produce a winch of sufficient capacity in anything resembling a small, light, or economical enough package. They get away with it, because, as I said, there are virtually no regulations or standards governing the industry. I'm not saying all 4x4 winches are inadequate, dangerous, or useless. But I am saying that the forces involved are often much greater than the manufacturer's would have you believe, and you will be far more capable and SAFER if you approach your 4x4 recovery KNOWING THIS, and knowing the real numbers. Realize, that for reasons of practicality and economics, your 4x4 recovery equipment is almost certainly undersized.....you can still do the job, using the correct techniques, but you will be much SAFER if you keep this in mind. Enough of the pre-amble.
Most, if not all, winch manufacturers will tell you to select a winch based on 1.5 times the gross vehicle weight. This often leads to less than satisfactory results for 2 reasons:
1) Most people are terrible at actually estimating the gross weight of their rig as it sits on the trail, full of gas, tools, equipment, food, camping gear, people, the dog...everything. Heck, in some cases the real figure can actually exceed the GVWR of the vehicle. Simple advice here - either err WAY on the heavy side, or get your rig weighed in trail trim.
2) More importantly, the "effective weight" of a "stuck" 4x4 is very often FAR more than 1.5 times the GVW. The following data on how to more accurately estimate the "effective weight", is taken from the world of professional heavy recovery - the guys that recover Tractor-trailers that have flipped on their side for instance, as well as U.S., Canadian, and UK Military recovery manuals.
Once you have accurately estimated or measured the trucks loaded weight (LW) you can calculate the resistance to be overcome in any recovery situation (this is commonly known as the ROLLING resistance). There are 4 types of resistance that must be accounted for to accurately assess the resistance that must be overcome. These are surface resistance, damage resistance, mire (stuck) resistance and grade (slope) resistance. Calculate them all as follows:
Surface resistance
A pull of 1/10 LW will cause a free wheeling truck to move on a hard, level surface.
A pull of 1/3 LW will cause a free wheeling truck to move on a softer surface, such as grass or gravel,
Damage resistance:
A pull of 2/3 LW will be required to move if the wheels cannot rotate (as if the brakes were fully applied), the pull required to overcome the resistance (drag) the truck id 2/3 or 67% of the LW. Damage resistance includes surface resistance (i.e. you only use one or the other)
Stuck (mire) resistance:
A pull of 100% of LW will be required if the truck is stuck to a depth of the sidewall on the tires.
A pull of 200% of LW will be required if the truck is stuck to the hubs.
A pull of 300% of LW will be required if the truck is stuck to the frame..
Mire resistance includes damage resistance (i.e. you only use one or the other)
Grade (slope) resistance:
Upgrade (vehicle has to be recovered up a slope or grade)
15 degrees - add 25% of LW
30 degrees - add 50% of LW
45 degrees - add 75% of LW
Vehicle recovery on level ground - no correction
Downgrade (vehicle has to be recovered down a slope or grade)
15 degrees - subtract 25% of LW
30 degrees - subtract 50% of LW
45 degrees - subtract 75% of LW
Final figure:
Add surface or damage or mire resistance and grade resistance, and this is your final figure or rolling resistance. This is the amount of pull the winch must apply in order to recover the stuck vehicle.
Example:
My trail rig fully kitted out weighs in at 5000 lbs. I get stuck down a rock ravine that's about 45 degrees steep, and there are big rocks up to the frame hanging it up. Rolling resistance is 5000lbs x 3 + (5000 x 0.75) = 18,750 lbs. As you can see, this is significantly more than the 5000lbs x 1.5 - 7500lbs the manufacturers would have you believe. You may be wondering how one could ever possibly recover the vehicle in this example, given that the largest commercially available 4x4 recovery winch is 15000 lbs and that most are in the 8-9000lb range. The answer is by using multi-line rigging, which we shall explore in a moment.
FollowupID: 482261
Reply By: Scoof - Tuesday, Feb 13, 2007 at 18:29
Hello Dave
Working Load Limit
The working load limit (WLL) of a sling is the maximum load that may be lifted by
that sling making a straight lift. The load factor for a straight lift = 1.
The WLL canbecalculated by dividing the guaranteed breaking strain (GBS) by a safety factor.In general rigging work the safety factor for FSWR is 5.
This is out of my Rigging Book not something I dreamed up hope it help's.
Kind Regards,
Jeff M. (SA)
AnswerID: 221470
Follow Up By: geocacher (djcache) - Tuesday, Feb 13, 2007 at 18:33
But where does any manufacturer quote the Guaranteed Breaking Strain?
If Gunnebo quote a safety margin of 4:1 and your rigging book assumes 5:1 that doesn't stack up either.
This is all getting very confusing.
Anyone know the the WLL for 8mm plasma rope?
FollowupID: 482222
Follow Up By: geocacher (djcache) - Tuesday, Feb 13, 2007 at 18:35
FSWR = flexible steel wire rope
FollowupID: 482223
Reply By: Member - Mike_L (SA) - Tuesday, Feb 13, 2007 at 18:43
Dave,
Site Link
Mick.
AnswerID: 221474
Reply By: SA_Patrol - Tuesday, Feb 13, 2007 at 19:03
Another site worth reading
Site Link
AnswerID: 221481
Follow Up By: geocacher (djcache) - Tuesday, Feb 13, 2007 at 21:13
Thanks for that.
Interestingly not one of his listed suppliers in the article on hooks stock a hook with an SWL of greater than 3200kg.
Yet he insists on using a hook at least as capable as the cable.
An 8mm rope from OK Offroad is rated at 13,700 lb. I'm not sure on the conversion of US lb to kg but it's gotta be at least 6,000kg.
You could put a 6 tonne hook on it, but the winch will stall before either breaks, so your winch becomes the weakest part of the system.
Interestingly we commonly use 3,200kg bow shackles. Most I know carry a 3.2T & 4T bow shackle.
4wd Monthly did a breaking load test on those a while back but I can't recall which issue. Might go and see if I can find it.
FollowupID: 482253
Reply By: Anthony - Tuesday, Feb 13, 2007 at 21:26
Hi Geocacher
I recently went to Bullivants (the Melbourne store is 5mins from my place) to get some 8mm Transport chain (8,000 kg rated - not for lifting only draging) and some Gunnebo hooks. The hooks are the yellow ones which are 2WWL rated for lifting applications as are the Gunnebo Hammer Locks, both have a 4 to 1 safety, suited for 8mm chain.
The 8mm Transport chain comes in a 9 metre length. I cut the chain to get a 5 metre "drag chain" and a 4 metre "equilizer chain" to attach to the 2 recovery points on the 4wd B/bar.
My understanding on the difference between WWL & Breaking Strength (BS). BS is more used for non-lifting applications for chains and hooks, which are usually not yellow.
I ended up buying the 8mm Transport chain (8,000 kg BS) and Gunnebo hooks (for 8mm chain - 2WWL & about $29 each) and hammer locks also with the 4 to 1 saftey to give me the same BS as the Transport chain.
The issue with the yellow lifting rated hooks, hammer locks and chain for lifting applications, the combination of chain, hook etc, once assembled needs to be tested by a certified tester to approve the WWL rating for lifting applications. This is not an issue (at least for me) when only used in a draging application.
cheers Anthony
AnswerID: 221520
Follow Up By: geocacher (djcache) - Tuesday, Feb 13, 2007 at 21:36
Thanks Anthony.
I presume when you are talking 2WWL hooks you mean the 2 tonne rated hooks.
You don't happen to have the part numbers do you?
FollowupID: 482263
Follow Up By: Anthony - Tuesday, Feb 13, 2007 at 22:08
For the yellow Gunnebo hook you posted the pic, the name is Eye Type Safety Latchlok Hook Type BK, the Bullivants Order Code is 122027 (to suit 7 & 8mm chain & 2WWL or 2 tonne rate) and the order code 122028 is to suit 10mm chain and is 3.2WWL or rated 3.2 tonne.
You can check out the Bullivants info at www.bullivants.com. The Phone number in Melb is 03 95851288. I don’t have any link with them except that I spend some of my money there buying their stuff.
The interesting thing is Bullivants imports Gunnebo direct and appear to sell the Gunnebo cheaper in Aust than Gunnebo. I have not checked this claim myself. I bought a couple of the Sling Hooks with latch type EKN for 8mm chain (about $29 each). This hook needs a Hammer lock to attach to the chain. I also bought one of the safety hook type EGKN/GKN for 8mm (also about $30) for 8mm chain. The good thing about this hook is you don’t need a hammer lock to attach it to the chain. It has a pin instead of a ring, so you don’t need to buy a hammer lock.
If you want to get a hook, like the yellow one pic above, but instead of the ring (which needs the hammer lock) you get the type the can attach direct to the chain. The Bullivants catalogue lists it as a Clevis Type Safety Latchlok Hook – SHC. The order code for 8mm chain is 121066 and the code for 10mm chain is 121067. The 8mm is 2 tonne and 10mm is 3.2 tonne.
Cheers Anthony.
PS They gave me a catalogue on my list visit.
FollowupID: 482271
Reply By: geocacher (djcache) - Tuesday, Feb 13, 2007 at 21:46
So does anyone reckon there's any difference between the ARB, Chinese & Gunnebo hooks apart from about $70?
You usually pay for what you get, but if they are all rated why is there such a difference.
AnswerID: 221532
Follow Up By: SA_Patrol - Tuesday, Feb 13, 2007 at 21:58
And who has rated the Chinese brand, It all depends on the quality of steel they use in production. I always buy my gear from Nobles. I know they have done lots of tests before they release a product.
FollowupID: 482267
Follow Up By: geocacher (djcache) - Tuesday, Feb 13, 2007 at 22:12
That's what I figured too. The price difference is huge.
I was surprised at the price of the ARB hook, but after reading that tech page on recovery you linked before I'm not so surprised.
FollowupID: 482273
Reply By: Doggy Tease - Tuesday, Feb 13, 2007 at 22:37
Gday Dave.
Just a few words for ya.
Gravity is a bitch and when she decides to teach you a lesson, it's gunna hurt.
Forget price in this equation. Just remember that no amount of money will bring back someone if the equipment fails.
Get the best you can and if you can go up a size,,,then get that instead.
You may only use the hooks full potential once during it's service life, make sure it will not fail on you.
meow.
rick.
AnswerID: 221551
Follow Up By: geocacher (djcache) - Tuesday, Feb 13, 2007 at 22:42
Money is no object. Just looking for knowledge on which to base common sense.
There's a huge gap between a 6 tonne hook and a 3.2 tonne hook in physical size.
If money was an issue I wouldn't replace my tyres at 50% tread depth for safety off & on road...
FollowupID: 482282
Follow Up By: Doggy Tease - Tuesday, Feb 13, 2007 at 22:54
Gday Dave.
Not a dig mate, just a bit of advice from someone who has seen stuff not do its job properly.
I've seen a 2 tonne rated ratchet strap snap, and all it was holding was a 400kg piece of pipe. The force that snapped the stap was the pipe moving as a truck went around a corner. Thats why i said gravity is a bitch.
The 6 ton hook will more than likely be overkill for winching...well maybe just a tad:):).
It becomes a real pain for us, when it is left up to us to decipher what all the SWL and WLL stuff means. It would be so much easier if there was a clear and concise law with regard all of the recovery equipment we use. But, at the least, go with the brand you trust.
mewo.
rick.
FollowupID: 482285
Follow Up By: geocacher (djcache) - Tuesday, Feb 13, 2007 at 22:59
No worries Rick,
No offence taken. I've seen what happens when the tie down fails and the pipe goes through the car that got hit....
FollowupID: 482287
Reply By: geocacher (djcache) - Thursday, Feb 15, 2007 at 22:33
From an enquiry to the Warn website.
Good day Dave,
Thank you for visiting the Warn web page.
We use a 3/8 inch clevis hook with our 9000 and smaller winches. This hook has a breaking strength rating of 21,600 lbs.
Best regards,
Steve Schoenfelder
Warn Industries
503-722-3009
steves@warn.com
AnswerID: 221985
