engel fridges
Submitted: Sunday, Mar 04, 2007 at 10:47
geoffro
hi wonder if any one can help me with my engel fridge it will run off 240 watt but wont run on 12 volt in the fourby, has it had it or can it be fixed. is it expensive
Reply By: Shaker - Sunday, Mar 04, 2007 at 11:11
Might be a stupid question, but have you double checked the 12 volt outlet?
225196
Reply By: Member - Norm C (QLD) - Sunday, Mar 04, 2007 at 11:16
Also, if you are pluging into a cigarette style plug, your Engel plug probably has a fuse in it (
mine has) in the connector that converts from Engel screw in plug to cig lighter style.
Check that there is a fuse in there and that it is not blown.
225197
Reply By: Derek from Affordable Batteries & Radiators - Sunday, Mar 04, 2007 at 11:25
Hi geoffro
Have a look here. a href=" Fuse" target="EOF" class="lbg">Site Link
Derek
225199
Reply By: Hayjude - Sunday, Mar 04, 2007 at 11:33
check your wiring as you can burn it out by using fridges in the acc sockets. The standard wire is only 2 or 3 amp you need at least 6 amp for the fridges
225201
Reply By: Member - Davoe (Nullagine) - Sunday, Mar 04, 2007 at 11:33
also if you have it screwed into the genuine engal socket watch the connection -
mine is dodgey despite screwing itin the whole way
225202
Follow Up By: Member - Davoe (Nullagine) - Sunday, Mar 04, 2007 at 11:36
forgot to add cords can break internally. go buy a test light for a couple of bucks and rip off the alligator clip then you can test the plug where it plugs into the engal for power to the engal at 12v - thats where i would start first
486122
Follow Up By: Member - Phil G (SA) - Sunday, Mar 04, 2007 at 14:00
I'm with Davoe here, I've had two mates with the latest series Engels who had the pos wire break within the plastic housing of the plug that goes into the back of the fridge. We were able to cut the plug apart for a temprary fix, but best solution is a new lead.
486134
Follow Up By: geoffro - Sunday, Mar 04, 2007 at 16:59
hi guys thank for the comments but have power all the way to the fridge then nothing, im thinking it the 12 volt connection in the fridge has anyone heard of the 12 volt connection going a stray and 24 watt connection is ok
486141
Reply By: yakodi - Sunday, Mar 04, 2007 at 16:35
Check the earthin 12v oulet in vehicle
225227
Reply By: geoffro - Sunday, Mar 04, 2007 at 17:13
225233
Reply By: hoyks - Sunday, Mar 04, 2007 at 18:02
Check the polarity.
Make sure + and - are the right way around.
225244
Follow Up By: Member - DOZER- Sunday, Mar 04, 2007 at 20:44
Beat me to it.....if you have correct polarity, and the volts are there, then your inverter is no good...all older than a few years engels run 240v compressers, and actually invert the 12v.
486185
Reply By: sastra - Sunday, Mar 04, 2007 at 20:34
Had worrying experience in '97 just before
Derby on three month big trip with wife and two kids.. Thought engel had died and could see lots $$$ for new fridge for trip. Checked fuse ( glass tube type ) at battery ( fridge in back of patrol ) and looked ok. Worried went to autolec in
Derby who checked battery, charged $25 and replaced fuse which was buggered up inside metal end which was not obvious.
Good lesson replace fuse anyway to eliminate as problem. I did have spares! Doh!
225284
Reply By: Jimbo - Sunday, Mar 04, 2007 at 21:21
Another Troll.
It is a
well known "fact" that Engels never fail.
225300
Follow Up By: Pajman Pete (SA) - Monday, Mar 05, 2007 at 07:43
I agree Jimbo, this whole post is just a conspiracy to make Waeco owners feel better!
486241
Follow Up By: Member - Matt M (ACT) - Monday, Mar 05, 2007 at 14:44
Pete,
Congratulations, you have stumbled on our evil plot.
Recently the Waeco Owners With Engel Envy (WOWEE) group undertook to saturate this and other forums with trumped up Engel problems.
Seemd to be working for a bit, but back to the drawing board I guess.
Matt.
486322
Follow Up By: Pajman Pete (SA) - Monday, Mar 05, 2007 at 15:27
;o)
I won't tell anyone - promise!
Pete
486333
Reply By: whyallacookie - Monday, Mar 05, 2007 at 13:29
By your post your have checked 12V and all is OK up to the fridge. I don't know the Engels but can you easily remove a cover to get access to the insides?
Perhaps with all plugged in (12V ONLY of course) can you check on the inside at the back of the pins? Also check there isn't another fuse inside this area (perhaps someone already knows if there is or not) If there is 12V all the way to the inverter (and check each side of the fuse as it my not be obviously blown or could just have a bad connection) then as posted before the inverter could
well be stuffed. Hopefully not as I imagine they wouldn't be cheap. If all checks out OK I'd be taking it to an Engel repair centre.
225416
