Battery corrosion problem
Submitted: Wednesday, Feb 21, 2007 at 21:27
ThreadID: 42569 Views:2218 Replies:3 FollowUps:7
I have dramas with the corrosion on the positive termal of the battery as well as down the side of the battery. The battery is a Supercharge 13 plate seal battery. I always make sure that there is that anti corrosion and contact goo stuff you get from Supercheap. The battery was previously in my Fathers Rodeo and know is in my Terrano. When it was i the Rodeo there was no problems with the battery.
Has anyone got any ideas or suggestions on how I can get this to stop?
SantaAus
Reply By: ZukScooterX90 (QLD)Member - Wednesday, Feb 21, 2007 at 21:39
Sounds like it maybe RS. Had a similar problem about a month ago.:o))))
AnswerID: 223252
Follow Up By: On Patrol (Aust.) - Wednesday, Feb 21, 2007 at 21:41
OK whats RS, I know what RSI is however, are they similar???
FollowupID: 484108
Follow Up By: Member - Oldplodder (QLD) - Wednesday, Feb 21, 2007 at 21:45
RS - big brother to mouse poo. Rat sh?t.
Havn't overfilled the battery a little?
FollowupID: 484111
Follow Up By: SantaAus - Wednesday, Feb 21, 2007 at 21:50
Funny Oldplodder, What is RS????
Can't over fill the battery she is sealed.
FollowupID: 484117
Follow Up By: Member - Oldplodder (QLD) - Wednesday, Feb 21, 2007 at 21:58
Sorry, thought you would have come across it, especially if you are in a trade.
RS,rat sh--,coloqualism for stuffed, no good, goner, useless, etc.
FollowupID: 484124
Follow Up By: ZukScooterX90 (QLD)Member - Thursday, Feb 22, 2007 at 19:20
Onpatrol,RS is what Oldplodder said.You know were not allowed to swear.:O)))Lol
FollowupID: 484284
Reply By: Eric Experience - Wednesday, Feb 21, 2007 at 22:55
SantaAus.
Sounds like it is over charging, measure the voltage after the motor has been running for about 30 mins,I.E when you get from the shops leave the motor running and measure the voltage, if it is more than 14.6 you have the problem. Eric.
AnswerID: 223277
Follow Up By: SantaAus - Wednesday, Feb 21, 2007 at 23:07
Thanks Mate, I will have a look at it.
FollowupID: 484148
Follow Up By: disco1942 - Wednesday, Feb 21, 2007 at 23:25
Is the problem that the Terrano should have one of the new type Calcium batteries and you have fitted one of the older style batteries that requires a lower charging voltage? Check to see if it is the correct type for your vehicle.
FollowupID: 484152
Reply By: Member - Brian H (QLD) - Thursday, Feb 22, 2007 at 00:02
Had a similar situation in my Rodeo, positive terminal getting corrosion all the time. I just placed a 2mm peice of polycarbonate cut out to fit over the terminal so the connector to the terminal was not touching the battery with vasoline on the terminal and connector. No more problems.
I had tried with just vasoline and no polycarbonate and still corroded. No corrosion now for over twelve months :). May not be whats the problem is with yours but maybe worth trying if what else has been advised here is not causing the problem.
Brian
AnswerID: 223293
