AnswerID: 224908 Submitted: Friday, Mar 02, 2007 at 11:53
Dustin
replied:
Ring around your local Toyota dealerships and wheel sellers, the base model LC comes with split rims and are often disguared on purchase, these are a nice narrow rim and sit up well under the body. The are often on ebay too for about $10 each.
All I usually do is take the spare off and chuck it in the back when we go out for the day, up on the roof rack for longer trips. A rock damaged $280 lesson makes sure it never stays underneath when going off road.
Reply 6 of 8
FollowupID: 485917 Submitted:
Friday, Mar 02, 2007 at 15:01
spliney posted:
In my case, mine's a 105 series, which comes standard with splits, So even though it had GXL wheels on it at purchase, I'm assuming that splits will still fit. Hence I carry a split as a spare to improve clearance. I've never actually checked! Should I??
Spliney
FollowUp 4 of 5
FollowupID: 485926 Submitted:
Friday, Mar 02, 2007 at 15:50
Member - Davoe (Nullagine) posted:
Splinely if you are running 265x75
tyres now your splits should still be the same rolling diameter which is the most important thing. if you have on 285s though they are a larger wheel. My 80 has a split as a spare. if you want to save more space you can bung a 79 seies 5.5 inch split and 7.5x16 tyre as the spare
 Click Image to Enlarge |
| You dont need to leave Perth to go bush |
FollowUp 5 of 5
