Airconditioning
Submitted: Thursday, Feb 15, 2007 at 18:40
travellingblooms
I have a 100 series GXL Landcruiser (99 model).
We had the aircon re-gassed 9 months ago as it was not cooling properly. The repairer tested for leaks and it came up ok. The aircon is again not cooling properly. Is this common in Landcruisers, and if the dye test came up ok, what else could be causing this.
TB
Reply By: chardthechippy - Thursday, Feb 15, 2007 at 18:54
I find on hot days my air-con wont cool as
well as others and I just put it down to the size of the car and all the glass. I had my windows tinted and run the air-con on recirc and found it work very
221933
Follow Up By: Member - jeff M (SA) - Thursday, Feb 15, 2007 at 21:58
Had the same problem after the air con was degased and regased for some reason can't remember.
The air con would work great say at 32 degree day but when it got to 37-40 no air con.
What was wrong was the gas pressure was too high in the system so when the temp went up the air con go out in overload.
Too much refrig gas in the system.
Once the excess gas was removed it would freeze the balls of a billard table.
Hope this may help
C YU Jeff M (SA)
482746
Follow Up By: Member - Davoe (Nullagine) - Friday, Feb 16, 2007 at 19:08
No chardthechippy that aint right I drove the work triton from
Nullagine to
newman the othr day 45 degrees pluss in the shade (47 in
Nullagine, 45 at
Bonney downs) and i had o keep opening the window to let some warm air in as i was freezing with the aircon on minimum
482956
Reply By: travellingblooms - Thursday, Feb 15, 2007 at 19:44
Thanks, but this is not the problem. I am talking about the air from the vents not being cool at all
TB
221943
Reply By: Andrew from Vivid Adventures - Thursday, Feb 15, 2007 at 20:16
Hi there bloomin' travellers...
I have the same vehicle and on *really* hot days and after really hot running the compressor temp cut-out would activate and the air con wouldn't cool the air.
Solution was quite easy and has worked for about a year - put a $50 thermatic fan on the outside of the radiator - there's really room for two, which I probably would do if I were doing it again. Didn't take much effort at all, and your mechanic could do it in a heartbeat.
It is surprising the repairer couldn't make this suggestion himself ...
Anyways, it worked for me.
Andrew.
221953
Follow Up By: Member - Davoe (Nullagine) - Friday, Feb 16, 2007 at 19:10
you dont have to spend 50 bux just unplug the plug that cuts the aircon out it plugs in where the top hose meets the block
482957
Follow Up By: Andrew from Vivid Adventures - Friday, Feb 16, 2007 at 19:23
um ... it is a over-temp cut-out switch or over-pressure switch - I can't recall which.
By spending $50 and keeping it cooler with a little more air flowing around it, it has been working much better ...
Are you saying that I should just let it overheat?
482959
Follow Up By: Member - Davoe (Nullagine) - Friday, Feb 16, 2007 at 19:34
naa thats the work vehicle fix however a tojo should be OK I wuld be looking at the radiator and the fan clutch before adding a fan
482961
Follow Up By: Andrew from Vivid Adventures - Friday, Feb 16, 2007 at 19:44
Thanks Davoe - I guess that is why buying ex-
mine site vehicles can be a little risque ;-)
Anyways, radiator and fan clutch were working fine ... it is just that the temp was *very* hot and the cooling system couldn't keep up (for the air-con) - the car itself was not overheating despite 14 hours on the bitumen on 40 degree day (Feb last year, Alice-
Adelaide). It's been fine since fitting the fan.
482966
Reply By: mark I - Thursday, Feb 15, 2007 at 20:33
I just had my Air con serviced to day. I had it serviced 3 weeks ago and it came back running worse than when it went in. When questioned the repairer he told me the TX (?) valve was stuffed and it was going to cost about $300 to fix , I was not a happy man with that diagnosis so i went to a couple of other Air con specialists and they both said it was probably not the said valve
I took it in this morning and they replaced the Drier and cleaned out the condenser they also cleaned the leaves out of the fan box, it is now running on 5 deg and there is no need to run it flat out. It cost $180 . The vehicle is a Courier.
Mark
221955
Follow Up By: Member No 1- Friday, Feb 16, 2007 at 08:05
???why did they replace the drier.....
beware cos this is or could be an industry rip-off...
you do not need to get automotive aircon systems and components changed unless something is faulty......yes driers can block up...but why did it?..they the systems are supposed to leak tight..nothing gets in or out...so what has blocked the drier?....
my experience....most automotive airconditioning specialists ( add in SO CALLED somewhere) should not be ARC approved...they have no bloody idea on how a aircondiioning system is supposed to operate.
482817
Follow Up By: brad1972 - Friday, Feb 16, 2007 at 20:50
Driers contain silica beads to absorb moisture as
well as filter the system and trap worn metal etc from the compressor so yes mate driers do block up, plus ac hose is porous (most hose for that matter) so eventually gas does leak out.Under the legislation in nsw you must replace the drier when servicing an ac system and top ups are no longer allowed.
Brad
482988
Follow Up By: Member No 1- Saturday, Feb 17, 2007 at 09:34
did the drier block up or was it short of gas? is what i want to know...Mark makes it sound like the drier maybe was at fault.
and most driers today do not use silica....its alumina...and or generally consists of a blend of dessicants.
Brad, all states are under the same legislation if you didnt know.
483092
Follow Up By: mark I - Sunday, Feb 18, 2007 at 19:10
No 1
I have been away for the weekend and have only just seen your response.
The Air con was working ok to start with. I do believe that the first so called specialist I went to did rip me off. I thought that after 6 years that it could do with a service, To start with they told me there was 50% more gas in the system than there should have been and this was putting pressure on the system. when I got the car back it was ok at idle but when I was driving the temp went up. I did take it back the next day this is when he told me TX valve was not working properly , I was not happy that he wanted more money fix a problem that was not there to start with. This is when I started to look for more advice, I went to 2 other air con specialists and they both said it was not the TX valve and I should start with changing the drier as it was 6 years old and should have been done with a service . they told me that the drier was blocked and the condenser needed a blow out and clean. the person I ended up using only did Air and nothing else, I had to trust someone and what he told me sounded plausible any way he fixed the problem. I have just driven from Byron to
Newcastle and back over the weekend and the AC was on the whole time and worked beaut . I have learnt a good lesson ,dont use a local garage with no experience .I think they buy these fancy looking bits off equipment and have not a clue what to do.
Mark
483346
Follow Up By: Member No 1- Monday, Feb 19, 2007 at 07:39
airconditioners dont need a service unless they are not working correctly. they may need checking by someone qualified to ensure all is ok.
sounds you like you got stiched up..
refrigerant leaks out of the system , not into it...so how did you end up with 50% gas afetr 6yrs.......sounds like you might have a .fitch & hiclones' fitted hahahaha.
if the aircon was working ok the drier certainly wasnt blocked.
condensers do block up but if your driving habits/conditions hadnt changed prior then it may not have been the condenser being dirty.
My best guess is that the first guy you took it to for a "service" overcharged the system.
once you have it working ok and,
if its cold inside,
and the large pipe at compressor is cold then your aircon is mostly OK.
483429
Reply By: Member - Olcoolone (SA) - Thursday, Feb 15, 2007 at 22:02
What you have to determine if it is lack of condensing or low refrigerant charge.
With 100 series you have to be very precise on the refrigerant charge, more so than other vehicles due to the way the air con is designed.
The easiest way to determine if the air con system is over charged is to place a garden hose on spray over the condenser, if it get cold inside then it may be over charged......or lack of air flow (hence radiator fan).
With the air flow issue try travelling at 60Kph and see if it gets cold, if it doesn't then its not a condenser problem.
With the gas side of things when spraying the condenser fell the large pipe at the compressor, if its cool to warm then the may be a restriction in the system or low gas charge, if its very cold to touch then there may be a heater problem.
With the dye test it comes down to how hard or capabilities the person doing the job is, the most common areas we see leaks in 100 series is the evaporator or the front seal on the compressor.
It is really surprising how many people we have who come in who have just had the air con "so called regased by the so called expert down the road" who has problems, it seems they are happy to take your money and tell you it needs a so called regas but when there is a another problem they are stumped.
Where abouts are you and I may be able to put you in contact with someone who knows what they are doing.
Regards Richard
Hope this helps
221978
Follow Up By: Member No 1- Friday, Feb 16, 2007 at 08:23
the easiest way of telling if a system is overcharged is to stick gauges on it!
"With the air flow issue try travelling at 60Kph and see if it gets cold, if it doesn't then its not a condenser problem." .....????
you are of course making assumptions as to cleanliness of the coil, un-damaged tubing causing refrigerant restriction etc etc etc all of which, which are potential condenser problems ...a blocked condenser restricting airflow may not even work at 100 k/h
482820
Follow Up By: travellingblooms - Friday, Feb 16, 2007 at 10:51
Thanks Richard,
I had it checked this morning and the repairer said he could detect no leaks but afterlooking under the dash, he found the evaporator to be the problem. It appears a new evaporator is required total cost $480. Does this sound fair enough??
I am in
Brisbane.
TB
482850
Reply By: Member - Karl - Friday, Feb 16, 2007 at 09:50
Just had the air con on my 80 Series fixed - it was just blowing air - not cold.
It turned out that the hose had broken and all of the gas had leaked out. Hose was replaced and re gassed and is now working fine.
Karl
222055
Reply By: SA_Patrol - Friday, Feb 16, 2007 at 17:39
Bring back R12 gas i don't think R134a is as good or what ever else they recommend these days, yes i know the ozone layer is gone , but maybe the cows destroyed that many years ago. :-)
222138
Follow Up By: Member No 1- Monday, Feb 19, 2007 at 07:43
134a works ok
it is not as efficient in a system designed for r12.
get a new car with the aircon system designed for 134a, or try a blend such a r43, sp34e, or r413 or r49. all non flamable
483430
Reply By: Member - Olcoolone (SA) - Friday, Feb 16, 2007 at 21:27
Unfortunately just sticking gauges on a air con system will not tell you if it is over charged or under charged.
The first thing to do is service the air con and by doing this it gives you a bench mark to work from.
With nearly all Toyotas 10 years or newer, trying to sort out condensing issues can be hard due to the fact that the condenser has a sub cooling section attached, this is were the difference comes into it of someone understanding the components and how they are meant to function and some one who does REGASING or TOPUPS.
Life was so simple years ago when you could just add or remove a bit of refrigerant and get the system working.
The systems these day are getting very complex in there design and operation.
R12 is no better or worse than R134a, it does not leak any quicker and performance on a correctly designed R134a system out performs the old R12 systems hands down.
$480 for the evap job sounds fair, that would be close to what we would estimate the job to be......(but my friends brothers next-door neighbours sisters....you know the story.......got it done by GFTTGGHUJJJIIKK who no longer is in business for $240.00 plus a trip to
Perth and $1000 spending money.)
In air conditioning there are known professionals and I THINK I AM professionals, ask around who does good work and warrants it, not whos the cheapest.
The hardest thing is educating the public.
Regards Richard
222191
Follow Up By: Member No 1- Monday, Feb 19, 2007 at 07:51
"Unfortunately just sticking gauges on a air con system will not tell you if it is over charged or under charged."...WHAT a load of ! ...ooops just read all you reply ....but sticking ones gauges on the unit and taking temps (of liquid line) at end of condenser will tell you if its overcharged....
r12 is a more efficient refrigerant than r134a...meaning one gets more refrigeration for same input.
483433
Reply By: Member - Olcoolone (SA) - Friday, Feb 16, 2007 at 21:49
I can not more with "brad 1972" (Driers contain silica beads to absorb moisture as
well as filter the system and trap worn metal etc from the compressor so yes mate driers do block up).
The other reason we replace driers every 2 years is when moister and refrigerant mixes it turns into an acidic acid and corrodes alluminiun, your air con system contains about 95% aluminium.
If the drier is more than 5 years old we also see the filter mesh inside the drier corrode, when this happens the desiccant beads in side the drier gets released into the system blocking the liquid line and tx valve. The only way is to replace the liquid line (in most cases a factory item) and tx valve.
So for the sake of saving $30 to $70 for a drier for most common vehicles is it worth the risk.
Real professional air con people get a bad deal from the general public, we get accused of ripping people off or we are to expensive because the guy down the road can do it for half the price because he does quarter the work.
I would sooner see the customer leave and go elsewhere because we are to expensive than lower our standard.
Believe me I am very very passionate about this subject.
Regards Richard
222199
Follow Up By: Member No 1- Monday, Feb 19, 2007 at 09:07
The moisture content in virgin refrigerant has a very low ppm. the initial refrigerant charge would be dry after having passsed thru a new drier once!
if you evacuated the system properly (and i mean properly!!) where did the moisture come from? if the system is leak tight it cant get in.....
yes moisture in a system creates acids and sludge and eats away at metals, all of which will block a drier....but in a properly evacuated system semihermetic system moisture at time of and after manufacture should not be a cause of concern....assumes a system has never been touched once it leaves the assembly line. ....the cause of moisture/and or acids entering the system after manufacture (excludes imporoper evacution etc at time of manufacture, a system breakdown and subsequent repair) is the service centre checking system pressures with wet/contaminated gauges.
483442
