Mercedes Spinter - Air suspension kit
Submitted: Monday, Feb 19, 2007 at 17:55
ThreadID: 42489 Views:3327 Replies:3 FollowUps:5
Any advice please on fitting, usefulness, and best brands of air suspension kits for the rear springs of a LWB Mercedes Sprinter van? Van is a 1999 214D. Thanks, Keith
Reply By: Member - Doug T (W.A) - Monday, Feb 19, 2007 at 21:17
www.airbagman.com.au/
AnswerID: 222769
Reply By: Eric Experience - Monday, Feb 19, 2007 at 22:15
Solly.
Interesting question, are you going for softer or firmer springing? There are a range of factory springs available. Because the van is so tall the springs have a heavy sway bar fitted. Just by removing this bar you can soften the ride but reduce your cornering speed. If you were to go to full air suspension you would have to engineer a complete new suspension,if you go that way I will be very interested in helping you as I have considered this and decided it was to hard to fit it all in. Eric.
AnswerID: 222793
Follow Up By: Solly - Tuesday, Feb 20, 2007 at 07:34
Hi Eric, The reason for considering this modification was only to give extra lift for gutters or creek crossings. So no change to existing suspension which I am very happy with on the road, just the possible addition of air bags so I can lift the rear. The Sprinter has a long overhang. Keith
FollowupID: 483668
Follow Up By: Eric Experience - Tuesday, Feb 20, 2007 at 20:56
Solly.
Quit agree, I've got 110 mm spacer between spring and axle and an extra 110mm length rod on the brake control valve, plus 16 inch wheels with 235/85 16 silent armers. This gives me more ground clearance than a troopy. Eric.
FollowupID: 483834
Follow Up By: Solly - Tuesday, Feb 20, 2007 at 21:40
Hi Eric, Interesting. One final question please. How is highway handling? I assume being higher would affect stability a bit. Keith
FollowupID: 483858
Follow Up By: Eric Experience - Tuesday, Feb 20, 2007 at 22:29
SOLLY.
The extra hight must effect it but I have not had any problems so far. I did a very fast trip from Alice Springs to Melbourne in 30 hours driving time, handles ok at high speed. Eric.
FollowupID: 483885
Follow Up By: Solly - Tuesday, Feb 20, 2007 at 22:48
thanks Eric.
Keith
FollowupID: 483890
Reply By: lindsay - Tuesday, Feb 20, 2007 at 10:29
buy a landrover!
AnswerID: 222870
