NP Pajero - potential problem when towing
Submitted: Monday, Feb 26, 2007 at 22:41
TripleC
Hi All,
I just thought I would let you know about a problem I experienced with my 2004 NP Pajero, which I have since found out Mitsubishi have known about since atleast April 2006, and don't appear to readily provide details on.
After a fairly short trip to tow our caravan to the storage yard I noticed a very strong smell of oil, and noticed it all over the drawbar & chains. A quick inspection under the back showed oil sprayed all out of the rear diff. Now I thought this was related to a plug & seal not being done correctly on a service, but found out it is relating to a know problem to Mitsubishi. It also appears that they fixed the problem on manufactures after late Oct 2005 (so it must have been known then???)
It appears that the companion shaft can come loose from the rear diff when it is under loads, such as towing, causing a huge loss of oil. On seeing the approx. 5mm gap I think it is also a potential point for dirt & mud to get in & cause damage if we were either off road, or in central OZ dust, not to mention what a long haul with a huge oil loss would have done.
I rang Mitsubuishi NSW office, and they were less than helpful, so I thought I had better let a few people know, just incase you have either experienced this issue, or do a lot of towing, or off roading, as you might want to check if your NM/NP build is effected.
TripleC
Reply By: Member - Oldplodder (QLD) - Tuesday, Feb 27, 2007 at 09:06
Thanks,
Have you posted this on the Victorian pajero club
forum ?
forum.pajeroclub.com.au/forum/
A lot of aussie pajero owners read that
forum.
224268
Reply By: TripleC - Tuesday, Feb 27, 2007 at 13:35
Hi Oldplodder,
Thanks for
the tip, but one of the Paj Club
forum members beat me to it, and copied my post from the OL site.
Craig
224315
Reply By: donks1 - Tuesday, Feb 27, 2007 at 17:48
hi there craig
i USED TO work for a mitsu dealer and never came across this problem
although i don't work there any more, ( gone to audi ) i'm interested.
5 mm seems a lot
don't suppose you have any photos
donks
224386
Reply By: suepajero - Tuesday, Feb 27, 2007 at 21:35
Hi TripleC, Just want to know,what do you mean,companion shaft ?Do you mean prop shaft or axle oil seels cheers Sue
224451
Reply By: TripleC - Tuesday, Feb 27, 2007 at 22:02
Hi Donks,
Sorry, but I headed to the dealer pretty quick, and it wasn't until they put it up on the hoist and showed me the problem there, and I didn't have the trusty camera with me.
Sue,
The companion shaft is the axle housing that connects to the diff housing. If you look under at the rear axle construction you will see the diff in the centre, and then the left & right axle connect to it. It is at that connection to the diff that it came apart.
Regards,
Craig
224465
