explorer crankshaft holding tool
Submitted: Tuesday, Mar 06, 2007 at 18:30
ThreadID: 42968 Views:3400 Replies:5 FollowUps:13
Anyone out there have a ford explorer crankshaft holding tool they want to sell or hire out? Am in deperate need of one as i cant get one off ford.
Exploder, do you have any ideas as you sem to be the guru on explorers. This is all i need now to finish off my timing chain saga
Reply By: Exploder - Tuesday, Mar 06, 2007 at 18:56
Ford didn’t wouldn’t lend you there’s, no surprises there.
Get this one off E-bay in the U.S use it once then sell it agene or keep it, rent it out, what ever.
Site Link
How did it all go mate, getting the parts from the guys in the states, any problems, or was it easer than it sounded LOL
Let us know when you get it running agene.
Cheers.
AnswerID: 225662
Follow Up By: jase_c - Tuesday, Mar 06, 2007 at 19:59
Hail exploder!
was problem free getting everyhing i needed from the U.S, found fast parts network very helpful, total spent so far- $600 australian compared to $1400 or more from Ford. May harrasss ford mechanics a little more for the tool first,lol
should be running in a week hopefully
thanks mate!
FollowupID: 486567
Reply By: Graham & Lynne - Tuesday, Mar 06, 2007 at 20:42
what are you doing ? Im a mechanic do you want to undo & or do up harmonic balancer?If so buy ABW tool from REPCO for $130.00 it is 1/2 inch drive put socket on one end & hit other end with 5lb hammer.
AnswerID: 225692
Follow Up By: Exploder - Tuesday, Mar 06, 2007 at 20:52
No mate, He has just replaced the timing chains and tentioners, On the Explorer SOHC V6, with out writing a essay about the timing set up on these engines, basically once the seid parts have been replaced to toque the Camshaft sprocket’s up and keep the timing correct you need the above pictured tool kit to lock the cam timing in position.
Cheers.
FollowupID: 486584
Follow Up By: jase_c - Tuesday, Mar 06, 2007 at 22:39
ya, need the tool to lock the crank in place at T.D.C to align both cams up.
B.T.W how do you post an image up here?
FollowupID: 486625
Follow Up By: Exploder - Wednesday, Mar 07, 2007 at 18:15
Bottom of ya follow up page
“To Post hyper links”
Copy and past the For images one
And delete this bit domain.com/image_path
Then paste you photo link in place of it.
Buy the way photos have to bee hosted off site to come up unless you are a member
Cheers.
FollowupID: 486764
Reply By: Graham & Lynne - Wednesday, Mar 07, 2007 at 18:50
check to see if the crankshaft is tightened
AnswerID: 225893
Follow Up By: jase_c - Wednesday, Mar 07, 2007 at 19:28
I dont need to tighten the crankshaft, just need the holding tool to align it at T.D.C
FollowupID: 486802
Reply By: Graham & Lynne - Wednesday, Mar 07, 2007 at 21:10
did some research for you 2day, ford dealers dont have the tool in Lismore or Ballina, send the complete engine to Brisbane, so i dont think your dealer will have the tool either.
so plan B, i had a similar problem lining up a camshaft on a BMW
i got a copy of procedures from ford, let me know if you need these.
your firing order should be 1 4 2 5 3 6, I'm not sure which is number one on your engine though, it will be either one of the cylinders on the front bank
you will need a chain pair of VICE GRIPS part number "20r" they look like a 10" vice grips with a 500mm long chain, cost $60 from Repco, Blackwoods
position engine on T.D.C. no 1, there should be timing marks for this on front of the block. the crankshaft may need holding with a socket and breaker bar, you will need an assistant to hold this.
the tensioner should be on the slack side of the chain, i.e. on non-drive load side. wrap VICE GRIPS around eccentric lobe on camshaft, that O.E. tool locates on and turn camshaft in opposite direction of engine rotation.
so lobes on cam for no. 1 cyl. are both pointing up at the same angle, that is exhaust lobe is same angle past 12 o'clock as is same angle of inlet before 12 o'clock. ensure there is no slack in timing chain by holding it in the opposite direction of normal rotation. now tighten cam bolt up.
install this cams tensionor
now carefully turn crankshaft 360 degrees in direction of rotation, this will result in no. 5 being on T.D.C. ensuring no valves hit.
repeat the above three paragraphs for this cam.
now carefully turn engine in direction of rotation making sure no valves hit and no. 1 lobes are back up the top again.
now carefully turn crankshaft 360 degrees in direction of rotation and now no. 5 lobe should on top.
you now have your engine timed correctly, ready to go exploring in your explorer
AnswerID: 225928
Follow Up By: jase_c - Wednesday, Mar 07, 2007 at 21:46
Hey thanks guys! all this info is helpful. My mechanic friend has come through with a lot of begging and hassling and got the tool on loan from someone at ford in Brisbane( persistance pays off ). Fingers crossed and she should be running by this time next week. B.T.W anyone after the rear seat to make theirs a 7 seater?
FollowupID: 486850
Follow Up By: Exploder - Wednesday, Mar 07, 2007 at 22:26
Not a bad way to get around it if you can’t get the tool, Graham
Cheers.
FollowupID: 486867
Reply By: Exploder - Wednesday, Mar 07, 2007 at 22:36
Hay Jase, Were any of your chain guides or tentioners damaged, like have pieces/ chucks missing, snapped or worn badly?
If so they often end up in the sump and or stuck to the oil pump pick up screen.
Cheers.
AnswerID: 225959
Follow Up By: jase_c - Thursday, Mar 08, 2007 at 06:19
both chain guides were broken and the peices were all through the sump mate! oil residue was quite sludgy which is what may have caused the tensioners to fail. Has been cleaned now and will hopefully get another 245 000kms out of it.
FollowupID: 486897
Follow Up By: Exploder - Thursday, Mar 08, 2007 at 19:03
Yeah mate if looked after these engines have a good service life the timing set up just let's em down, sounds like it may have had a few skipped oil changers or had cheep oil used in it at some stage.
Cheers.
FollowupID: 487013
Follow Up By: jase_c - Friday, Mar 09, 2007 at 09:15
Can you recommend any particular oil thats good for them, or just go for a good quality one?
FollowupID: 487133
Follow Up By: Exploder - Friday, Mar 09, 2007 at 15:34
Any good name 10W30, 10W40 or10W50 oil
I use Penrite HPR 10 (10W50) changed every 10,000k or 6months and only use the Ford Motorcraft oil filters.
I wouldn’t use anything heaver than a 10 weight oil in them. They originally took a 5W30 but Ford Australia revised that a few years ago to 10w30, I use the 10W50 as a lot of my applications are long miles on the black top with off-road work as well, the car spend next to no time in city traffic.
A few people in the states have run a 0W30 in them from new with 0 problems, but I wouldn’t recommend switching to that with 200,000+ on the clock.
Cheers.
FollowupID: 487210
Follow Up By: jase_c - Monday, Mar 26, 2007 at 11:48
hi exploder,
engine is back in car and running! what auto transmission fluid do you use as mine needs a top up?
FollowupID: 490537
Follow Up By: Exploder - Wednesday, Mar 28, 2007 at 18:33
Mate use Mercron V type fluid.
It’s $20 a quart from ford.
Other wise use Penrite Fully synthetic ATF at $45 for 4 litres as this meats the Mercron V standards.
Don’t use a Dexton Type fluid in it; It needs to have a Mercron V spec fluid used.
You may need to get the penrite ordered in as not many Auto parts shops stock it on the shelf, I only no of 2 shops in Perth that have it as a shelved item.
Give Penrite a call directly and they will tell you who they supply it to in your aria
Cheers.
Cheers.
FollowupID: 491128
