Hilux loud click on full left lock
Submitted: Saturday, Mar 03, 2007 at 04:58
ThreadID: 42870 Views:2396 Replies:3 FollowUps:0
My Hilux, & my daughters, both make a loud metalic click sound after being released from hard full left lock when steering. But not every time. Any one with a Hilux, IFS model, have the same? Anyone know what it is? Her car has 217,000km & mine 48,000km.
Reply By: Member - Bucky (VIC) - Saturday, Mar 03, 2007 at 08:01
Do yourself ( s ) a favor, do not turn anything on full hard lock, go there for a split second, then back it off a little...
It may also pay to have your " limit-locks " looked at, or greased..
They just look like bolts
They are located on the inside of your front wheel hubs, on the backing plate, ( my Navara has 2, front and rear, on each ) and their job is to stop you turning the wheeels too far left or right,,
It may be as simple os smearing a dollop of grease on each and also in the slide they rub on..
If you still hear the it then have the power steering looked at
Cheers Mate
Bucky
AnswerID: 225018
Reply By: whyallacookie - Saturday, Mar 03, 2007 at 10:48
As Bucky said, My old Rocky started doing this and a dollop of grease on the limiting bolt/pin fixed it. It was worse if on full lock and moving over a bump etc.
AnswerID: 225051
Reply By: Member - Norm C (QLD) - Saturday, Mar 03, 2007 at 12:42
Another potential is CV joints. Check the boots to see that they are not damaged and letting grease out / dirt and water in. Clicking on full lock is often an early indicator of CV problems.
AnswerID: 225068
