Removal of lcd televsion stand
Submitted: Monday, Feb 26, 2007 at 22:23
boatman
I bought a Digitor 17" lcd for my caravan and wish to use a wall bracket on the back. I need to remove the stand. The guys at Dick Smith could'nt help, they said leav it on which makes it a bit impractical to swing around with a daggy stand hanging from it. Anyone got an isea hoe they come off?
Reply By: Member - Alanc - Tuesday, Feb 27, 2007 at 01:10
The Palsonic I purchased for our Van had two screws on the back fixing the stand, When the stand was removed the screw holes lined up with pre drilled holes on a wall bracket I brought. Ended up not using the wall bracket because it did not really fit where we wanted to install it and I was concerned how it would travel permanently attached to the caravan wall. Our caravan TV is now "free range" in that we can shift it around to suit our purposes in and out of the caravan and in the house. Sorry , did not really answer your question.
224228
Reply By: Pajman Pete (SA) - Tuesday, Feb 27, 2007 at 08:03
Angle grinder?
224248
Reply By: TerraFirma - Tuesday, Feb 27, 2007 at 13:43
The stand must come off I would have thought, they don't usually ship LCD's with stands attached, perhaps that has changed nowdays. No idea with Digitor, isn't that a Dick Smith brand..?? Can you see any screws..??
224319
Reply By: Member - JohnR (Vic)&Moses - Tuesday, Feb 27, 2007 at 13:52
Should be four screws if it was meant to come off. They are usually made with 75mm or 100mm centres and often both.
224326
Follow Up By: Shaker - Tuesday, Feb 27, 2007 at 14:54
It also could have keyed holes like a computer monitor.
485212
Reply By: Member - John R (NSW) - Tuesday, Feb 27, 2007 at 14:23
Boatman, if the stand has no visible attachment, it may require you to remove the back cover from the unit. The screws may be behind it.
If it's moulded from one piece, you could get yourself a Dremel and cut it off/polish out any evidence..... I have a Dremel and it's a magic bit of kit :-)
224334
