Shentai st30 emergency tool kit
Submitted: Wednesday, Feb 28, 2007 at 00:05
ThreadID: 42776 Views:2337 Replies:9 FollowUps:5
Anyone have any good or bad experience please tell.
Cheers Steve Top End Explorer Tours.
Reply By: Bilbo - Wednesday, Feb 28, 2007 at 00:45
Wot is it??
Bilbo
AnswerID: 224494
Follow Up By: Oldsquizzy (Kununurra) - Wednesday, Feb 28, 2007 at 01:54
12 volt zoom zoom gun (1/2 inch impact ) RACV use and sell them, They reckon they are all right
FollowupID: 485411
Reply By: smort - Wednesday, Feb 28, 2007 at 06:36
Hi Steve
no connection with product or its promotion
I have had one for about a year - used it infrequently - with a 1/2" to 3/4" adapter - removes and replaces wheel nuts on my isuzu 4wd truck without the usual backbreaking effort.
Gets my recommendation from experience
Hope this helps
AnswerID: 224500
Reply By: Member - Phil B (WA) - Wednesday, Feb 28, 2007 at 07:12
Great bit of kit, had mine about 2 years no problems in removing wheel nuts.
I also used it to remove other nuts around the vehicle and if you're not careful it will snap them off, it has that much torque.
AnswerID: 224501
Reply By: Member - MrBitchi (QLD) - Wednesday, Feb 28, 2007 at 09:02
Got one. Love it.
DON'T use it to tighten wheel nuts!!! Should ALWAYS do that by hand.
AnswerID: 224515
Follow Up By: Juzzy - Wednesday, Feb 28, 2007 at 09:20
Thanks for that tip.
I just bought one the other day and was going to do some testing this weekend.
FollowupID: 485441
Follow Up By: Member - MrBitchi (QLD) - Wednesday, Feb 28, 2007 at 09:32
Your welcome. I use mine to just spin the nuts on till they just bite and then tighten by hand.
FollowupID: 485444
Reply By: Member - Beatit (QLD) - Wednesday, Feb 28, 2007 at 09:53
I have two, one in each car, I have used it a couple of times and found it very good. The small red light is actually useful in the dark and I reckon even the bride can use this. Was thinking that I'll have to invest in their jack as well - saw them advertised the other day. Seem to work on the same principle but not sure it is high enough for the Nisan.
Kind regards
AnswerID: 224523
Follow Up By: ZukScooterX90 (QLD)Member - Wednesday, Feb 28, 2007 at 21:28
Beatit,i would tend to not bother with jack (elec) as it only just lifts the one wheel on the x90. Tried it under the back wheel of the f truck & the top part that sits under the axle bent inwards.:o)))
FollowupID: 485585
Reply By: Gerhardp1 - Wednesday, Feb 28, 2007 at 11:39
Add my endorsement to this product.
Ever tried getting the diff nut undone to replace the seal?
This baby just laughed at it, and I was overjoyed as well. :)
As mentioned, don't do up your wheel nuts with it. The little "clack" it emits when hammering is totally deceptive, as is the lack of any feedback to your hands.
Brilliant!
AnswerID: 224535
Follow Up By: V8Diesel - Wednesday, Feb 28, 2007 at 14:21
+1.
Using a cheater bar on a diff is awkward to say the least.
FollowupID: 485495
Reply By: revhead307 - Wednesday, Feb 28, 2007 at 13:52
Ive had one for 18 months and I love it. Saves lots of effort.
Gets used once every few months I suppose.
Jeff
AnswerID: 224560
Reply By: Member - MrBitchi (QLD) - Wednesday, Feb 28, 2007 at 16:41
One other comment.....
The supplied sockets are rubbish. Have so far destroyed 2 of them. Replace them with some quality impact sockets and you'll be fine.
AnswerID: 224594
Reply By: Member - Pesty (SA) - Wednesday, Feb 28, 2007 at 22:20
Had one for about 3 years and use it all the time with 5 vehicles and 5 trailers, but you will need to replace socket with good quality one,
Use mine to tighten wheel nuts too, but double check them when done.
Cheers Pesty
AnswerID: 224674
