Question - GU Patrol Front Recovery Hooks
Submitted: Wednesday, Mar 07, 2007 at 20:41
jdpatrol
Hi all
Sourced a second front recovery hook from an interstate wrecker, unseen, for my 2004 Patrol wagon.
Arrived today. Not what I expected – probably ok – dunno?
On my Patrol, the original hook is bolted to bottom of chassis rail along the rail centre. . It’s basically a straight bit of solid metal tube bent down and around, with 2 large bolts connecting it to a thread welded inside the chassis rail.
The one that came today fixes to the side of the chassis rail with a plate, to which a hook (similar dimensions to original hook) is welded. The plate is bolted to the chassis rail with three bolts. Definitely solid. Rail has threads inside the rail – same bolt size – correctly positioned – Definitely must have been made for a Patrol. Thing I don’t like is the line of load will be eccentric to the line of the chassis rail – i.e. will generate bending forces (a ‘moment’ to the engineers out there) around the weak axis of the chassis.
Any thoughts?????
JD
Reply By: Marn - Wednesday, Mar 07, 2007 at 20:55
Try it. If it bends you will know its no good.:)
225918
Reply By: goingplatinumcomau - Wednesday, Mar 07, 2007 at 20:57
Hi JD
I can understand your preperation for futcher towing requirements of Said Nissan re = Motor Problems.
However most Tray Top Tow Trucks can back in and roll them up No Poblem.
Unless of course you intend to go out the bush then they will not have the most up to date tow trucks.
Just incase you need it towed a long way may be best to weld it on ?.
Regard's Jon
225919
Follow Up By: Grandpa joe - Wednesday, Mar 07, 2007 at 21:11
So what's your next act? Juggling ?
Ya' CLOWN
486836
Follow Up By: jdpatrol - Wednesday, Mar 07, 2007 at 21:18
Mate this was a serious question. Why dont you go check out a Toyo website or something - might have a
forum discussion on recovering vehicles with broken diff's or something. LOL :-)))))))))
486838
Follow Up By: Member - Brian (Gold Coast) - Thursday, Mar 08, 2007 at 09:57
I agree...... with Grandpa joe and jd!
How about a serious answer to a serious question.
If you're going to 4wd, it makes damn good sense to have recovery gear in place, NO MATTER WHAT YOU DRIVE!
486918
Follow Up By: Member - BORGY.. (SA) - Thursday, Mar 08, 2007 at 10:20
I agree with all of the above ...and wtf is futcher
486923
Follow Up By: Bilbo - Thursday, Mar 08, 2007 at 10:43
Isn't this the same guy - "Goingplatinum" that rambled on about 3.5 litre Nissan engines a few days ago?
I think he's one of our American cousins,,,,,,,,
I may be wrong, but the reply is a bit sarcastic.
Bilbo
486929
Follow Up By: Shawn - Thursday, Mar 08, 2007 at 12:07
Mate,
I would also suggest you use the spell Chekka
486939
Reply By: barney rubble - Wednesday, Mar 07, 2007 at 21:38
Gday JD mate while i aint no engineer i have to agree the line of load dont sound right but mate why the need for another recovery hook is there a fault with the original fitments i should know about because when you say metal tube bent yep sounds weak as put that way
but obvoiusly the nissan /toyota thing is alive and
well
i think another forumite sums it
well with "when all else fails buy a nissan"
225936
Follow Up By: jdpatrol - Wednesday, Mar 07, 2007 at 21:59
"when all else fails buy a nissan" - couldn't agree more Barney - very happy with
mine.
Look no problems to speak of with the existing hook - Nissan hook about as heavy as any Ive seen. But we have been involved in quite a few serious snatches - e.g. recovering others and being recovered ourselves in deep mud. I'm conscious the load all going down one side all the time cant be that good - so want to spread the load where I can. I also like the idea of using a lanyard (??) , particularly after seeing a strap let go on a video (referred to on EO a few months ago). JD
486854
Follow Up By: Muzzgit [WA] - Wednesday, Mar 07, 2007 at 23:32
The thing to remember is that with 2 recovery points on the front, and assuming you will use both as often as possible, the new one will cope with anything you give it because it will only be taking half the load.
Does that make sense?
486881
Follow Up By: jdpatrol - Thursday, Mar 08, 2007 at 10:08
Makes sense to me Muzzgit
That's really what its all about IMO. Regards JD
486921
Reply By: greggu - Wednesday, Mar 07, 2007 at 21:45
jd patrol mate you can buy the original tow hook from nissan dealers but will have to order in cost about 40 $ as i recall but you have to source the HT bolts from a bolt store to bolt it on on the other side with the threaded holes are in place - i did this - the one you have from the wrecker is probably ok but check the welding real close
any torsion loads will depend on the angle of the pull so and yes in simple terms if the pull is at an angle will both try to shear the bolts and pull them out at the same time whereas with the original hook position its all basically a shear load - if you were to hook both ends of a tow rope or snatch strap to both hooks should all be ok - but hard to say without really seeing it - and yes i am an engineer civil usually
but mate that other dopey wank@r is a real DH is he not
see you greg
225941
Follow Up By: jdpatrol - Wednesday, Mar 07, 2007 at 22:12
thanks Greg. Yeah, get a bit tired of the Nissan knockers.
Gees I was quoted about $100 by my local Nissan place, which is why I sourced it from Wreckers. Bugger
Welding looks good. We'll see eh. Regards JD
486862
Reply By: Kiwi Kia - Thursday, Mar 08, 2007 at 11:24
I would not use a welded hook. I have been involved with testing recovery hooks and we found that some welds have crystallised the metal and caused the hooks to snap. Forged hooks 'unwind' (straighten out) when overloaded which is better then having a chunk of metal fly through the air. Also, use grade 8.8 bolts and no higher. The higher the tensile rating the more brittle the bolts become.
A new forged hook should cost less then $20
226043
Reply By: greggu - Thursday, Mar 08, 2007 at 19:56
no worries jd if the welds are good and its bolted in with three bolts say 12mm size or larger then it all sounds like it should be ok to me - no cerification though with out seeing it
see you greg
226146
Reply By: Patrol_Driver - Sunday, Mar 11, 2007 at 11:13
I got a 2nd recovery hook put on by my Nissan dealer during a 20,000 service, I said how much and the mechanic said "carton of beer". Not sure whose car they took the hook off but I was happy!
226715
