Side Window Shades - What Sort
Submitted: Tuesday, Mar 06, 2007 at 15:59
Member - Norm C (QLD)
I'm looking at getting some side window shades for the rear doors on the Dual Cab Hilux. Main reason is that we now carry a second fridge in there (rear seats removed), and thought it might help to keep the temp down, particularly when parked.
I've seen the black micromesh ones that you slip over the top of the door frame and window. Haven't yet found any that are big enough for the Hilux.
Anyone any idea which are the best shades and how effective are they in keeping heat out of the vehicle.
Guess we should also leave a window down and inch or so if parked for long periods to allow a bit of air circulation.
Reply By: Shaker - Tuesday, Mar 06, 2007 at 16:39
Be careful leaving your windows down a bit, as your fridge might "escape".
225636
Reply By: Member - Davoe (Nullagine) - Tuesday, Mar 06, 2007 at 16:39
those socks are great..... until you go bush and tear them apart. i have el chepo windscreen sun blocks that you sit in the front windscreen. I cut them to size and superglued velcro dots to the sunshade and side windows so you just velcro on your shade. (cant see much out of them tho)
225637
Reply By: Kev M (NSW) - Tuesday, Mar 06, 2007 at 16:54
Norm,
The black micro mesh ones are good for the 1st year or so then they deteriate pretty quickly.
You can get them for the Hilux as they are make and model specific they cost any where from $30 to $50
I use them for the kids but have found that they still get burnt (one is a red head) so the old cloth nappy goes up as
They are quite good for stopping insects getting in as
well. You need to make sure that the kids haven't left them down parcally as we have not noticed until we moved off. Could cause a few problems if it rains
In the last 3 years I have gone through 2 sets and am now about to fit the 3rd set this weekend. They do reduce the amount of light in the back of a dual cab with canopy so should suit your purpose.
Cheers Kev
| Russell Coight:
225640
Reply By: porl - Tuesday, Mar 06, 2007 at 17:34
You could buy your own window tint and just put multiple layers on that window. Just google "DIY window tint" and you'll get heaps of options. I use the ezy-tin stuff at home, have yet to put it on my window above the fridge but plan to.
Not as effective as a sock but as above, the tint is on the inside when you go bush ...
225649
Reply By: Member RayJen Paj05 (NSW) - Tuesday, Mar 06, 2007 at 19:09
Hi Norm, we used the socks up north last year on the back windows - Tanami and GRR. Aim was to provide shade for back
seat fridge location. They provided shade and improved security as
well as lower temp in cabin but constant dust environment caused a kind of permanent sandblasting effect on the friction points on paint and glass.
Ours were mid-priced, don't know if top $$ ones would work better in that respect.
All the best, RayJen
225665
Follow Up By: Member - Norm C (QLD) - Tuesday, Mar 06, 2007 at 19:27
Hadn't thought of that RayJen. I guess it is the dust and small dirt particles caught in the cloth then rubbing on the glass and paint. If so, I suppose I could take them off and rince them out every now and then. But would I do it??
Norm C
486565
Reply By: Doggy Tease - Tuesday, Mar 06, 2007 at 20:11
Gday Norm, got just the thing for ya mate.
It is called Solar Screen. Actually made outa the same sort of stuff that the humble windscreen shade is made from. The difference is that these things are made to measure, use suction cups to attatch to the window(tint not harmed) and completely block the sun, and all those prying eyes..:).
We recently got them for the Patrol.The rear cargo area windows are now always covered and the temp decrease is definately noticable. We also got the rest of the screen's so that when camped, the entire window area can be covered.
Solar Screen (QLD) 07 3398 5500
meow.
rick.
a satisfied customer only, no affiliation.
225682
Follow Up By: Member - Norm C (QLD) - Tuesday, Mar 06, 2007 at 20:27
Thanks Rick. Tried Google, but no luck
Do they have a web site?
Norm C
486571
Reply By: Kumunara (NT) - Tuesday, Mar 06, 2007 at 23:16
Norm
I noticed that your vehicle has a canopy and I presume it is fibreglass. Fibreglass does not heat up like metal and you will find that the rear of your vehicle will be cooler than the cabin. I suggest that you consider putting the fridge in the rear rather than the cabin.
225728
Follow Up By: Member - Norm C (QLD) - Tuesday, Mar 06, 2007 at 23:29
Thanks mate. Got a 70 litre fridge in the back (under canopy). Also a 40 litre in cab. No room for anything else under canopy. This is what it looks like now.
!MPG:9!
486633
Reply By: Doggy Tease - Tuesday, Mar 06, 2007 at 23:54
Gday Norm. Solar Screen don't have a web site from what i understand.
We actually saw the stuff on another Patrol over xmas whilst we were in
Denham and went for a sticky beak...:) they are actually padded window screen's is about the best way to describe them i suppose. Cut to the shape of the window, with a few suction cups to hold them in place. I reckon they are bloody
well made and a bargain at the price.
They advertise in the 4wd monthly mag is about all i can tell ya mate, and they do a heap of caravan's as
The bloke is real easy to have a yak with,,and will do his best to help you out if he can.
We paid less than $500 for the complete set that goes in the Patrol,,,thats every window- total blackout inside,,,.
When we were in
Denham, the fridge struggled to hold its own against the heat, to the point that i had to cover it with a doona to help the proper fridge cover do its job.
The last few days over here have been a tad warm, and with the screen's on, the fridge just purr's along nicely......with no more doona over it...:)
meow.
rick.
225732
Reply By: Member - Arkay (SA) - Wednesday, Mar 07, 2007 at 09:17
Heather bought some black mosquito netting stuff from Priceline for about $8 and made a couple of shaped window socks for the front window . Sewed them up on her humble sewing machine. We use them to keep the pesky flies out and let the breeze in when we stop for a cuppa or lunch sitting in the car in the shade. Don't use them while in motion, I am anti-dust.
The car aircon helps keep the interior cool when driving so the car fridge doesn't struggle so much.
We can put the front window socks on when stopped for extended periods in a safe place, e.g in an isolated
bush camp, or we are in attendance and in sight of the vehicle all the time.
225760
Follow Up By: Member - Arkay (SA) - Wednesday, Mar 07, 2007 at 09:18
Sorry, she said it was Spotlight not Priceline.
486668
Reply By: Member - John B (QLD) - Wednesday, Mar 07, 2007 at 11:27
Hi Norm the quality brand is Chevron ,repco will order yhem for u . We remove them when motoring , have had them for nearly 3 years and they have hardly faded.
225778
