Oziexplorer for PC only
Submitted: Sunday, Mar 04, 2007 at 21:28
ThreadID: 42921 Views:3121 Replies:6 FollowUps:7
Hi electron gurus,
I'm not looking at GPS for a while but I love my maps and was wondering if you thought it is still worth the cost for the software for Oziexplorer (or similar) if only to use at home.
I'm thinking topographics of small areas. How user-friendly is the software? Also there are the plot maps etc here, on Exploroz, what are your opinions?
Thanks,
Brian
Reply By: Kumunara (NT) - Sunday, Mar 04, 2007 at 21:44
BWARE
Before purchasing my first GPS I had OziExplorer and the Natmaps and I found them useful when planning a trip. OziExplorer is reasonably priced and is worth the cost.
To get the full benefit you will need to purchase a GPS.
AnswerID: 225302
Follow Up By: Bware (Tweed Valley) - Sunday, Mar 04, 2007 at 23:03
Thanks, Kumunara,
I figured value is in using GPS as well but I am happy for now if I can see a map on the 'puter screen.
FollowupID: 486219
Reply By: garrycol - Sunday, Mar 04, 2007 at 22:46
Why not try OziExplorer before you buy by downloading the trial version and trying it for a while. It works well.
Garry
AnswerID: 225314
Follow Up By: Bware (Tweed Valley) - Sunday, Mar 04, 2007 at 23:16
Umm, I have tried that the last few nights after late shifts at work and I am having a few problems LOL Perhaps I should have read the instructions first?
Am I supposed to be able to see a map that I can download on the trial version? ie I have downloaded 'Moreton Island' from the 'Trecks' on this site but can't seem to bring it up on the trial version of OziExplorer; I keep getting 'file not found' etc
FollowupID: 486223
Follow Up By: garrycol - Monday, Mar 05, 2007 at 13:59
There is a demo map attached. The map you downloaded should be able to be used but you might try scanning in a map yourself and saving it as a BMP file - then load and calibrate it and off you go - I used the trial version with maps I scanned and some demo ones downloaded from oziexplorer and drove from Canberra to Newcastle and back using the maps - the only downside was having to restart the trial version every hour.
I would just take the time to carefully go through each of the menus in oziexplorer first, to see what is there - the load map menu should work. - Well it did for me - rememeber you will most likely have to calibrate the map using the load and calibrate menu - then the map will be ready for use.
Garry
FollowupID: 486309
Follow Up By: Bware (Tweed Valley) - Monday, Mar 05, 2007 at 18:54
Thanks, Garry.
FollowupID: 486388
Reply By: bgreeni - Sunday, Mar 04, 2007 at 23:31
You must have the file that has the map (a .JPG, .BMP etc) and another file with a .MAP extension. The .MAP file tells Ozi where the map is and its calibration etc. For a beginer it is best to have both files in the same directory.
Bruce
AnswerID: 225324
Follow Up By: Bware (Tweed Valley) - Sunday, Mar 04, 2007 at 23:49
You are talking to a computer 'dunce' LOL
FollowupID: 486228
Reply By: Keith_A (Qld) - Monday, Mar 05, 2007 at 10:19
Hi Brian - yes it well worth having on the home computer.
We use it often to check location of National Parks/ Forrests, find tracks/roads and also look for new places to camp.
Ozi has many features such as measuring distances between points.
It also lets you put markers on the map to record locations of interest. These markers can include text (notes about the spot) plus a picture.
It does take some time to learn - like anything new, but well worth the effort.
OK - some basics.
Oziexplorer is the program that DISPLAYS the maps.
It has a directory to store your map files - the directory is called 'Maps'.
The sample maps are there, but they are very limited.
Most people buy the Australian Govt NATMAP Raster Mosaic. (Mosaic means they have joined all the thousands of small maps of Aust into one seamless map).
A map is really just a big picture, so Ozi needs a second file called a dot-map (.map) file which has co-ordinates so Ozi can interpret the 'picture' as a map.
The most important button in Ozi is the 'Configuration' button. Click FILE, then click Configuration. Most of the settings are already filled out, but you MUST tell Ozi where your MAP files (called Map Images) are stored. If you don't, Ozi cannot find or display the maps.
Ozi includes a seach feature by name. When you first use this feature you will see a button called LOAD. Click this and load the Australian names file. After that, the SEARCH feature will work perfectly.
There is a web site and forum, just for Ozi - Oziusers - tech.groups.yahoo.com/group/OziUsers-L/
Worth a visit.
Ozi lets you take 'virtual/ trips' when you cannot afford to do the real thing. It also lets you look for alternate routes and even find new locations to visit. The CAMPS3 bible (lists all free or lowcost campspots) has GPS co-ordinates for most of the campsites listed so you can find them easily.
Use the trial version of Ozi, and set the Configuration. it is worth the effort.
Have fun.....................Keith
AnswerID: 225368
Follow Up By: Bware (Tweed Valley) - Monday, Mar 05, 2007 at 10:30
Cheers, Keith, that's great info. Thanks for explaining it so well :-))))
FollowupID: 486274
Reply By: Member - Doug T (W.A) - Monday, Mar 05, 2007 at 11:05
Bware
I too love maps , my favorite thing when I went to school, Oziexplorer will be ok just on the PC but there is a better set of maps , you could pre-buy Garmin Mapsource V 7 City Navigator Australia CD $349.00 (inc. GST) and it will allow you work out routes on the PC , but if your going to spend 349 dollars then one would be silley not to go a few more dollars and get a Garmin Quest that has the CD with it anyhow, www.ja-gps.com.au/garmin_quest_1.html .
The other map option would be Tracks4Australia CD $179 which is very good
www.gpsoz.com.au/oztopo/ , and you can have a snoop around my map and GPS page on the internet members.westnet.com.au/dtilley/maps.htm
AnswerID: 225377
Reply By: Member - Doug T (W.A) - Monday, Mar 05, 2007 at 11:15
If you have Broadband ADSL or Cable go to this site and you can download some huge maps
Site Link
AnswerID: 225380
Follow Up By: Bware (Tweed Valley) - Monday, Mar 05, 2007 at 18:56
Thanks, Doug.
I have plenty to ponder now :-))))
FollowupID: 486390
