me old magellan gps has packed it in.
Submitted: Wednesday, Feb 28, 2007 at 14:26
ThreadID: 42789 Views:7471 Replies:10 FollowUps:15
hello everyone,
I have a magellan 310 gps that won't hook onto the satellite's, I haven't used it for a while and when I turned it on it just keeps tracking being over half a hour now. I have had it for about four years.
Reply By: Leroy - Wednesday, Feb 28, 2007 at 15:03
Peter I have a 315 and if I haven't used it for a while and if I move to another location epecially and turn it on it takes for ever to lock on to satelites. Once it has locked on to them it's fine. I'm sure it takes over 10mins to do this sometimes and I see you said you had yours on for 30min but did the gps have a clear view of the sky above?
Leroy
AnswerID: 224580
Reply By: Member- Rox (WA) - Wednesday, Feb 28, 2007 at 15:07
Try Ringing Next Destination in Perth They are the agents (08) 9444 0233
AnswerID: 224581
Follow Up By: kampen - Wednesday, Feb 28, 2007 at 16:28
g'day Rox,
thanks for that, I rung them and they were very helpful, went through the process and now it is out side tracking, here's hoping. Lucky I was going to through it away. thanks again.
Peter.
FollowupID: 485512
Follow Up By: Leroy - Wednesday, Feb 28, 2007 at 20:12
and the process was?
FollowupID: 485559
Reply By: Bilbo - Wednesday, Feb 28, 2007 at 16:39
It's only a matter of time before my Magellan 315 fails in this manner. One day it will.
It happens progressively as new sotfware is uploaded to the nav satellites and the older GPS models can't hack it anymore.
So far I've binned 2 GPSs since they first came out around 1987. I now have a 315 and a much newer Magellan Explorist 210. The 315 is next I reckon.
Bilbo
AnswerID: 224592
Follow Up By: kampen - Wednesday, Feb 28, 2007 at 16:50
yep, I think mine might have come to it's use by date. It's not working with the info they gave me. still I will keep trying in hope it might grab aomething up there.
It seems to lock on to about stellite's but want start up. i will give them another ring.
FollowupID: 485517
Follow Up By: Willem - Wednesday, Feb 28, 2007 at 19:11
My 315 did that a while ago. Would start up but could not locate Satellites. Left it for an hour of driving and still nothing. So switched it off in disgust. Next day I fired it up again and Bingo everything was working again. Since then it has performed faultlessly. I use it regularly to give me accurate speed readings. It is a 2002 model but how long the shelf life is, will remain a mystery. It will probably kark it tomorrow...lol
FollowupID: 485542
Follow Up By: Richard W (NSW) - Thursday, Mar 01, 2007 at 06:27
Happened to my 315 about 3 years ago which was 3 years after I bought it sent to WA to be re-tuned and has worked fine ever since.
Touch wood.
FollowupID: 485644
Follow Up By: The Explorer - Friday, Mar 02, 2007 at 01:07
"It happens progressively as new sotfware is uploaded to the nav satellites and the older GPS models can't hack it anymore. "
Hello - doubt if this is the case - proven by fact that gps units identical to yours still work. More likely just requires some patience, possibly some firmware glitch or maybe harware failure. Newer units do have improved antennas, ability to track more sats and better power consumption (etc) but still feed off same data as delivered from sats "in the beginning" AFAIK.
FollowupID: 485816
Follow Up By: Bilbo - Friday, Mar 02, 2007 at 01:21
Exploder,
I'm only repeating what happened to my first 2 GPSs years ago. Magellan in Osborne Park were quite good about and did fit upgraded EPROMS, new software etc, all for free. But eventually, they just couldn't upgarde anymore and they no longer functioned at all.
In the bin they went,,,,,,,,
Bilbo
FollowupID: 485817
Follow Up By: The Explorer - Friday, Mar 02, 2007 at 02:03
Just recalled the issue with the change over to year 2000 aka y2K (the so called end of the century but a year early). Some older units did not have the ability to give correct time and/or function after this date (31/12/1999)..the magellan Nav 5000 we had at work (in a box in draw) still functioned but date/time was wrong...this is obviously not an issue now if the unit worked after this time...just thought Id mention it
FollowupID: 485820
Reply By: hoyks - Wednesday, Feb 28, 2007 at 19:17
I just fired up my GPS300 and I think it might not just be yours.
It has been hanging off the clothes line for 10 minutes and it still thinks it is at Barrington Tops where I used it a few weeks back.
Might need to go shopping.
AnswerID: 224624
Follow Up By: hoyks - Wednesday, Feb 28, 2007 at 19:21
You could also have a look at the Magellan website if you have lost the manual. They have them on-line for 'obsolete produsts':
Site Link
FollowupID: 485544
Follow Up By: hoyks - Wednesday, Feb 28, 2007 at 19:24
Well, I had to leave it for 20 minutes and then it hooked on to enough sats to tell me that it was in the back yard rather than the front, so all may not be lost.
FollowupID: 485545
Reply By: Alan S (WA) - Wednesday, Feb 28, 2007 at 22:27
Not one to quote search the archives but check post 12314, there is a detailed set of instrcutions how to reset a 310.
I saved it because i have a 310 and some times needed to reset it.
AnswerID: 224676
Follow Up By: kampen - Thursday, Mar 01, 2007 at 19:38
thanks Alan,
I have been talking to them in perth and please to say it is up and running. they were very helpful. I thought it was ready for the recycle bin.
Peter.
FollowupID: 485760
Follow Up By: Leroy - Thursday, Mar 01, 2007 at 19:50
and what did them in perth say was the problem?
FollowupID: 485763
Follow Up By: kampen - Monday, Mar 05, 2007 at 21:19
Hi Leroy,
Sorry taken so long. them been Next Destination, had to clear it all and start from scratch. You hold the right hand arrow key and the power button at the same time. Take's a few time's to get it but will come with do you want to delete all Yes or No. Push yes and then turn back on, set time and leave it outside to pick up the satellites. Took a while to pick them up, about 30 minutes. Going great now.
FollowupID: 486424
Follow Up By: Leroy - Tuesday, Mar 06, 2007 at 13:21
thanks for that - a handy bit of info.
Leroy
FollowupID: 486528
Reply By: kingswoodwagon - Thursday, Mar 01, 2007 at 01:04
Peter,
i have an old magellan i pull out of the cupboard every few years.
i literally put it up on the roof to initialize - it needs an unobstructed view. otherwise it takes hours.
Cheers.
AnswerID: 224694
Follow Up By: equinox - Thursday, Mar 01, 2007 at 22:46
Thats not the original brick is it kings?
I remember seeing that first on Beyond 2000 and later used it with Western Mining 92 and 93.
FollowupID: 485791
Reply By: smort - Thursday, Mar 01, 2007 at 06:20
Hi all
only thing I havent heard so far is upgrade software
I have an old etrex that refuses to die
I have upgraded the software a couple of times from the Garmin netsite via serial cable
Maybe this is the difference - dont know
If there has been a large shift in gps position (1000 ks or so) from last use unit takes a while to find sats - did it when I switched it on for the first time as new and still does it - maybe nothing is wrong
Hope this helps
smort
AnswerID: 224705
Reply By: Old Gold - Thursday, Mar 01, 2007 at 09:42
I had the trusty 315 but alas the poor wee thing chucked it in awhile ago so i updated to the 600 wonderful bit of gear it is to
AnswerID: 224723
Reply By: pprass - Thursday, Mar 01, 2007 at 13:25
You may know this already, but there is an almanac in the GPS that keeps track of the satellites that it expects to see when the GPS is turned on. This allows it to quickly lock on expected satellites and away it goes. If the GPS has been turned off for a long period of time or it has been moved by more than 500km from the last time it was on, then that almanac is out of date and it takes ages for it to re-establish connection with the current satellites that are overhead.
The simple way to get it going in this situation is to do an "Initialization" ofthe GPS, where you basically tell it where you are and what time of day it is.
AnswerID: 224755
Reply By: AdrianLR (VIC) - Sunday, Mar 04, 2007 at 15:32
I have a 315 (so far so good, fingers crossed that it stays that way!) I read somewhere that it has an inbuilt battery to keep the almanac live. If you store the unit without batteries or they go flat then the onboard battery dies. I guess that with fresh AAs it will recharge making warm starts quick but I wonder if when the onboard one really dies than even a warm start takes a long time.
I haven't looked recently but have Magellan released new firmware that has a GDA96 datum?
Adrian
AnswerID: 225220
