tyre s &trip meter
Submitted: Friday, Feb 23, 2007 at 11:16
ThreadID: 42616 Views:2397 Replies:3 FollowUps:0
G/Day All, running differant profile tyres has made my speedo out ,100kys on speedo=105 true speed,how wil this effect my speedo trip reading,will 1000kys on trip meter=1050kys actually travelled, trying to work out fuel consumption,& naturally the 1050 gives me better braging rights, is it this simple,Friar.
Reply By: kingswoodwagon - Friday, Feb 23, 2007 at 11:47
Friar,
yes, you are right.
this is the case whern you tyre circumference increases.
To calculate the difference - measure the circumference of both new and old tyres (when fitted to rims)
Divide the new (eg 193cm) by the old (eg 184cm) and the result eg 1.05 = 105% of the old speedo/odo reading - 5% increase
Discliamer : i made all this up ( do your own research before following my advice)
AnswerID: 223515
Reply By: Kumunara (NT) - Friday, Feb 23, 2007 at 11:49
Friar
Similar problem with my speedo and odometer both being out. I use the GPS instead. I suggest that if you want to work out your fuel consumption etc accurately get a GPS
Tjilpi
AnswerID: 223516
Reply By: Robin - Friday, Feb 23, 2007 at 11:53
Hi Friar
You don't say what sort of car !
The speedo and the tripmeter generally have different error rates deliberately.
Normally, like on patrols, the speedo reads high (reads 100kph when doing 95)
but the odometer stills reads accurately.
Can get cheap electronic kits to change ratio back when
fitting bigger tyres. I have done this , but in practise
find it easier to use a gps as per Tjilpi for fuel consumption figures as
its more accurate and doesn't require changes.
Robin Miller
AnswerID: 223517
